Probleem met .NET installeren.
  • razmir
  • Laatst online: 17-08 17:06
razmir
Waar is mijn Q gebleven?
Ik zit nu al 2 dagen te proberen windows .net framework te installeren.. maar hij wil niet echt..
Hier is wat dotnetfx.log zegt:
[02/18/04,03:45:05] Starting Install.exe
[02/18/04,03:45:05] Parsing switches from commandline: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\IXP000.TMP\Install.exe
[02/18/04,03:45:05] SourceDir: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\IXP000.TMP\
[02/18/04,03:45:05] Install started
[02/18/04,03:45:05] Checking system requirements
[02/18/04,03:45:05] OS: Win 2k
[02/18/04,03:45:05] Ver:
[02/18/04,03:45:05] SP: Service Pack 4
[02/18/04,03:45:05] Checking Internet Explorer Version
[02/18/04,03:45:05] Looking for 5.0.2919.6307
[02/18/04,03:45:05] Found Internet Explorer Version: 5.00.3700.1000
[02/18/04,03:45:05] Internet Explorer Version is OK...
[02/18/04,03:45:05] System meets minimum requirements
[02/18/04,03:45:05] Checking Windows Installer version...
[02/18/04,03:45:05] Trying to load msi.dll
[02/18/04,03:45:05] Loading: C:\WINNT\system32\msi.dll
[02/18/04,03:45:07] msi.dll loaded ok
[02/18/04,03:45:07] Looking for: 2.0.2600
[02/18/04,03:45:07] Found: 2.0.2600
[02/18/04,03:45:07] Windows Installer version ok
[02/18/04,03:45:07] Finished Checking Windows Installer version.
[02/18/04,03:45:07] Trying to load msi.dll
[02/18/04,03:45:07] Loading: C:\WINNT\system32\msi.dll
[02/18/04,03:45:07] Looking for mscoree.dll from PDC
[02/18/04,03:45:07] mscoree.dll from PDC is not installed local
[02/18/04,03:45:07] Looking for mscoree.dll from Beta
[02/18/04,03:45:07] mscoree.dll is not installed local
[02/18/04,03:45:09] Installing: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\IXP000.TMP\netfx.msi
[02/18/04,03:45:09] Checking IIS...
[02/18/04,03:45:09] Checking MDAC Version
[02/18/04,03:45:09] Looking for 2.70.7713.0
[02/18/04,03:45:09] Found MDAC Version: 2.53.6200.1
[02/18/04,03:45:09] MDAC Version is less or MDAC not installed
[02/18/04,03:45:09] StopDarwinService(): Darwin Service was already stopped
[02/18/04,03:45:09] Trying to load msi.dll
[02/18/04,03:45:09] Loading: C:\WINNT\system32\msi.dll
[02/18/04,03:45:09] Full UI
[02/18/04,03:45:09] Calling MsiInstallProduct() with commandline: REBOOT=ReallySuppress MDAC_NOT_PRESENT=1
[02/18/04,03:50:13] MsiInstallProduct() returned 1603
[02/18/04,03:50:13]
[MsiInstallProduct]
ReturnCode=1603
[02/18/04,03:50:13] Preparing Dialog
[02/18/04,03:50:13] Message: Microsoft .NET Framework Setup failed. If this problem continues, contact Product Support Services.
[02/18/04,03:50:15] Install.exe returning 1603
[02/18/04,03:50:15]
[Install.exe]
ReturnCode=1603
Enig idee iemand?
Ik kom er echt niet meer uit...
  • dominic
  • Laatst online: 21-08 19:07
dominic
will code for food
Ik denk dat MDAC de boosdoener is: [02/18/04,03:45:09] MDAC Version is less or MDAC not installed
Download my music on SoundCloud
  • razmir
razmir
dominic schreef op 18 februari 2004 @ 12:19:
Hmm ff kijken of ik die kan installeren dan..
tnx iig
error 1603 is dat ie geen rechten op een folder heeft volgens technet
  • razmir
razmir
Verwijderd schreef op 18 februari 2004 @ 12:21:
Mja.. maar dat lijkt me sterk als ik inlog met administrator account..
  • razmir
razmir
hij doet het nog steeds niet met die MDAC..
enige verschil is nu dattie zegt
[02/18/04,04:35:08] Checking MDAC Version
[02/18/04,04:35:08] Looking for 2.70.7713.0
[02/18/04,04:35:08] Found MDAC Version: 2.80.1022.3
[02/18/04,04:35:08] MDAC Version OK
Iemand anders nog een idee?
  • St-Bun
  • Laatst online: 09:25
Ik heb zelf ook es tijden met de installatie van .net gezeten. Ik kreeg ook telkens de algemene foutmelding 1603. Na van alles en nog wat geprobeerd te hebben, heb ik uiteindelijk maar windows opnieuw geinstalleerd. :(
Wat je nog kan proberen is eerst es het framework 1.0 te installeren.
O dus
  • razmir
razmir
St-Bun schreef op 18 februari 2004 @ 12:56:
Net geprobeert 1.0 te installeren.. maar doet ook niets..
stomme .NET :(
  • sanfranjake
sanfranjake
Computers can do that?
(overleden)
Is die laatste MDAC (en natuurlijk alle andere kritische) Windows-patches aanwezig op de pc ? Als je de Setup-files tijdens installatie via internet update best kans dat die specifieke versie zoekt.
Mijn spoorwegfotografie
  • razmir
razmir
sanfranjake schreef op 18 februari 2004 @ 20:08:
net gedaan maar wil ook niet helpen..
iemand anders nog ideetje? :)
