vast in level 2 splinter cell, ook met walktrough
  • 60 views sinds 30-01-2008
Hoi, ik zit in sc in level 2 vast als ik naar de southwing moet, als de kok dat raam open doet en ik ga via de dakgoot erheen, wordt ik gepakt door de lasers, ik heb een engelse walktrough en daar staat het niet duidelijk in.
Ik kan het zelf ook nergens vinden. Wie kan me helpen aub.
[C. Defense Ministry]
Mission Overview - Find out Nikoladze's secret.
Mission difficulty rating: 6/10.
What a view. It should be from 7 stories in the air. Anyways, start out
by dropping down to the balcony in front of you. Face the courtyard and
turn right. See that vertical pipe? Grab onto it, and slide down to the
balcony below. Open the doors and equip your firearm. Look to the
northwest of the room. See that camera? Destroy it. The guard now is
curious. He draws his firearm and checks to see what it is. Knock him
out or kill him and hide his body behind the bookshelves. Destroy the
light; grab the data stick from the computer, and head out. You are now
in a hallway with two patrolling guards. Move into the shadows and
crouch. Equip your firearm and go for a headshot. Do this to the second
guard (this may take a couple of attempts since the guard is right next
to the alarm). Now hide the guards' body in either the previous room or
in this hallway's shadows. Examine the room. We should come to the
conclusion that there are 3 doors - one where you came from, one at the
opposite side of it, and another all the way down the hallway. Take the
door in the middle, next to the alarm, and head up to the top floor.
Grab the health kit, and head all the way down. Destroy each camera
along the way (there should be about 3). You don't need to destroy the
lights. At the bottom-most floor, a checkpoint occurs...
Open the door in front and take out the camera in view. Now head down
the garage and make a U-turn into a new section. You see 2 cars, 1 guy,
and one camera. Hamlet's car is the black one, and the camera is a
little higher and to the right of his car. Now, if you're a pistol
expert, take out the camera. Hamlet will check to see what this is.
Stay in the shadows, crouched, and he shouldn't find you. Hamlet
convicts himself no one is there, and goes right in front of his car to
'lose some weight'. Sneak up on him when he is. Interrogate him, and
knock him out. Hide his body in the shadows, and return to the hallway
with the 3 doors.
Open the last door, and STOP! A camera is directly above you. Equip
your firearm, and one bullet should do it. Grab the data stick; turn
off the lights, and lock pick the next door. Checkpoint.
Now you should see a cook open his window. Sneak out to the balcony,
facing the courtyard and turn left. Jump up on the balcony, and face
the wall. Jump up again for Sam to grab the gutter pipe. Climb all the
way to the cook's window. Once you're over the window, press Y to let
go and land on the table. Move forward and fall down to the floor
(REMEMBER TO PRESS B FOR A SILENT FALL), and hide behind the box. Watch
this funny cut scene. Now after the guard leaves, crouch down if you
haven't already and move to the further-most cook through the right
side of the kitchen (no I'm not crazy). The first cook shouldn't see
you, so knock out (KO) the one in the corner (its only takes one hit).
Now quickly run over to the alarm (next to the door the guard left
through). The other cook should run over to the alarm, about 70% of the
time. That's where you KO him. The other 30% he should run into the
freezer. You can also KO him as well in there. Anyways, carry the cooks
into the freezer and shoot the lights out in there.
ALTERNATE STRATEGY for taking out the cooks - from m-ko@terra.com
(Alex): When you drop in through window wait for cutscene to pass, and
grab a bottle, run in freezer, turn off light, go back to the window,
throw bottle in freezer. The cooks will come to investigate, circle
around and trap them inside and knock them out.
Moving on, turn the lights out in the whole kitchen, and open the door.
See the patrolling guard? Go for a headshot on him, and carry him into
the freezer as well. Now go out into the 'main room' where the double-
doors lead you, and quickly run into the left path. Dead end? Yes. Wait
for the other guard to come check out what the noise was. KO out
(remember, make the first move when he's close to you), and carry him
in the freezer with the others.
If you have at least 2 bullets (I had 5), you're in good condition. Go
back to the kitchen and grab a bottle from the window you came in, and
then lower yourself to the floor right above the ground one in 'the
main room'. Toss the bottle, and the first guard checks to see what it
is. If you have 2 bullets or more, go for a headshot on him. If not, KO
out. Then sneak behind the other guard, and KO him as well. Carry them
into the darkest place you can find (you don't have to carry them into
the kitchen's freezer, I just carried their bodies under the stairs),
and check out the computer. Grab the data stick, and Lombert will call
in to tell you a colonel is on his way, so hide under the stairs
(doesn't matter which one). The colonel wants to play some solitaire on
his computer, so when he does, sneak up on him (DON'T KNOCK HIM OUT),
and grab him. Now facing the computer, make your way to the
southwestern part still on the ground floor. Toss his head into the Eye
scanner (stand next to the eye scanner with him and press A), and KO
him. Hide his body, and enter that room you opened. Checkpoint...
finally.
You should have one or more bullets, destroy that camera, and open that
door to the courtyard. A cut scene emerges with Nikoladze, and Philip
Masse - the computer expert. Race over to the elevator and wipe out
your Laser Mic. Press X to get it out, and point it to the elevator.
Once your done, Lombert calls in and requests that you gather data from
his computer. But wait, 3 guards exit... with guns! Shouldn't be a
problem for you, just hide crouched down. Knock out whatever guard
comes close to you, and then the second. Repeat this for the third. If
you still have some ammo, try and go for headshots, and enter the door
they were in. Grab the health pack on the wall and exit back into the
courtyard. There are 2 more doors. One of these doors should contain
some vines to the right of them that you can climb. Go there and do so.
And drop down for the loading zone and checkpoint.
Wow, we have seconds before the elevator reaches the bottom. Run into
the janitor room, left of the elevator, and crouch down (make sure that
light in that room are turned off). Several seconds later, footsteps
are heard. There are a total of 2 guards. If you open the door midway
(A+down on the left trigger), you can see the first guard all the way
down the hallway. The second guard is walking around the area, so open
the door, and go for a headshot to him when he comes into view, or
knock him out in case you're out of ammo. Sneak up on the second one,
and repeat this process. Hide their bodies in the janitor's closet, and
take the elevator up to the top floor. Here's checkpoint!
We have seconds before a guard comes around and finds your there. Run
out of the elevator and to the left (the camera won't spot you so don't
worry). Lockpick the first door you come across (on the left), and jump
inside. If a guard follows you, deliver him a headshot. I admit, I was
out of ammo so we'd have to fight. Anyways, hide his body in the exact
same room, and turn off the lights. See the computer for a data stick,
and jump up on the desk the computer is on. Face the door, and jump up
once more to your left. Climb into the air ducts, and drop down at the
end, and quickly hide behind the plants. Now, here comes the hard part.
Run out and quickly into the first room on the left you find. The
camera would have seen you by now, but we have a good 5 seconds before
the guards come. Take the two health kits on the wall, and climb up the
ladder, opening the trap down as you go. Once your up they're, run to
your right for a checkpoint, and a rappel object. Heal your wounds (if
any) with the health kits, and rappel down.
See the guard? Go for a headshot if you have any ammo. If not, press
the Y button for Sam to jump into the windows, breaking it. Knock the
guard out. Turn the lights off, and grab the guard's... FRAG GRENADE!!!
Head over to the computer farthest from when you entered. Grab the data
stick there, and now head over to the other computer. Get your frag
grenade ready, and press A next to the computer. The information will
be downloaded and sent to Lombert, but Grinko will detect this and send
3 guards after you. Hide in the corner, equip your frag grenade and
throw the grenade as soon as the door opens. The grenade will knock out
2 guards, and the third will check the room. If you're in a fairly good
hiding place, the guard won't find you and he'll walk over and look at
the broken window. Now's your chance. After you've knocked him out,
send the rest of the information to Lombert. Mission Accomplished!
We need to get the heck out of here, now. Open the door the guards come
from. See the camera to the left of you? It's the one that spotted you
a couple minutes ago. Anyways, run out to the hallway to your left, and
enter the first door on the left. By now the camera should have
detected you (I could never get past it undetected), and 3 guards will
be sent after you. If you want to fight them, do so, but our main
concern is getting away. So after you've entered the first door on the
left run down the stairs and make a U-turn. To the right of the door is
a health kit. If you want it, grab it, but we don't have any more
enemies to fight, so run out the door. Run down this next set of
stairs; followed by a right. See what looks like an opened office door?
It's an elevator. Take a running start and jump into it and grab the
vertical pipe. Slide down it.
Look familiar? It's the garage where we took care of Hamlet. Anyways,
go back to where Hamlet's car was and there's our getaway ride. Talk to
our friend to end the mission.
Version 1.30 - Sorry for the delay. I receive so many emails of
Splinter Cell FAQs... They are mostly asking about Defense Ministry
alarms, and why the alarm goes off when you're climbing over the gutter
pipe. Please, remember to hide the driver. If I get one more question
about DM alarms, I'm going to scream.
Het is _NIET_ de bedoeling dat je een topic gaat openen nadat ie gesloten is. Mijn mailtje daarnet was nog vrij vriendelijk, maar dit is dan je laatste waarschuwing: De volgende keer ga ik strenger optreden.
