Wat voor mobo is dit?
  • 60 views sinds 30-01-2008
Ik heb op dit forum en in google gezocht naar wat voor moederbord ik zou kunnen hebben, maar nergens iets kunnen vinden. daarom hoop ik dat jullie weten welk moederbord dit is:
Part number VG-31
Micro ATX form factor
Socket 478 architecture
Supports Intel Pentium 4 processor up to 2.53 GHz
Supports Intel Celeron processor up to 1.9 GHz
400/533 MHz front side bus
Intel i845G Northbridge, ICH4 Southbridge
Northbridge: Intel i845G graphics and memory controller hub
supports up to 512 MB non-ECC DDR-DIMM modules for a maximum of 1.0 GB system
memory
Intel Extreme Graphics with Direct AGP
Integrated graphics controller allocates 1 or 8 MB system memory at boot
Additional graphics memory is dynamically allocated based on need. Systems with
less than 256 MB may allocate up to 32 MB. Systems with 256 MB or more may
allocate up to 64 MB.
(48 MB with Intel Exteme Graphics Driver V11.0 or less)
Southbridge: Intel I/O Contoller Hub 4
Integrated AC97 audio interface
USB 2.0 controller supports 6 USB ports
Dual ATA-100 disk drive controllers support UDMA 100/66/33
Chipset supports up to 6 bus mastering PCI channels
Memory
2 DDR-DIMM slots for PC 1600 or PC 2100 DDR-DIMMS
Maximum module size is 512 MB
Maximum total memory is 1.0 GB
Supports non-ECC DIMMS
2 IDE connectors
Supports 2 IDE devices on each connector.
Supports UDMA 100/66/33 - requires an 40 pin/80 conductor cable for UDMA 66 and
100 disk drives
1 floppy disk connector
3 PCI Slots
Back panel connectors
PS/2 keyboard (purple)
PS/2 mouse (green)
4 USB 2.0 ports
1 RJ45 networking port (on later revisions)
1 parallel port
1 serial port
1 VGA connector
Microphone jack (pink)
Line in jack (light blue) for powered speakers only
Line out jack (lime)
Onboard connectors
ATX power connector
ATX +12v power connector
CPU fan connector
System fan connector (also known as duct or chassis fan)
Jumpers points to clear CMOS
Optical drive audio input
Auxiliary audio input
Front panel power and LED connectors
1 USB connector supporting 2 additional USB ports on front panel
Front panel audio connector
System supports ACPI power saving modes
Verder, als het enige waarde heeft, vond ik dit nog op mijn moederbord: D3307, FIC P/N 53-80534-13
Dit moederbord komt uit de fantastische HP pavilion 423.nl
  • Hoyden
  • Registratie: December 1999
  • Laatst online: 20:35
Lees ff dit topic door, dan weet je wat meer:
Weet iemand welk type/merk mobo dit is?
En dan met name de onderste post. :)
OEM Built http://www.fic.com.tw/ bordje ;)
  • 3dfx
Dan zou ik je browser ff op 'online werken' zetten :P, dit vond ik nl. direct met google (trefwoorden 'VG-31 mainboard'):
http://www.fic.com.tw/pro...d_detail.aspx?model_id=80
Een Fic dus
  • dion_b
  • Laatst online: 23:36
dion_b
say Baah
PMG FAQ
Maar los daarvan is dit gewoon een oefening in de info lezen die je hier gepost hebt- FIC VG-31 idd :z
Oslik, blyat! Oslik!
