Debian fatal error
Ik heb 2 hd's aan een raid-controller gehangen. Deze worden herkend als hdi en hdk tijdens booten;
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
VP_IDE: IDE controller at PCI slot 00:11.1
VP_IDE: chipset revision 6
VP_IDE: not 100% native mode: will probe irqs later
VP_IDE: VIA vt8235 (rev 00) IDE UDMA133 controller on pci00:11.1
ide0: BM-DMA at 0xb400-0xb407, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xb408-0xb40f, BIOS settings: hdc:DMA, hdd:DMA
HPT374: IDE controller at PCI slot 00:13.0
HPT374: chipset revision 7
HPT374: not 100% native mode: will probe irqs later
HPT37X: using 33MHz PCI clock
ide2: BM-DMA at 0xcc00-0xcc07, BIOS settings: hde:pio, hdf:pio
ide3: BM-DMA at 0xcc08-0xcc0f, BIOS settings: hdg:pio, hdh:pio
ide4: BM-DMA at 0xe000-0xe007, BIOS settings: hdi:DMA, hdj:pio
ide5: BM-DMA at 0xe008-0xe00f, BIOS settings: hdk:DMA, hdl:pio
hda: Maxtor 6E020L0, ATA DISK drive
blk: queue c0382d20, I/O limit 4095Mb (mask 0xffffffff)
hdc: Maxtor 6Y080L0, ATA DISK drive
hdd: R/RW 4x4x32, ATAPI CD/DVD-ROM drive
blk: queue c038318c, I/O limit 4095Mb (mask 0xffffffff)
hdi: Maxtor 6Y060L0, ATA DISK drive
blk: queue c0383ed0, I/O limit 4095Mb (mask 0xffffffff)
hdk: Maxtor 6Y060L0, ATA DISK drive
blk: queue c038433c, I/O limit 4095Mb (mask 0xffffffff)
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
ide1 at 0x170-0x177,0x376 on irq 15
ide4 at 0xd000-0xd007,0xd402 on irq 18
ide5 at 0xd800-0xd807,0xdc02 on irq 18
hda: attached ide-disk driver.
hda: host protected area => 1
hda: 40718160 sectors (20848 MB) w/2048KiB Cache, CHS=2534/255/63, UDMA(133)
hdc: attached ide-disk driver.
hdc: host protected area => 1
hdc: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=158816/16/63, UDMA(133)
hdi: attached ide-disk driver.
hdi: host protected area => 1
hdi: 120103200 sectors (61493 MB) w/2048KiB Cache, CHS=119150/16/63, UDMA(100)
hdk: attached ide-disk driver.
hdk: host protected area => 1
hdk: 120103200 sectors (61493 MB) w/2048KiB Cache, CHS=119150/16/63, UDMA(100)
hdd: attached ide-cdrom driver.
hdd: ATAPI 32X CD-ROM CD-R/RW drive, 2048kB Cache, DMA
Uniform CD-ROM driver Revision: 3.12
Partition check:
hda: hda1 hda2 hda3 hda4 < hda5 hda6 hda7 hda8 >
hdc: hdc1 hdc2 hdc3 hdc4 < hdc5 hdc6 hdc7 hdc8 hdc9 >
hdi: hdi1 hdi2
hdk: hdk1 hdk2
-Met een gemodificeerde recue-flop kan ik de hd's partitioneren, in dmesg (hierboven) zie je ook de indeling.
-fdisk -ul laat alleen hda en hdc zien!
-als su of root kan ik niet cfdisk /dev/hdi of hdk uitvoeren, ik krijg;
FATAL ERROR: cannot open disk drive
-Dacht misschien probleen in kernel-2.6.2, heb ook kernel-2.4.24 geinstaleerd, precies het zelfde, tevens staat ACPI aan, zou toch niet uit moeten maken?!
What's going on?
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Met je rescue flop kun je ze wel benaderen?
Dan heb je dus in je gewone kernel geen support voor die HPT374 en in de kernel op die flop wel.
Verwijderd schreef op 09 februari 2004 @ 12:10:
hdi: hdi1 hdi2
hdk: hdk1 hdk2
Klopt dus niet die stelling, wel ondersteuning van hpt374 door kernel
  • RvdH
RvdH
Verwijderd schreef op 09 februari 2004 @ 12:30:
Komt die dmesg nou van die floppy of van je systeem?
Wat is de inhoud van je /proc/partitions?
dmesg is van systeem, niet boot floppy dus
cat /proc/partitions, wordt helemaal te gek:
major minor #blocks name
9 0 32000 md0
9 1 4883648 md1
9 2 497856 md2
9 3 12384192 md3
9 4 1020032 md4
9 5 1020032 md5
9 6 511936 md6
57 0 60051600 hdk
57 1 59684656 hdk1
57 2 366912 hdk2
56 0 60051600 hdi
56 1 59684656 hdi1
56 2 366912 hdi2
22 0 80043264 hdc
22 1 32224 hdc1
22 2 4883760 hdc2
22 3 497952 hdc3
22 4 1 hdc4
22 5 12384256 hdc5
22 6 512032 hdc6
22 7 1024096 hdc7
22 8 1024096 hdc8
22 9 59684656 hdc9
3 0 20359080 hda
3 1 32098 hda1
3 2 4883760 hda2
3 3 498015 hda3
3 4 1 hda4
3 5 514048 hda5
3 6 1020096 hda6
3 7 1020096 hda7
3 8 12386083 hda8
Staat dus hier wel tussen!
  • igmar
  • Laatst online: 19:53
igmar
ISO20022
Bestaan de block devices wel in /dev/ ? Niet alle installaties maken hdi en hdk aan..
igmar schreef op 09 februari 2004 @ 12:49:
hoe check ik dat?
Ik denk dat ik begrijp wat je bedoelt;
zie in /dev alleen tot en met hdh9, zou het dus hier in zitten en wat moet ik hier aan doen?
Ik heb gevonden dat je het met mknod moet doen, alleen moet ff checken welke variabelen ik nog meer moet doen afgezien van;
mknod /dev/hdi
mknod /dev/hdk
[ Voor 41% gewijzigd door Verwijderd op 09-02-2004 13:23 ]
  • RvdH
RvdH
Major en minor nummers staan in /proc/partitions.
Maar je kunt ook proberen om /dev/MAKEDEV hdk te runnen.
[ Voor 38% gewijzigd door RvdH op 09-02-2004 13:52 ]
RickJansen, je hebt gelijk, nu kan ik eindelijk mijn raid5-array opzetten!
betahhh Timing buffered disk read: 64MB = 94.16MB/s in raid5, nu nog ff alle directories op de juiste md gooien en klaar!
heren bedankt!
