Ik heb even gezocht op google en misschien wat gevonden:
http://www.ultrasoftware.net/archive/detail.asp?id=10456
Even naar beneden scrollen en dan zie je:
Good-looking calculating JSP-page from Excel.
Separate JavaBean with full source. 140 Excel-functions supported. No Excel needed on server. No Excel needed for the users of the JSP-pages. No programming, let the domain expert create the code. Solve your problem using Microsoft Excel and convert it to a JavaBean and a JSP-page.
Easy updating: fix spreadsheet and generate again. Use it for expense report, survey, order forms, reservation forms, employment application, financial advisor, ROI-calculator, engineering.
No Risk! 30 day money back guarantee. ExcelEverywhere will save you time and money. It will make your customers happier thru increased service and better quality.
* The domain expert can generate code to be used inside software systems, no need to explain how the calculations are done to a programmer.
* 10-fold increase in productivity. The enormous gain in productivity comes from being able to use Excel for developing the calculations and from having access to 140 built-in functions of Excel.
* Improved quality due to much easier testing in Excel.
* Automatic reformatting of numbers on webpage using JavaScript.
* Supports checkboxes and dropdown lists.
* Easy update of webpage, just update the spreadsheet and run ExcelEverywhere.
* Can be used by in-house personnel, no programming or advanced web skills needed. No need paying external consultants.
* Easy of use. No programming experience is needed.
* Exactly mimic the behavior of Microsoft Excel.
* Covers 140 functions of Excel. Currently all but a few advanced financial and statistical functions are supported.
* Many different target environments supported: Windows, Linux, UNIX, Macintosh, embedded systems like set-top boxes.
The resulting webpages can be run within all browsers launched the last 2-3 years. v.2.3.11
Misschien een idee?
Rafe: niet zo slijmen he.
