NTFS Error?
  • 29 views sinds 30-01-2008
hi,
i didn't know where i had to place this question, so don't shoot me if it's on the wrong place!
I have an
-AMD Athlon 2500+ barton core
-512mb ram @333hz
-ABIT NF7-s mobo
-Ati radeon 9600 128mb
-Windows XP Dutch version (Home edition)
-Maxtor diamondmax plus 9, 80gig ATA/133
I putted this computer together the usual way i do (i'm not a noob in this), formatted the hard disk with quick NTFS structure and I installed windows xp and everything works. 2days later suddenly while the PC was booting i get the message "the following file /system32/ntfs.sys is corrupt of missing, you can try to repair this file with the Windows XP cd".
OK, i try to repair it, but it doesn't work. I formatted the whole disk and this time i took the long NTFS structure. Again everything installed...1day later...same failure!
again i formatted, but again..a day later it crashed.
now is my question...what's the problem here? a bad harddisk? or something else?
plz help me, because i need this pc asap for my school work!!
greets
  • TERW_DAN
TERW_DAN
Met een hamer past alles.
Hoi, welkom op got.
Zoals je misschien al wel had opgemerkt is dit een Nederlands forum dus is het ook wel erg fijn als je je topicstart netjes in het Nederlands tikt.
ik denk dat je eerst je geheugen maar eens moet gaan testen met memtest86.com.
ow sorry :) ik dacht dat het een engels forum was.
nuja het is niet in zo'n moeilijk engels geschreven :P
maa rzal er op letten in het vervolg
  • dion_b
  • Laatst online: 23:38
dion_b
say Baah
Welcome to Gathering of Tweakers :)
Given that you have a Dutch version of Windows XP I assume you are able to communicate in that language. If you intend to post on GoT, please do so in Dutch. If that is not really an option, might I suggest English forums such as Anandtech or Ars Technica. In any event this topic does not comply with the GoT rules, mainly as it is in English, so I shall close it as per those very same rules.
Oslik, blyat! Oslik!
