Asus 9800 XT - Overklok resultaten
  • 217 views sinds 30-01-2008
  • Degrader
  • Laatst online: 13:06
Nadat ik twee exemplaren van de Asus 9800 XT heb kunnen testen (overklokken ;) ) vallen mij de resultaten nogal erg tegen. De core wil niet verder dan 415MHz, terwijl het geheugen bij mijn eerste exemplaar al op zijn standaardsnelheid artifacts geeft. De core wordt maximaal 65 graden en het geheugen 59 graden. Aan mijn voeding ligt het waarschijnlijk niet aangezien ik een Enermax 350W heb. Wat ik nogal opmerkelijk vond is dat sommige reviewers deze kaart redelijk tot goed konden overklokken, terwijl andere reviewers ongeveer dezelfde slechte resultaten krijgen als ik. Bijvoorbeeld:
Quote Nordic Hardware:
About the 9800 XT results:
Certainly the Radeon 9800 XT has 412 MHz as standard on its core but the fact is that OVERDRIVE is supposed to bring up the core to 432 MHz and from what we have understood that's where ATi draws the line for qualified chips. In that case we can say that GeXCube overclocks 0 % on the core and Sapphire is not so much better. The memory isn't anything nice to work with either when it comes to overclocking.
But our results, especially when it comes to the cards core, are not in conjunction with what we have seen in other reviews out on the world wide web. It seems to be something wrong with our testsystem. We have spoken with the manufacturers and ATi themselves. (since we have the same problems with ATi's reference card). The popular theory is that we have a too weak PSU. We have made more tests with a high quality 450w PSU and it didn't make any difference. Other bids have been the program we have used to overclock but here we have used four different programs (Rage3D Tweaker, PowerStrip, RiveTuner and ASUS SmartDoctor) without any luck with one or the other.
Another explanation people has tried to give us is that we have had OVERDRIVE activated, but that hasn't been the case in any of the tests and which would in any case cause graphical errors and stability issues.
Finally we re-installed Windows, drivers, tried exchanging hardware and everything else you can consider doing in that situation. Concluding: The problems was there no matter how much we tried.
That leaves us with the question: Is there something fundamentally wrong with our testsystem or does the cards just overclock really bad (in other words. are our cards of worse quality the usual ones)?
To be honest we don't really know what it can be. So don't consider our result as anything final when it comes to the three Radeon 9800 XT-cards core-overclocking. The other results we have ended up with seems to be right if comparing to other reviews.
Bron: http://www.nordichardware...Last_2003/index.php?ez=19
Nou is mijn vraag: tot welke frequenties kunnen jullie je Asus 9800 XT overklokken?
  • Apen-nootjes
  • Laatst online: 03-04-2025
Apen-nootjes
aka Apen-klootjes
Het zal je misschien alweer iets helpen: ATI 9800xt + peltier
Dit is een gozer die z'n 9800 met een peltier gekoeld heeft en daar ook resultaten enzo bij zet :)
SmartDoDo: Ach, afhankelijk van je smaak kan het best een lekker geil ding zijn :P
You never had a date you couldn't inflate
  • Koekje
Koekje
GoT-lurker
Het is gewoon een kwestie van geluk hoe ver je je kaart kan overclocken.
maar even een beetje offtropic: ik kon mijn 9800 np overclocken tot xt speeds en zelfs hoger maar ik heb m wel geflashed naar een xt.
There are 10 types of people in this world. Those who understand binary, and another 9 who don't give a s**t.
  • WiXX
  • Laatst online: 07:51
WiXX
Kijk uit malloot een...
Ik heb me xt op 421/374 lopen en hij loopt extreem stabiel op die snelheden.
Had hem eerst hoger gecloacked alleen eerst krijg je dan artifacts in ragtroll (3dmark2003) en Halo.
Maar op deze snelheden werkt het perfect.
  • Henk
  • Laatst online: 12:28
Ik heb een 9800 pro @ XT (geldt dat ook als een XT? :P ) en die draait met gemak 430 core, kan waarschijnlijk nog wel hoger ook.
  • papichulo
  • Laatst online: 31-05 20:16
mijn 9800xt werkt momenteel op 439/385 en allen op 3dmark2003 en maxp2 krijgt die artifacts. Op NFSU, COD, MOHAA, Halo zeer stabiel.
Het geheugen kan hoger maar dan is het :r .
Ik vraag mij af wat voor geheugen er op staat. Samsung of infineon.
  • Astennu
  • Laatst online: 19-08 17:53
K had die van bio_blade toen met v-mods @ 490-400 draaien zonder 455-400 dus dat ging wel lekker was een herc kaartje.
  • GeeMoney
  • Laatst online: 12:29
Ik heb zelf mijn 9800Pro flashed @ XT nu op 424//373 draaien.
Mijn R9800 Pro van 380/680 kan op 440/760 draaien maar ik spaar hem en game altijd op 410/720.
Koeling: Zalman ZM80C-HP en ZM-OP1 Fan @ 12V
  • WiXX
WiXX
papichulo schreef op 02 februari 2004 @ 21:01:
Dat noem ik niet stabiel, maarja dat is mijn visie.
dat kijk je toch even op je mem chips wat er op staat :)
maar als ie al niet stabiel is in 3dmark2003 kan je niet spreken van een stabiele OC.
  • papichulo
Verwijderd schreef op 03 februari 2004 @ 14:25:
Even kijken op mem chips :O ja natuurlijk.
Heb je die Asus 9800xt van dichtbij al eens bekeken.
Die memchips zijn helemaal bedekt met koeling.
En ik ben niet van plan die "effe" eraf te halen om ff te zien welke het zijn.
Als iemand het wel weet?
  • Henk
papichulo schreef op 03 februari 2004 @ 15:05:
Effe dr af is zo gebeurd, schroefbevestiging is een fluitje van een cent. Gelijk ff die asusprut dr af en artic silver 5 dr tussen en je haalt misschien nog wel een hogere OC ook :)
  • papichulo
RedXraD schreef op 03 februari 2004 @ 15:10:
Oke voor die artic silver pasta zou ik het ook doen.
Maar toch niet voor ff te kijken welke mem erop staat. Ik kan het ook ff vragen op deze topic. ;)
  • Henk
papichulo schreef op 03 februari 2004 @ 20:19:
Nee, want er zijn dus verschillende soorten geheugen per 9800 XT, zowel DDR als DDR II, en bij DDR ook nog es onderscheid tussen samsung en infineon :P
  • papichulo
RedXraD schreef op 03 februari 2004 @ 22:35:
Inderdaad, maaaar ik had daarvoor een 9800pro gehad en daarop kon je het wel op aflezen en deze zijn van Samsung. Dus beter dan infineon,that's all.
En dat is het enige wat ik wou weten. Het merk. Maar blijkbaar is dit een moeilijke vraag.
  • papichulo
Ok heb dan toch ff de cooler eraf gedaan en andere pasta op de mems fijngesmeerd, want hetgeen erop lag was denk ik geen pasta maar wel een poedervorm.
Nu want stond er op die mems, geen samsung of infineon maar wel dit;
HY5DU573222
AFM-25 344A
KOR 7L54239WQ
Als er iemand iets afweet van dit soort geheugen. Ik ben een en al oog. B)
  • Henk
papichulo schreef op 04 februari 2004 @ 00:15:
HY5DU573222
AFM-25 344A
KOR 7L54239WQ
Hynix geheugen denk ik (eindelijk)
Zou je voor mij ff een backupje van je bios willen maken en dat ff naar mij willen meelen? dan zet ik hem dr bij in het 9800 pro -> XT topic, kunnen ook mensen met hynix mem aan het flashen gaan... plzzzz ;)
Henk(AT)RedXraD(DOT)nl :)
[ Voor 3% gewijzigd door Henk op 04-02-2004 00:58 ]
  • papichulo
RedXraD schreef op 04 februari 2004 @ 00:58:
Hinyx? Spreken we dan over goede een goed merk.
En te vergelijken met Samsung of Infineon of ander merk?
  • bobsnl
  • Laatst online: 26-06 09:56
papichulo schreef op 04 februari 2004 @ 14:31:
Hinyx hoort gewoon tussen de topmerken
[IMG]http://veloviewer.com/SigImage.php?a=1d38a&r=2&c=8&u=M&g=p&f=abcdefghij&z=a.gif[/IMG]
  • papichulo
bobsnl schreef op 04 februari 2004 @ 14:33:
Oke goed om te weten
thx
Heb die arctic silver5 pasta fijntjes op de mems en de chip gesmeerd, maar de resultaten zijn hetzelfde. :/
  • papichulo
Sorry verbetering. Hynix
  • papichulo
Hier een paar resultaten van benchmarks, met Asus 9800XT op 439/385 oc . Temp. ervoor; gpu 45 ram 41
3d mark 2003: 6728
3d mark 2001se: 19090
gunmetal benchmark 1: 3795
'' '' 2: 4957
aquamark: 45197
allemaal op resolutie 1024x768
temp erna; gpu 48 ram 44
  • papichulo
papichulo schreef op 06 februari 2004 @ 13:56:
3d mark 2003: 6728
'' '' 2: 4957
aquamark: 45197
de memory heb ik verlaagd naar 376 omdat er flitsende strepen op beeld kwamen bij Battle og Proxicon. maar de gpu is verhoogd naar 453 en ik haal nu een score van 6805. De temps blijven idem. ;)
  • papichulo
na wat onderzoek via google, ben ik te weten gekomen dat, sapphire en ook hercules dezelfde mems gebruiken als die van asus op de 9800xt :|
  • Mister_X
  • Laatst online: 16-09 11:38
Ik heb ook HYNIX geheugen, maar zag het nog niet in dat andere topic staan?! kan iemand me eraan helpen?
  • Boogieman82
  • Laatst online: 12-11-2025
IK draai op 432/371mhz, als ik hoger ga krijg ik artifacts. Alleen is mijn temp. wel 72c. Meer mensen met een Hercules Radeon 9800xt die dit hebben??
3dmark03= 6500punten
3dmark01=17500punten
specs
Bij Pixel shader krijg ik op de neushoorn zilvere pixeltjes, loopt die dan niet meer stabiel???
Bij de rest van de test heb ik namelijk geen problemen...
Club3d 9800 xt @ 430 / 380
Club3D 9800Pro@XT
Core @ 453 MHz
Mem @ 396 MHz
Thermaltake Extreme Giant III + Ramsinks
En nog geen artifact gezien, kan dus hoger })
Boogieman82 schreef op 22 april 2004 @ 23:24:
De mijne wordt zelfs 74-75 graden. Volgens mij is dit normaal voor de Hercules kaarten.
