hoe smartctl info lezen ?
  • DDX
  • Laatst online: 23:44
linux systeem
3ware controller gaf iedere dag deze errors aan :
22:23:04 Sat 14-Feb-2004:WARNING: SMART Threshold Exceeded condition detected on port 3 on controller ID:1. It is recommend you re
place this drive immediately and rebuild unit if needed. (0xf)
smartctl -a geeft op deze drive :
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
=== START OF INFORMATION SECTION ===
Device Model:     WDC WD1800BB-00DAA0
Serial Number:    WD-GAATJENIKSAAN
Firmware Version: 70.13G70
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   6
ATA Standard is:  Exact ATA specification draft version not indicated
Local Time is:    Mon Feb 16 13:57:29 2004 CET
SMART support is: Available - device has SMART capability.
SMART support is: Enabled
=== START OF READ SMART DATA SECTION ===
SMART overall-health self-assessment test result: PASSED
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity was
                                        completed without error.
                                        Auto Offline Data Collection: Enabled.
Self-test execution status:      (   0) The previous self-test routine completed
                                        without error or no self-test has ever
                                        been run.
Total time to complete Offline
data collection:                 (6519) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        Auto Offline data collection on/off support.
                                        Suspend Offline collection upon new
                                        command.
                                        Offline surface scan supported.
                                        Self-test supported.
                                        Conveyance Self-test supported.
                                        Selective Self-test supported.
SMART capabilities:            (0x0003) Saves SMART data before entering
                                        power-saving mode.
                                        Supports SMART auto save timer.
Error logging capability:        (0x01) Error logging supported.
                                        No General Purpose Logging support.
Short self-test routine
recommended polling time:        (   2) minutes.
Extended self-test routine
recommended polling time:        (  83) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SMART Attributes Data Structure revision number: 16
Vendor Specific SMART Attributes with Thresholds:
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0007   253   253   021    Pre-fail  Always       -       5150
  4 Start_Stop_Count        0x0032   100   100   040    Old_age   Always       -       2
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x000b   200   200   051    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   090   090   000    Old_age   Always       -       7655
 10 Spin_Retry_Count        0x0013   100   100   051    Pre-fail  Always       -       0
 11 Calibration_Retry_Count 0x0013   100   100   051    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0012   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0012   200   200   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x000a   200   200   000    Old_age   Always       -       0
200 Multi_Zone_Error_Rate   0x0009   200   200   051    Pre-fail  Offline      -       0
SMART Error Log Version: 1
No Errors Logged
SMART Self-test log structure revision number 1
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%         9         -
# 2  Extended offline    Completed without error       00%         9         -
selftest enzo zijn dus gewoon gelukt
alleen bij results staat er bij lifetime(hours): 9
als ik het simpel lees zou dit dus betekenen dat deze disk over 9 uur dood is (lijkt me stug)
maar waarop is dit dan gebasseerd ? (testen ed zijn ok?)
andere (zelfde type) disk
# 1  Short offline       Completed without error       00%      1085         -
deze heeft dus 1085 uur (te gaan?)
draait al 7600 uur, dus waarom zou die niet nog eens 7600 uur draaien ?
https://www.strava.com/athletes/2323035
