Sorry voor de zeer onduidelijke titel...
Ik ben bezig met het installeren van Exchange nog een keer maar nu krijg ik de volgende foutmeldingen als ik DCdiag en netdiag draai:
DCDiag
Doing initial required tests
Testing server: Thuis\HADES
Starting test: Connectivity
The host 8744a839-942d-4b53-a5ff-3d3611a21804._msdcs.KLOP.Intranet could not be resolved to an
IP address. Check the DNS server, DHCP, server name, etc
Although the Guid DNS name
(8744a839-942d-4b53-a5ff-3d3611a21804._msdcs.KLOP.Intranet) couldn't
be resolved, the server name (hades.KLOP.Intranet) resolved to the IP
address (192.168.0.2) and was pingable. Check that the IP address is
registered correctly with the DNS server.
......................... HADES failed test Connectivity
NETDIAG
DNS test . . . . . . . . . . . . . : Failed
[WARNING] The DNS entries for this DC are not registered correctly on DNS server '192.168.0.2'. Please wait for 30 minutes for DNS server replication.
[FATAL] No DNS servers have the DNS records for this DC registered.
DNS event vieuwer:
Event Type: Error
Event Source: DNS
Event Category: None
Event ID: 4011
Date: 10-2-2004
Time: 16:47:28
User: N/A
Computer: HADES
Description:
The DNS server was unable to add or write an update of domain name klop in zone Klop.Intranet to the Active Directory. Check that the Active Directory is functioning properly and add or update this domain name using the DNS console. The extended error debug information (which may be empty) is "0000208D: NameErr: DSID-031001C6, problem 2001 (NO_OBJECT), data 0, best match of:
'CN=MicrosoftDNS,CN=System,DC=KLOP,DC=Intranet'". The event data contains the error.
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
Data:
0000: 20 00 00 00 ...
De laatste melding staat in de event-viewer van de DNS. Naar mijn weten heb ik de DNS goed ingesteld. Wie kan mij meer info geven over deze foutmelding?? Zolang deze foutmeling er is zal er namelijk denk ik geen goede exchange kunnen draaien
Ik heb trouwens een active directory draaien op dezelfde PC...
DCDiag
NETDIAG
DNS event vieuwer:
Event Type: Error
Event Source: DNS
Event ID: 4011
Date: 10-2-2004
Time: 16:47:28
User: N/A
Computer: HADES
Description:
Data:
SmartDoDo: Ach, afhankelijk van je smaak kan het best een lekker geil ding zijn :P
You never had a date you couldn't inflate
