[Fedora] Speedtouch USB modem probleem!
Ik ben al enkele avonden bezig met het installeren van mijn mooie groene klote Speedtouch USB modem onder Fedora Core 1
Als ik na de installatie verbinding wil gaan maken krijg ik deze fout
[root@webserver root]# /root/startadsl&
[1] 3307
[root@webserver root]# BLOCK1 Connection timed out
get_reference: pusb_control_msg: Connection timed out
URB147: Connection timed out
URB148: Connection timed out
URB149: Connection timed out
URB150: Connection timed out
modem_start_synchro: pusb_control_msg: Connection timed out
Error reading interrupts
Ik heb het modem geinstalleerd door het volgen van deze step by step guide
After spending a long time trying to get my ADSL modem working on RedHat Linux I stumbled upon the following procedure at devshed.com. I take no credit for the contents of this article, I just reproduced it so I would never have trouble finding it again.
If you are using Fedora Linux you must delete the speedtch.o file from the kernel and reboot before following this procedure. The file can be located using:
find /lib/modules/ -name speedtch.o
Download the following files:
speedtouch-20011007.tar.gz
speedmgmt.tar.gz
ppp-2.4.0-2.i386.zip
Copy the files to the /root directory and perform the following operations as the root user.
Run the ppp-2.4.0-2.i386.rpm file to update PPP to use PPPoA:
unzip ppp-2.4.0-2.i386.zip
rpm -i --force ppp-2.4.0-2.i386.rpm
Extract and make the code in the speedtouch-20011007.tar.gz file:
tar xvvzf speedtouch-20011007.tar.gz
cd speedtouch-20011007
./configure
make
make install
Extract the code in the speedmgmt.tar.gz file, but do not make it:
tar xvvzf speedmgmt.tar.gz
Create the adsl file as follows:
cd /etc/ppp/peers
vi adsl
Add the following information into the file:
debug
kdebug 1
noipdefault
defaultroute
pty "/usr/local/bin/pppoa2 -vpi 0 -vci 38"
nodetach
sync
user "username@provider"
noauth
kdebug 7
noaccomp
nopcomp
#nomagic
noccp
#passive
#lcp-echo-interval 5
#lcp-echo-failure 30
#persist
Your service provider should be able to give you the values for -vpi, -vci and user. Most of the service providers in the UK use the -vpi and -vci settings listed.
Add the username and password to the chap-secrets file:
vi /etc/ppp/chap-secrets
The third line should be added with the appropriate values:
# Secrets for authentification using CHAP
# client server secret IP addresses
username@provider * yourpassword
Create a startup script:
cd ~
vi startadsl
Enter the following information:
#!/bin/sh
/sbin/modprobe n_hdlc >& /tmp/pppd.log
/sbin/modprobe ppp_synctty &> /tmp/pppd.log
/usr/local/bin/modem_run -f /root/mgmt/mgmt.o -m
/usr/sbin/pppd call adsl &> /tmp/pppd.log
/sbin/route add default ppp0
Save the file then change it's permissions using:
chmod 700 /root/startadsl
Create a file to reference your DNS servers:
vi /etc/resolv.conf
Enter the addresses of your DNS servers like:
nameserver 158.43.240.4
nameserver 158.43.240.3
Create a stop script:
vi stopadsl
#!/bin/sh
kill -INT `pidof pppd`
chmod 700 /root/stopadsl
The ADSL connection can then be started and stopped using the following commands:
# Start ADSL
/root/startadsl&
# Stop ADSL
/root/stopadsl
Output from the pppd process is logged in the /tmp/pppd.log file. This can be viewed using:
Ik heb ook deze algemene linux guide geprobeerd van Xs4all
( http://www.xs4all.nl/help...b/linux/configureren.html )
Dit werkte ook niet. Al kreeg ik geen foutmelding hierbij :(
Kan iemand mij helpen? Waar kan dit aan liggen?
Zou dit aan mijn firewall liggen? Ik heb bij setup niets aparts hierin aangevinkt. Alleeen dat het www/ftp/mail moest doorlaten
heeft iemand maybe FAQ die WEL werkt?
  • Zwerver
Verwijderd schreef op 22 februari 2004 @ 13:31:
als je nou eens je firewall (iptables neem ik aan?) gewoon flushed? En de standaard policy's op ACCEPT zet, werkt die dan wel? Want volgens mij moet je voor adsl verkeer andere porten doorlaten
Woonachtig Down Under. Ik negeer je insults niet, maar tegen de tijd dat ik ze lees zijn ze meestal niet relevant meer
Zwerver schreef op 24 februari 2004 @ 20:59:
Tja ik las dat ik niets hoefde aan de passen in mijn firewall (aldus de kilometers linux docs die ik heb doorgelezen) maar ik zal het toch proberen. Kunnen de timeouts daardoor komen?
