Belinea 102015 Aanschaffen
Hi Guys, ben voornemens een 20 inch LCD aan te schaffen en loop te twijfelen over de Belinea 102015 specs zien er goed uit, maar kan nergens reviews vinden iemand een mening hierover. Ik game veel: strategy: generals, Age series, en First Person Shooters: CS, etc. Responsetijd van Rise 15 en Fall 10 lijkt me ruim voldoende voor game snelheid, maar heb er weinig verstand van verder.
Alvast bedankt voor de reacties.
Panel characteristics
screen size in inch / cm 20.1/51.5
viewable screen size in inch / cm 20.1/51.5
max. picture size (w x h) in mm 408x306
recommended resolution 1600x1200
pixel pitch in mm 0.255
active matrix, TFT yes
displayable colors (max.) 16.7 m
brightness in cd/qm: typ. (min.) 250
contrast ratio: typ. (min.) 600:1
horizontal viewing angle : typ. (min.) 170°
vertical viewing angle : typ. (min.) 170°
coating Anti Glare
response time: rise / fall in ms (typ.) 15/10
electrical data (LCD)
horizontal frequency in kHz 30-82
vertical fequency in Hz 50-75
bandwidth in MHz 162
input voltage 110-230V, 50-60Hz yes
power consumption in Watt, On/Stand-by/Suspend/Off-Mode 90/3
input signal (VGA) analog / digital yes/yes
output audio amplifier 2 x 2 watt
features
factory/user defined modes 26/6
OSD yes
integrated speaker yes
power Supply (internal/external) internal
tilt back / forth 20°/5°
swivel right / left 0°/0°
OSD (LCD)
brightness / contrast yes/yes
H / V position yes/yes
automatic picture calibration yes
fine tuning / focus yes/no
{17;color temperature}} / color calibration yes/yes
selection at lower resolutions (1:1 or full screen) no/yes
zoom yes
frequency information yes
recall / video signal selection yes/yes
OSD position yes
OSD language (s) 5
max. refresh rates in Hz
640 x 480 75
800 x 600 75
1024 x 768 75
1152 x 864 75
1280 x 1024 75
1600 x 1200 75
approvals / standards
Plug & Play, DDC1/2B yes/yes
Power-Management: Vesa DPMS / Nutek / Energy Star no/no/yes
TCO99 yes
TÜV GS / TÜV Ergonomie yes/yes
EN 29241 / DIN ISO 9241-3, - 7, -8 yes/yes
VESA FPMPMI Standard compliant yes
connections
15 pin. Mini-D-Sub yes
24 pin DVI-D DVI-I
Audio In yes
accessories
user manual in 15 languages 10 languages
power cable yes
video connection 15 pin Mini-D-Sub yes
audio cable yes
video connection: 24 pin DVI-D DVI-I
  • Nitroglycerine
  • Laatst online: 23:34
Nitroglycerine
Autisme: belemmering en kracht
Ik denk dat je onder je FPS'en last zult krijgen van ghosting. Ik heb onlangs een nieuwe monitor aangeschaft, wilde eigenlijk een TFT schermpje, maar na uitvoerige tests bij Norrod in Groningen (op een zeer rustig tijdstip) ben ik tot de conclusie gekomen dat de beeldkwaliteit nog niet goed genoeg is om een TFT/LCD scherm neer te zetten.
De tests voerde ik uit door de monitoren (zowel CRT als LCD) aan de externe monitoraansluiting van m'n laptop (met ATi Radeon mobile 9000 videochip) te hangen en de volgende toepassingen te draaien:
- Dragscène uit The fast and the firous (snelle beeldwisselingen)
- Panoramascène uit Gods & Generals (veel verschillende kleuren)
- Quake 3 Arena demo
- Unreal tournament 2003 demo
- Need for speed underground dragrace
Vooral bij de FPS'en en NFS had ik erg veel last van ghosting bij de TFT schermen. Als beste TFT kwam de IIyama E481S-S naar voren, maar die bleef aardig achter bij de Iiyama en Philips 19 & 22 inch CRT schermen.
Jouw belinea scherm heb ik niet kunnen testen, maar qua specs lijkt ie aardig op de Philips 200P3A, en daar was niet eens fatsoenlijk een dvd'tje op te kijken.
Het bovenstaande is puur mijn mening, gekleurd door mijn ervaringen en wensen. Als je twijfelt over je aankoop, ga dan met een laptop naar een winkel die de Belinea verkoopt en test hem daar (als je het op een rustig tijdstip doet hebben ze daar geen problemen mee (anders bel je van te voren even om je wensen kenbaar te maken)).
Hier kon uw advertentie staan
ahhhhhhh mega thx voor je reactie, heb ik heel veel aan ! hartstikke bedankt
jonges nog een paar reacties misschien ??
  • _MaLa_
  • Laatst online: 18-12-2022
Je zou dan iemand moeten spreken over persoonlijke ervaringen met die belinea vooral dan met games etc. ik heb zelf de IIyama E481S 19 inch dan en ben er echt te vreden over vooral met games echt geen ghosting speel veel counterstrike,battlefield etc. Je kan wel wat zien als je echt veel gespeelt heb op crt maar na een tijdje niet meer. schermem met IPS LCD techniek moet je hebben voor een een goede snelle response tijd en grote inkijk hoek.
Ervaring games op Iiyama E481S 19" TFT
s6 :+
[ Voor 10% gewijzigd door _MaLa_ op 10-02-2004 14:14 ]
Nou ik heb zelf de 15 inch versie de 101537. Maar ik vind hem steen goed in games.
Heb weinig last van ghosting. Heel of en toe zie je dat hij wat trager is maar het is bij mij haast niet te zien.
Speel heel vaak UT2003, NFSU, CoD en dat gaat gewoon prima.
En ik vind het zelf veel rustiger voor de ogen
  • koraks
Dat is een totaal ander panel dan in de 20" versie, dus de vergelijking is niet bijzonder waardevol.
Als je fatsoenlijk wil gamen op een 20" LCD kom je al gauw uit bij een LCD met een IPS panel. Deze LCD's zijn momenteel nogal prijzig. Snelle responsetijden en het vermijden van ghosting zijn prioriteiten die eerder bij groot-formaat LCD's niet werden gesteld. De genoemde IPS panels behoren tot zo'n beetje de eerste generatie die én een groot beeldoppervlak hebben, én een hoge resolutie, én fatsoenlijk gedrag bij spellen/video. Én ze zijn heel duur...
