MSX Game Reader productie opgestart door ASCII
  • 137 views sinds 30-01-2008
  • Eindbaas
  • Laatst online: 25-09 15:43
Heb je ook altijd al je originele MSX Cartridges op je pc willen spelen? Dat kan nu met de Game Reader:
Met Babelfish vertaald stukje over de Game Reader:
Plan/development: Corporation ASCII, MSX association production: Corporation アスキーソリューションズ sale: Edge corporation < Sale day > 2004 March 16th < Specification > MSXPLAYer private USB corresponding MSX game cartridge the leader (Windows edition as for) USB1.1/2.0 correspondence and USB B connector terminal power source, the supply 1 slot, as for the formal logographic entering USB cable of the manual sliding cover attaching power supply indication light and the access lamp attaching MSX game leader, it does not belong from the USB cable. "USB B connector? The USB A connector "cable is separate and necessary. The instruction manual and the like does not belong. As for method of using, please read "the MSX magazine permanent standing matter 2" of December day sale. SCC sound source you verify the operation of the game cartridge of コナミ of the attachment. If two it purchases, utilization in 2 slot specifications is possible, (the slot 1, the slot 2 to change through the) USB hub with the switch, has not guaranteed operation. Directly, connecting the knitting machine and the personal computer, please use. * As for size and weight of the substance, and the package there are times when it is modified.
The MSX game leader is the peripheral device in order to use the MSX game cartridge with the Windows personal computer. The MSX game cartridge purchasing this product, you cannot play the one which is not having. - The Windows machine which loads the USB connector (correspondence OS: Windows98/Windows98SE/Windows Me/Windows2000/Windows XP) is necessary. With Linux machine and Mac OS it does not operate. - As for the driver in order to make the Windows machine recognize as a software, and a USB peripheral device in order to operate the MSX game cartridge it is not included in this commodity. As a software, MSXPLAYer which belongs to "the MSX magazine permanent standing matter 2" of December 3rd sale becomes necessary. In addition the driver becomes download from the Web page. - Those where it is corresponding are only the MSX game cartridge. The FM sound source and the extended cartridge of modem and the like are not corresponding. In addition, it is not something which operation of all MSX game cartridges preservation is proven. - When condition of the cartridge is bad, there are times when it does not operate normally.
Afbeeldingslocatie: http://zeepje.tweakdsl.nl/zu_01.jpg
Zo te zien is dit een USB device waar je gewoon een MSX cartridge in kunt doen en spelen maar, nou ja er zal nog wel een soort van emulatie software geïnstalleerd moeten worden denk ik...
Van www.msx.org:
Today, ASCII stopped the possibility to pre-order both the MSX Game Reader and the limited edition 20th anniversary MSXPC. The sample version(s) of MSX Game Reader have been tested and approved, and are now in production. In a while (since there were many orders, this could take a while) the people who ordered it can enjoy their MSX Cartridges on PC.
The MSXPC sample is still to be approved, after which production will start. At the same time, ASCII started a special MSX action on their frontpage. Amongst 500 people who order the latest MSX Magazine, a special edition of the Magazine and a magnetic sticker are distributed.
Een ander verhaal is dus de MSXPC, deze moet nog goedgekeurd voor produktie worden:
Met Babelfish vertaald stukje over de MSXPC:
The keyboard one somatotype personal computer which 髣 髴 with makes MSX of the past years do. Loading Celeron 2.4GHz onto liberal CPU even with business use. Of course, also "MSXPLAYer" operates comfortably. Although being one somatotype, it equips also IEEE1394, USB2.0, LAN, serial, parallel and レガシーインターフェース. The place is not taken as a keyboard one somatotype PC, the monitor just can be connected, it works as the personal computer. Being small-sized, because you do not take the place, you recommend as a 2nd personal computer. Just the ultimate all-in-one personal computer! In the keyboard, スグレモノ where everything such as motherboard and CPU, HDD and optical drive enters! Especially being the recommendation is key touch. It surpasses to also the Th 00 kP 0 d series which is called the highest also the striking feeling which is not inferior. Using also CPU power and the like with business, sufficiently, you can use. As for the detailed specifications the keyboard one somatotype personal computer which 髣 髴 with makes MSX of this past years do. Loading Celeron 2.4GHz onto liberal CPU even with business use. Of course, also "MSXPLAYer" operates comfortably. Although being one somatotype, it equips also レガシーインターフェース. Not to take the place as a keyboard one somatotype PC, as a 2nd personal computer the recommendation
Afbeeldingslocatie: http://zeepje.tweakdsl.nl/zu_02.jpg
Zie hier voor de specs van beide apparaten: https://ssl.ascii-store.com/c/msx_syousai
En hier is de ASCII shop: https://ssl.ascii-store.com/corner/msx.cgi
[ Voor 67% gewijzigd door Eindbaas op 13-02-2004 15:23 ]
  • Sa1
  • Laatst online: 11-10 19:42
Sa1
http://zeepje.tweakdsl.nl/zu_01.jpg k heb het plaatje even voor je gemirrord. andere nu ook :) http://zeepje.tweakdsl.nl/zu_02.jpg
[ Voor 22% gewijzigd door Sa1 op 13-02-2004 15:11 ]
  • Eindbaas
Sa1 schreef op 13 februari 2004 @ 15:09:
Dank je :)
zou je die andere ook kunnen doen?
Edit: wederom Dank!
[ Voor 5% gewijzigd door Eindbaas op 13-02-2004 15:11 ]
  • Eindbaas
Kom kom, er zitten hier genoeg MSX liefhebbers om hier wat meer interesse in te tonen ;)
  • Yngwie-
  • Laatst online: 15-03 17:01
Yngwie-
Murphy was an optimist
Altijd leuk om inderdaad te lezen dat er nog ontwikkeling in de MSX wereld zit :) Een aantal MSX games behoren nog altijd tot mijn all time favorieten (Ys, Xak, Metal Gear, SD Snatcher, Nemesis/Salamander serie en ga zo maar door :D ) Die Game Reader lijkt me inderdaad wel geinig. Alleen zo te zien zit er 1 slot in? Zou betekenen, dat bepaalde Konami combinaties tussen 2 cartridges niet gaat werken. Bijvoorbeeld Salamander en Nemesis 2, waarbij er een extra stage bijkomt waar je Vernom kunt verslaan :)
Verder die MSXPC. Tja, wel leuk, maar het is mijns inziens niet veel meer dan een PC waar een emulator op draait. Heb ik nu ook met NLMSX, dat eigenlijk perfect draait. Dus als je het goed wil doen, moet je gewoon een echte MSX hebben staan ;)
Hele tijd terug is er ook eens sprake geweest (misschien nog steeds, hou het eerlijk gezegd niet bij momenteel) van een on-chip MSX. Oftewel, 1 chippie, waar de complete MSX functionaliteit e.d. in zit, alsmede evt. ondersteuning voor HD's en andere randapparatuur. Maar wat daar nu nog van terecht gaat komen, durf ik in ieder geval niet te zeggen.
[ Voor 8% gewijzigd door Yngwie- op 15-02-2004 12:45 ]
  • Eindbaas
De MSXPC zal naar alle waarschijnlijkheid draaien met de MSXPLAYER emulator. Deze is gebaseerd op de fMSX emulator.
De Game Reader is voor mij het meest interessant, nou ja de leukste gadget om het zomaar te noemen :)
  • Croga
  • Laatst online: 11:26
Croga
The Unreasonable Man
Sinds fMSX geport is naar de Xbox hoeft dit voor mij eerlijk gezegd niet meer zo.... Die MSX spellen hoor je gewoon op de TV te spelen, net als met mijn VG8010 vroeger! uren lang Gauntlet vanaf cassette :)
Het enige nadeel blijft nog altijd dat de beste spellen alleen in het Japans uit zijn gekomen :'( Daiva is toch erg lastig spelen als je niet weet wat al die berichten tussendoor eigenlijk te vertellen hebben....
  • Eindbaas
Croga schreef op 20 februari 2004 @ 14:05:
Xak serie, Ys serie, Dragonslayer 6, Sorcerian, The Snatcher, SD Snatcher en Solid Snake bijvoorbeeld al eens in het engels gespeeld? Er wordt niet stilgezeten. Zo wordt er nu bijv. gewerkt aan een vertaling van Illusion City :)
Dat het niet op een svga monitor gespeeld moet worden ben ik helemaal met je eens!
[ Voor 10% gewijzigd door Eindbaas op 20-02-2004 19:54 ]
