[Cisco SOHO97] Router reageert niet
Ik ben heb net de firmware van m'n Cisco SOHO97 geupdate, maar nu doet ie nix meer.
Alles wat ie aan informatie geeft is dit:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
Self decompressing the image : #################################################
8192K bytes of processor board System flash (Read/Write)
##################################### [OK]
2048K bytes of processor board Web
              Restricted Rights Legend
 dsl
Use, duplication, or disclosure by the Government is ^
% Invalid input detected at '
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
Cisco Internetwork Operating System Software
IOS (tm) SOHO97 Software (SOHO97-K9OY1-M), Version 12.2(13)ZH2, EARLY DEPLOYMENT
 RELEASE SOFTWARE (fc1)
Synched to technology version 12.2(14.5)T
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Tue 22-Jul-03 13:43 by ealyon
Image text-base: 0x800131C0, data-base: 0x808D0C84
Compliance with U.S. Export Laws and Regulations - Encryption
This product performs encryption and is regulated for export
by the U.S. Government.
This product is not authorized for use by persons located
outside the United States and Canada that do not have prior
approval from Cisco Systems, Inc. or the U.S. Government.
This product may not be exported outside the U.S. and Canada
either by physical or electronic means without PRIOR approval
of Cisco Systems, Inc. or the U.S. Government.
Persons outside the U.S. and Canada may not re-export, resell,
or transfer this product by either physical or electronic means
without  prior approval of Cisco Systems, Inc. or the U.S.
Government.
CISCO SOHO97 (MPC857DSL) processor (revision 0x400) with 29492K/3276K bytes of m
emory.
Processor board ID AMB071902AL (2741581432), with hardware revision 0000
CPU rev number 7
Bridging software.
1 Ethernet/IEEE 802.3 interface(s)
1 ATM network interface(s)
128K bytes of non-volatile configuration memory.
2048K bytes of processor board Web flash (Read/Write)
 dsl power-cutback 0
% Invalid input detected at '^' marker.
ý
Press RETURN to get started!
*Mar  1 00:00:10.871: %LINK-3-UPDOWN: Interface Ethernet0, changed state to up
00:00:11: %SYS-5-CONFIG_I: Configured from memory by console
00:00:12: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed sta
te to up
00:00:13: %LINK-3-UPDOWN: Interface ATM0, changed state to down
00:00:14: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0, changed state to
 down
00:00:15: %SYS-5-RESTART: System restarted --
00:00:15: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold star
t
en dan blijft ie hangen, terwijl er nog 'n paar lampjes knipperen.
Heeft iemand enig idee wat dit kan zijn? :?
Oudere firmware even installeren en testen. Als hij het weer doet de nieuwe proberen. Mocht dat niet helpen dan is er iets mis met de firmware.
Ik heb een SOHO96 en een SOHO97 op mn werk. Niet onder eigen beheer ;)
  • Dennism
  • Registratie: September 1999
wel op enter gedrukt? anders doet ie nl niets nee!
staat zelfs duidelijk op regel 65 van jou code stukje ;)
[ Voor 39% gewijzigd door Dennism op 19-02-2004 11:18 ]
  • Metalium-220
  • Laatst online: 12-08-2022
Metalium-220
Forza Utreg!
LOL :D
Ik heb dezelfde router en hij wacht op dit punt gewoon op een reactie van de gebruiker. Inderdaad dus gewoon even op enter rammen.
Dennism schreef op 19 februari 2004 @ 10:14:
Jah, lezen kan ik ook nog wel...
Heb natuurlijk ook op Enter gedrukt, maar ding blijft gewoon hangen... :/
