[Sendmail] stat: data format error
  • 112 views sinds 30-01-2008
  • Rembrand20
  • Laatst online: 22-09-2023
Beste tweakers,
Ik heb sinds kort een probleempje met mijn mail server.
Mijn mailserver is een redhat 9 bak met sendmail 8.12.*.
Als ik een mailje over deze machine stuur is er niets aan de hand.
Maar wil ik lokaal een mailtje sturen krijg ik de volgende fout melding.
Feb 13 00:11:36 *******sendmail[24896]: i1CNBabs024896: to=r***@****.net, ctladdr=root (0/0), delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30043, relay=[127.0.0.1] [127.0.0.1], dsn=5.6.0, stat=Data format error
Feb 13 00:11:36 ****** sendmail[24896]: i1CNBabs024896: i1CNBabt024896: DSN: Data format error
Feb 13 00:11:36 *****sendmail[24898]: i1CNBagP024898: ruleset=check_rcpt, arg1=<>, relay=localhost.localdomain [127.0.0.1], reject=553 5.0.0 <>... User address required
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabt024896: to=root, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=31072, relay=[127.0.0.1], dsn=5.0.0, stat=User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagP024898: from=<>, size=1072, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabt024896: i1CNBabu024896: return to sender: User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagR024898: ruleset=check_rcpt, arg1=<>, relay=localhost.localdomain [127.0.0.1], reject=553 5.0.0 <>... User address required
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabu024896: to=postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=32096, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagR024898: from=<>, size=2096, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabt024896: Losing ./qfi1CNBabt024896: savemail panic
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabt024896: SYSERR(root): savemail: cannot save rejected email anywhere
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabs024896: i1CNBabv024896: postmaster notify: Data format error
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagT024898: ruleset=check_rcpt, arg1=<>, relay=localhost.localdomain [127.0.0.1], reject=553 5.0.0 <>... User address required
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabv024896: to=Postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagT024898: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabv024896: i1CNBabw024896: return to sender: User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagV024898: ruleset=check_rcpt, arg1=<>, relay=localhost.localdomain [127.0.0.1], reject=553 5.0.0 <>... User address required
Feb 13 00:11:36 ***-***-*** sendmail[24896]: i1CNBabw024896: to=postmaster, delay=00:00:00, xdelay=00:00:00, mailer=relay, pri=30000, relay=[127.0.0.1] [127.0.0.1], dsn=5.0.0, stat=User unknown
Feb 13 00:11:36 ***-***-*** sendmail[24898]: i1CNBagV024898: from=<>, size=0, class=0, nrcpts=0, proto=ESMTP, daemon=MTA, relay=localhost.localdomain [127.0.0.1]
Heeft iemand enige idee wat het kan zijn.
Model 3 LR AWD Solid Black / Black / Aero / Trekhaak - Bestelling 2-10 Leaseplan, 4-10 Tesla, RN 22-09, Nieuwe RN 25-11, VIN Yes, leverdatum: ?/?/19(?)
  • Whizzer
  • Laatst online: 31-08 13:19
Whizzer
Flappie!
wat dacht je hier van: "User unknown"....
Ik ben geweldig.. en bescheiden! En dat siert me...
  • Rembrand20
Ja en dat is dus niet het geval...
Als ik een mailtje naar het zelfde adres stuur komt het gewoon aan...
  • Rembrand20
Heb het opgelost was iets met dns naampje
