[Excel] vraagje
Ik heb in Excel een aantal waarden onder elkaar en wil daaronder het al die waarden bij elkaar optellen. Nu kan ik dat met SOM. Niet zo moeilijk. Nu is het probleem echter dat hij alleen de positieve getallen moet optellen. Dus niet -2 en -3 etc.
Kan dit?
  • Schonhose
  • Laatst online: 01-09 09:29
Schonhose
Retro Icoon
Gebruik de functie SumIf (Engelse Excel)
SUMIF
See Also
Adds the cells specified by a given criteria.
Syntax
SUMIF(range,criteria,sum_range)
Range is the range of cells you want evaluated.
Criteria is the criteria in the form of a number, expression, or text that defines which cells will be added. For example, criteria can be expressed as 32, "32", ">32", "apples".
Sum_range are the actual cells to sum.
Remarks
The cells in sum_range are summed only if their corresponding cells in range match the criteria.
If sum_range is omitted, the cells in range are summed.
Microsoft Excel provides additional functions that can be used to analyze your data based on a condition. For example, to count the number of occurrences of a string of text or a number within a range of cells, use the COUNTIF function. To have a formula return one of two values based on a condition, such as a sales bonus based on a specified sales amount, use the IF function.
Criteria moet dan zijn >=0
De laatste parameter is niet nodig:
=SUMIF(B2:B7;">=0")
Succes
[ Voor 9% gewijzigd door Schonhose op 06-02-2004 09:12 ]
"The thing under my bed waiting to grab my ankle isn't real. I know that, and I also know that if I'm careful to keep my foot under the covers, it will never be able to grab my ankle." - Stephen King
Quinta: 3 januari 2005
Koel bedankt!
