Op zoek naar een handige oplossing voor GPS in de auto, gecombineerd met een koppeling naar onze database die PALM software ondersteund (zodat je snel een route naar een klant kunt plannen) maar niet te veel laders, snoertjes en andere ellende in de auto willen hebben kwam ik de GPS module voor de Nokia 9200 tegen. Op zich een perfecte oplossing, zeker in combinatie met de TomTom software. Maar wat schetst mijn verbasing nadat ik kwijlend door de FAQ aan het lezen was........ Lees zelf de laatste regel maar:
bron
1. What phones the Nokia GPS Module is compatible with?
The Nokia GPS Module is compatible with the Nokia 9210 and Nokia 9210i.
Back to top >>
2. What is included in the sales package of the Nokia GPS Module?
The sales package consists of: a Nokia GPS Module LAM-1, 2 CDs containing TomTom CityMaps and RoutePlanner, an external GPS antenna, an installation leaflet, and a carrying pouch. For the map installer the following Windows operating systems are supported: Win98, Me, Win2000 and XP. Note: NT4 is not officially supported.
Back to top >>
3. In what countries will it be available
In Europe the Nokia GPS Module will be sold in the same countries as the Nokia 9210i Communicator. Please note that language support is limited due to TomTom applications (which use Palmtop). Supported languages: English, German, French, Italian, Spanish, Finnish and Dutch.
Back to top >>
4. Which countries does the map cover?
TomTom RoutePlanner covers both Western and Eastern Europe. TomTom CityMaps cover more than 100,000 cities in Austria, Belgium, Denmark, France, Germany, Great Britain, Italy, Luxembourg, The Netherlands, Portugal, Spain, Sweden and Switzerland.
Back to top >>
5. Can I get free updates of my existing applications and maps for the Nokia GPS Module?
The Nokia GPS Module's applications are licensed from Palmtop B.V. Therefore free updates, for example map additions, are not available from Nokia. However you can contact TomTom directly for any available software updates.
Back to top >>
6. How does the Nokia GPS Module affect my Nokia Communicator's operating time?
Power consumption of the GPS Module is 50 mA in active mode and 1 mA when idle. In practice, GPS can be used in tracking mode with full display brightness for more than 5 hours without additional charging.
Back to top >>
7. Do these applications have voice-assisted routing?
No.
Back to top >>
8. Can I use my own landmarks when planning a route?
Yes. Memorize your location in RoutePlanner using the Find-Memorize cursor and store a quick key for 10 locations. You can use these quick keys (0-9) in route planning as either departures or destinations. In CityMaps you can store your own location as an overlay and, when planning a route, pick the overlay for your route point.
Back to top >>
9. Can I plan routes without the Nokia GPS Module?
Yes. You can view maps and plan routes even when the Nokia GPS Module is not attached, or if you have disabled the GPS from the GPS menu. In other words, no GPS coverage is needed for this function.
Back to top >>
10. Why can't the Nokia GPS Module accessory be used with the Advanced HF Car Kit optimized for the Nokia 9200 Communicator Series?
In order to utilize the functionalities of the attachable Nokia GPS module, the cover of the Nokia 9200 Communicator needs to be open. This is not possible when the Nokia Communicator is placed in the Nokia Car Kit optimized for the Nokia 9200 Communicator Series. Nokia recommends the Nokia Communicator be kept in the car holder while driving. For safety reasons, Nokia does not recommend using the Nokia GPS Module LAM-1 when driving a car.
Back to top >>
8)7 8)7 8)7 8)7
Raar heh, denk ff na.
dit is de manier om eventueele dingen (rechtzaken) af te wimpelen
-Radiostralingen, elektronica.
-ABS, cruisecontrol, motormanagement
Nee vooral; botsingen omdat je op dat ding zat te kijken. Storen doet het niet echt, het gaat erom dat je je aandacht op de weg houdt :)
Verwijderd schreef op 11 februari 2004 @ 17:52:
Jij kijkt wel vaker naar een GPS module in de auto ;)
Verwijderd schreef op 11 februari 2004 @ 17:56:
Ja :P Et gaat natuurlijk om kijken naar et scherm enz eik0l :P
  • Sick Nick
  • Laatst online: 31-07 09:24
Sick Nick
Drop the top!
Verwijderd schreef op 11 februari 2004 @ 17:57:
Oooow, dat werkt wel goed ja. Daar hoef ik niet echt voor opzij te kijken, voor die module wel. Die zit onder het dashboard, kan me voorstellen dat dat niet echt veilig is om daar naar te kijken tijden het rijden :+
