[ASP] Emailadres check / bestaand of niet?
  • 64 views sinds 30-01-2008
zou iemand mij kunnen vertellen hoe ik in onderstaand script aan kan passen zodat in de db gekeken wordt of het ingevulde e-mailadres al bestaat of niet?
Op dit moment is het namelijk mogelijk om hetzelfde e-mailadres meerdere keren toe te voegen..
dim lID ' as long
dim sAction ' as string
dim sEmailAddress ' as string
dim sName ' as string
dim lGroups ' as array of long
dim i ' as integer
lID = clng(request("ID"))
sAction = lcase(request("action"))
if lID <> 0 then LoadEmail (lID)
select case sAction
case "save"
sEmailAddress = trim(request("EmailAddress"))
sName = trim(request("achternaam"))
if request("Group").Count > 0 then redim lGroups(request("Group").Count - 1)
for i = 1 to request("Group").Count
lGroups(i-1) = clng(request("Group")(i))
next
SaveEmail lID, sEmailAddress, sName, lGroups
response.redirect "../members.asp"
case "delete"
DeleteEmail lID
end select
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<title>E-mail adres</title>
<script language="javascript" src="../../../include/new_validate.js"></script>
<script language="javascript">
function Save()
if (isValid(formulier)){
formulier.action.value = "save";
formulier.submit();
function Delete()
formulier.action.value = "delete";
formulier.submit();
</script>
<link href="../../acm.css" rel="stylesheet" type="text/css">
</head>
<body>
<form name="formulier" id="formulier" action="email.asp" method="post" target="_self">
<input type="hidden" name="action" value="">
<input type="hidden" name="id" value="<%= lID %>">
<table width="575" border="0" cellpadding="2" cellspacing="0" class="tekst_backoffice">
<tr>
<td width="1%" bgcolor="#d4d0c8"><a href="#" onClick="javascript:Save();">[img]"../../images/kn_save.gif"[/img]</a></td>
<td width="96%" align="right" bgcolor="#d4d0c8"></td>
<td width="1%" bgcolor="#d4d0c8">[img]"../../images/transparant.gif"[/img]</td>
<td width="1%" align="right">[img]"../../images/transparant.gif"[/img]</td>
</tr>
</table>
<br>
<table width="278" border=0 cellpadding=0 cellspacing=0 class="tekst_backoffice">
<tr align=left valign=middle>
<td class="tekst_backoffice" title="E-mail adres"> E-mail adres:<span class="alert">*</span>
</td>
<td>
<input type="text" validator="email" name="EmailAddress" required description="E-mail adres" maxlength="255" size="25" value="<%= sEmailAddress %>">
</td>
</tr>
<td class="tekst_backoffice" title="Naam"> Naam: </td>
<td>
<input type="text" name="achternaam" description="Achternaam" maxlength="255" size="25" value="<%= sName %>">
</td>
</tr>
<%= BuildGroupList (lID) %>
</table>
<div>
<div align="left"><span class="tekstalert"><br>
<font color="#FF0000">* is een verplicht veld</font></span><font color="#FF0000"><br>
 </font><br>
</div>
</div>
<div class="hr"></div>
</form>
</body>
</html>
public sub SaveEmail (lID, sEmailAddress, sName, lGroups)
dim sSQL ' as string
dim i ' as integer
dim rs ' as ADODB.Recordset
'@commment Save updated or new e-mailaddress.
if lID = 0 then
'@comment Insert if group does noet exist yet.
set rs = server.createobject("ADODB.Recordset")
rs.Cursorlocation = adUseServer
rs.Open "tbMember", CONNECTIONSTRING_MAILING, adOpenKeySet, adLockOptimistic, adCmdTableDirect
rs.AddNew
rs.Fields("MemberEmail") = sEmailAddress
rs.Fields("MemberName") = sName
rs.Update
lID = rs.Fields("MemberID").Value
rs.Close
set rs = nothing
else
'@comment Update if group already exists
sSQL = "UPDATE [tbMember] SET MemberEmail = '" & EscapeForSQL(sEmailAddress) & "'," & _
" MemberName = '" & EscapeForSQL(sName) & "'" & _
" WHERE MemberID = " & lID
ExecuteSQL CONNECTIONSTRING_MAILING, sSQL
end if
'@comment Delete previous groups
sSQL = "DELETE FROM AddressGroup WHERE fkMember = " & lID
'@Comment Save updated or new groups
for i = lbound(lGroups) to uBound(lGroups)
sSQL = "INSERT INTO AddressGroup (fkMember, fkGroup) VALUES (" & _
lID & ", " & lGroups(i) & ")"
next
end if
end sub
'* Load the data of an e-mail address
'@param lID - the id of the e-mail address
public sub LoadEmail (lID)
sSQL = "SELECT * FROM tbMember WHERE MemberID = " & lID
set rs = DisconnectedRecordset (CONNECTIONSTRING_MAILING, sSQL)
sEmailAddress = trim(rs.fields("MemberEmail").Value)
sName = trim(rs.fields("MemberName").Value)
rs.close
set rs = nothing
end sub
'* Delete an e-mail address and all its associated data
'@param lID - the ID of the e-mail address you wish to delete.
public sub DeleteEmail(lID)
'@comment Delete links to groups.
'@comment Delete member
sSQL = "DELETE FROM tbMember WHERE MemberID = " & lID
end sub
'* Builds a list of all groups with checkbuttons
'@param lAddressID - The ID of the address for which you want to build the grouplist
'@returns a string with the correct HTML for the groupslist.
public function BuildGroupList (lAddressID)
dim sHTML ' as string
dim rsGroup ' as ADODB.Recordset
dim lCount ' as long
dim lGroupID ' as integer
dim sChecked ' as string
dim i ' as integer
sSQL = "SELECT ID, Name, Description FROM [Group] ORDER BY Name"
sHTML = ""
set rsGroup = DisconnectedRecordset (CONNECTIONSTRING_MAILING, sSQL)
i = 0
do while not rsGroup.EOF
lGroupID = clng(rsGroup.Fields("ID").Value)
sSQL = "SELECT COUNT (*) FROM AddressGroup WHERE fkMember = " & lAddressID & _
" AND fkGroup = " & lGroupID
lCount = clng(Field(sSQL, CONNECTIONSTRING_MAILING))
if lCount = 0 then
sChecked = ""
else
sChecked = "checked=""checked"""
end if
sHTML = sHTML & "<tr>" & vbcrlf
if i = 0 then
sHTML = sHTML & "<td>Groepen:</td>" & vbcrlf
else
sHTML = sHTML & "<td> </td>" & vbcrlf
end if
i = i + 1
sHTML = sHTML & "<td colspan=""2"">" & vbcrlf
sHTML = SHTML & "<input type=""checkbox"" name=""group"""
sHTML = sHTML & " value=""" & rsGroup.Fields("ID").Value & """"
sHTML = sHTML & " " & sChecked & ">" & vbcrlf
sHTML = sHTML & rsGroup.Fields("Name").Value & " " & rsGroup.Fields("Description").Value
sHTML = sHTML & "</td>" & vbcrlf
sHTML = sHTML & "</tr>" & vbcrlf
rsGroup.Movenext
loop
rsGroup.Close
set rsGroup = nothing
BuildGroupList = sHTML
end function
  • gorgi_19
  • Laatst online: 08:35
gorgi_19
Kruimeltjes zijn weer op :9
ASP:
"SELECT Count(*) as aantal FROM tbMember WHERE Email = '" & Request.Form("Email") & "'"
En dan kijken hoe groot de aantal is; 0 bestaat er geen, groter dan , bestaat het wel.
[ Voor 75% gewijzigd door gorgi_19 op 02-03-2004 12:28 ]
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • whoami
  • Laatst online: 11:53
Hoi,
Het is niet de bedoeling van P&W dat je anderen voor jou aan het werk kunt zetten om een script dat je ergens gevonden hebt aan te passen.
Het is hier de bedoeling dat men elkaar helpt bij programmeerproblemen, maar het is niet de bedoeling dat anderen al het werk voor jou opknappen.
https://fgheysels.github.io/
