[apollon] problemen met configure...
  • 46 views sinds 30-01-2008
  • decramy
  • Laatst online: 08-09 17:46
decramy
root@birdie:~#
29
30
root@donald:~/apollon-0.9.2# ./configure
[.... veel onzinige shit ....]
checking if Qt compiles without flags... yes
checking for moc... /usr/share/qt3/bin/moc
checking for uic... /usr/share/qt3/bin/uic
checking whether uic supports -L ... yes
checking whether uic supports -nounload ... yes
checking if Qt needs -ljpeg... no
checking for rpath... yes
checking for KDE... configure: error:
in the prefix, you've chosen, are no KDE headers installed. This will fail.
So, check this please and use another prefix!
donald:~/apollon-0.9.2# apt-get install kdelibs kdelibs3 kdelibs4
Reading Package Lists... Done
Building Dependency Tree... Done
kdelibs is already the newest version.
kdelibs4 is already the newest version.
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
  kdelibs-bin: Conflicts: kdelibs3 (< 4:3.0.0) but 4:2.2.2-13.woody.8 is to be installed
  kdelibs-data: Conflicts: kdelibs3 (< 4:3.0.0) but 4:2.2.2-13.woody.8 is to be installed
  kdelibs4: Conflicts: kdelibs3 (< 4:3.0.0) but 4:2.2.2-13.woody.8 is to be installed
E: Broken packages
Me config.log @ http://playground.decramy.net/config.log
Wat doe ik in ***naam fout? Wat zie ik over het hoofd?
20*375Wp met Enphase IQ7+ micro's | Stiebel Eltron HGE Water/Water WP 9kW | Tesla M3, powered by SmartEVSE | Servertje @ www.coloclue.net
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
configure: 27337: /usr/local/kde/include/ksharedptr.h
Dat is de file waarop gecontrolleerd wordt, je mist dus de kdelibs-dev als je deze installeerd moet het beter gaan lijkt me.
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Wilke
  • Laatst online: 22:48
decramy schreef op 16 februari 2004 @ 18:33:
Wat doe ik [..] fout? Wat zie ik over het hoofd?
Wat je fout doet: Lezen (of beter: het 'niet lezen'). Wat je over het hoofd ziet: een zeer duidelijke errormessage die precies zegt wat het probleem is:
Dus of je hebt uberhaupt geen KDE geinstalleerd staan (wat blijkbaar een dep. is van Apollon, wat dat ook is), of je moet aangeven waar het geinstalleerd is (--prefix=/pad/naar/kde/basis/dir).
  • decramy
decramy
root@birdie:~#
donald:~/apollon-0.9.2# apt-get install kdelibs-dev
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
  kdelibs-dev: Depends: kdelibs3 (= 4:2.2.2-13.woody.8) but it is not going to be installed
               Depends: kdelibs3-bin (= 4:2.2.2-13.woody.8) but it is not going to be installed
               Depends: libarts-dev (= 4:2.2.2-13.woody.8) but it is not going to be installed
               Depends: libkmid-dev (= 4:2.2.2-13.woody.8) but it is not going to be installed
               Depends: uic (>= 3:2.3.1-1) or
                        kde-designer but it is not installable
E: Broken packages
--purge werkt ook niet...
ik had hetzelfde probleem
heb ik volgens mij gefixed door "apt-get install kde-devel" te doen
  • decramy
decramy
root@birdie:~#
Tnx!
Maar nu wil ie nog steeds niet...
Ik heb niets aan de .tar gedaan, alleen uitgepakt en meteen make uitgevoerd...
29
30
31
32
33
34
35
36
37
38
39
40
donald:~/apollon-dist/apollon-0.9.2# make
make  all-recursive
make[1]: Entering directory `/root/apollon-dist/apollon-0.9.2'
Making all in apollon
make[2]: Entering directory `/root/apollon-dist/apollon-0.9.2/apollon'
Making all in images
make[3]: Entering directory `/root/apollon-dist/apollon-0.9.2/apollon/images'
make[3]: Nothing to be done for `all'.
make[3]: Leaving directory `/root/apollon-dist/apollon-0.9.2/apollon/images'
Making all in libapollon
make[3]: Entering directory `/root/apollon-dist/apollon-0.9.2/apollon/libapollon'
make[4]: Entering directory `/root/apollon-dist/apollon-0.9.2/apollon/libapollon'
make[4]: Nothing to be done for `all-am'.
make[4]: Leaving directory `/root/apollon-dist/apollon-0.9.2/apollon/libapollon'
make[3]: Leaving directory `/root/apollon-dist/apollon-0.9.2/apollon/libapollon'
make[3]: Entering directory `/root/apollon-dist/apollon-0.9.2/apollon'
if g++ -DHAVE_CONFIG_H -I. -I. -I.. -I/usr/include/kde -I/usr/share/qt3/include -I/usr/X11R6/include  -I../apollon/libapollon  -DQT_THREAD_SUPPORT  -D_REENTRANT -g -Wnon-virtual-dtor -Wno-long-long -Wundef -Wall -pedantic -W -Wpointer-arith -Wwrite-strings -ansi -D_XOPEN_SOURCE=500 -D_BSD_SOURCE -Wcast-align -Wconversion -Wchar-subscripts -O2 -Wformat-security -Wmissing-format-attribute -fno-exceptions -fno-check-new -fno-common  -MT apollon.o -MD -MP -MF ".deps/apollon.Tpo" \
  -c -o apollon.o `test -f 'apollon.cpp' || echo './'`apollon.cpp; \
then mv ".deps/apollon.Tpo" ".deps/apollon.Po"; \
else rm -f ".deps/apollon.Tpo"; exit 1; \
fi
apollon.cpp:41:29: libgift/libgift.h: No such file or directory
apollon.cpp:42:26: libgift/conf.h: No such file or directory
apollon.cpp: In constructor `ApollonApp::ApollonApp(QWidget*, const char*)':
apollon.cpp:89: error: `Config' undeclared (first use this function)
apollon.cpp:89: error: (Each undeclared identifier is reported only once for
   each function it appears in.)
apollon.cpp:89: error: `config' undeclared (first use this function)
apollon.cpp:89: error: `config_new_ex' undeclared (first use this function)
apollon.cpp:91: error: `config_get_str' undeclared (first use this function)
apollon.cpp:92: error: `config_get_int' undeclared (first use this function)
apollon.cpp:95: error: `config_free' undeclared (first use this function)
make[3]: *** [apollon.o] Error 1
make[3]: Leaving directory `/root/apollon-dist/apollon-0.9.2/apollon'
make[2]: *** [all-recursive] Error 1
make[2]: Leaving directory `/root/apollon-dist/apollon-0.9.2/apollon'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/root/apollon-dist/apollon-0.9.2'
make: *** [all] Error 2
  • smokalot
  • Laatst online: 15-01 22:00
smokalot
titel onder
Denk je dat dat hele configure-script voor het leuk is ofzo?
Waarom niet meteen make install doen dan ;)
[serieus]
./configure is nodig, die creeert een Makefile, en die kan make dan gebruiken om te weten wat ie precies moet doen.
[/serieus]
It sounds like it could be either bad hardware or software
  • decramy
decramy
root@birdie:~#
smokalot schreef op 17 februari 2004 @ 21:15:
[serieus]
[/serieus]
:X 8)7 |:(
doh, die `configure` komt ie goed doorheen...
dus ik doe zoals aangegeven in INSTALL `make`
en de output staat hierboven...
* decramy is dom, maar niet zo dom
[ Voor 4% gewijzigd door decramy op 17-02-2004 21:32 ]
........apollon.cpp:41:29: libgift/libgift.h: No such file or directory...............
Je hebt giFT niet geinstalleerd.
  • decramy
decramy
root@birdie:~#
donald:~/apollon-0.9.2# apt-get install gift
gift is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
tuurlijk wel...
Maar die dir apollon/libgift bestaat ook niet...
mm, `apt-get install libgift-dev libgiftproto-dev` will do the trick...
  • decramy
decramy
root@birdie:~#
ok, make en make install zijn nu suc6vol doorgelopen...
in de map apollon staat ook een executable 'apollon'. maar deze staat nog niet in /usr/local/bin (ja, ik heb make install gedaan)
  • Wilke
Nu gaat dit topic echt dicht. We kunnen je niet bij elke stap aan het handje blijven houden. Afhankelijk van de prefix zou hij ook geinstalleerd kunnen zijn in /usr/bin of ergens in /opt. Dit soort dingetjes zijn absoluut zelf wel uit te vinden.
