FreeBSD 4.9 VPN naar utwente
  • Four
Four
I void warranty
Goede middag. Ik ben bezig met het opzetten van VPN naar utwente. Ik heb dit gedaan volgens de volgende handleiding: http://www.snt.utwente.nl/handleidingen/vpn.html#linux (zie VPN via FreeBDS)
Ik denk dat alles goed staat, maar zodra ik connectie lijk te maken via deze machine met een ip adress van utwente, krijg ik in me mpd output te zien:
IFACE: Up event <- was er al natuurlijk
[vpn] LCP: no reply to 1 echo request(s)
[vpn] LCP: no reply to 2 echo request(s)
[vpn] LCP: no reply to 3 echo request(s)
Dan gaat hij weer opnieuw connectie maken. Ik zie dat er iets fout gaat in LCP maar heb geen idee hoe ik dit verhelp. Kan iemand me een paar meter op weg helpen?
Output mpd:
[vpn] LCP: Open event
[vpn] LCP: state change Initial --> Starting
[vpn] LCP: LayerStart
[vpn] device: OPEN event in state DOWN
[vpn] pausing 3 seconds before open
[vpn] device is now in state DOWN
pptp0: connecting to 130.89.1.223:1723
[vpn] device is now in state OPENING
pptp0: connected to 130.89.1.223:1723
pptp0: attached to connection with 130.89.1.223:1723
pptp0: ctrl connection closed by peer
pptp0: killing connection with 130.89.1.223:1723
pptp0-0: killing channel
[vpn] PPTP call failed
[vpn] device: DOWN event in state OPENING
[vpn] link: DOWN event
[vpn] LCP: Down event
[vpn] pausing 9 seconds before open
pptp0-0: outgoing call connected at 10000000 bps
[vpn] PPTP call successful
[vpn] device: UP event in state OPENING
[vpn] device is now in state UP
[vpn] link: UP event
[vpn] link: origination is local
[vpn] LCP: Up event
[vpn] LCP: state change Starting --> Req-Sent
[vpn] LCP: phase shift DEAD --> ESTABLISH
[vpn] LCP: SendConfigReq #45
MRU 1500
MAGICNUM 193d6952
AUTHPROTO PAP
[vpn] LCP: rec'd Configure Request #0 link 0 (Req-Sent)
AUTHPROTO PAP
[vpn] LCP: SendConfigAck #0
AUTHPROTO PAP
[vpn] LCP: state change Req-Sent --> Ack-Sent
[vpn] LCP: SendConfigReq #46
MRU 1500
MAGICNUM 193d6952
AUTHPROTO PAP
[vpn] LCP: rec'd Configure Request #1 link 0 (Ack-Sent)
AUTHPROTO PAP
[vpn] LCP: SendConfigAck #1
AUTHPROTO PAP
[vpn] LCP: SendConfigReq #47
MRU 1500
MAGICNUM 193d6952
AUTHPROTO PAP
[vpn] LCP: rec'd Configure Reject #47 link 0 (Ack-Sent)
AUTHPROTO PAP
[vpn] LCP: SendConfigReq #48
MRU 1500
MAGICNUM 193d6952
[vpn] LCP: rec'd Configure Ack #48 link 0 (Ack-Sent)
MRU 1500
MAGICNUM 193d6952
[vpn] LCP: state change Ack-Sent --> Opened
[vpn] LCP: phase shift ESTABLISH --> AUTHENTICATE
[vpn] LCP: auth: peer wants PAP, I want nothing
[vpn] PAP: using authname "s9914331"
[vpn] PAP: sending REQUEST
[vpn] LCP: LayerUp
[vpn] PAP: rec'd ACK #1
[vpn] LCP: authorization successful
[vpn] LCP: phase shift AUTHENTICATE --> NETWORK
[vpn] setting interface ng0 MTU to 1460 bytes
[vpn] up: 1 link, total bandwidth 64000 bps
[vpn] IPCP: Up event
[vpn] IPCP: state change Starting --> Req-Sent
[vpn] IPCP: SendConfigReq #34
IPADDR 10.98.128.1
[vpn] IPCP: rec'd Configure Request #0 link 0 (Req-Sent)
IPADDR 130.89.1.223
130.89.1.223 is OK
[vpn] IPCP: SendConfigAck #0
IPADDR 130.89.1.223
[vpn] IPCP: state change Req-Sent --> Ack-Sent
[vpn] IPCP: SendConfigReq #35
IPADDR 10.98.128.1
[vpn] IPCP: rec'd Configure Nak #35 link 0 (Ack-Sent)
IPADDR 130.89.7.163
130.89.7.163 is OK
[vpn] IPCP: SendConfigReq #36
IPADDR 130.89.7.163
[vpn] IPCP: rec'd Configure Ack #36 link 0 (Ack-Sent)
IPADDR 130.89.7.163
[vpn] IPCP: state change Ack-Sent --> Opened
[vpn] IPCP: LayerUp
130.89.7.163 -> 130.89.1.223
[vpn] IFACE: Up event
[vpn] exec: /sbin/ifconfig ng0 130.89.7.163 130.89.1.223 netmask 0xffffffff -link0
[vpn] exec: /sbin/route add 130.89.7.163 -iface lo0
[vpn] exec: /usr/local/etc/mpd/up.sh ng0 inet 130.89.7.163 130.89.1.223
pptp0: read: Operation timed out
[vpn] PPTP call terminated
[vpn] device: DOWN event in state UP
[vpn] LCP: state change Opened --> Starting
[vpn] LCP: phase shift NETWORK --> DEAD
[vpn] setting interface ng0 MTU to 1500 bytes
[vpn] up: 0 links, total bandwidth 9600 bps
[vpn] IPCP: Down event
[vpn] IPCP: state change Opened --> Starting
[vpn] IPCP: LayerDown
[vpn] IFACE: Down event
[vpn] exec: /usr/local/etc/mpd/down.sh ng0 inet
[vpn] exec: /sbin/route delete 130.89.7.163 -iface lo0
[vpn] exec: /sbin/ifconfig ng0 down delete -link0
[vpn] LCP: LayerDown
[vpn] pausing 7 seconds before open
[vpn] closing link "vpn"...
[vpn] link: CLOSE event
[vpn] LCP: Close event
[vpn] LCP: state change Starting --> Initial
[vpn] LCP: LayerFinish
[vpn] device: CLOSE event in state DOWN
[vpn] opening link "vpn"...
[vpn] link: OPEN event
[vpn] pausing 1 seconds before open
dwyslexy != luiheid !! Taalpuristen sla uw slag
