bestanden overzetten met flash fxp ??
  • 39 views sinds 30-01-2008
Ik wil bestanden overzetten van mijn server naar een server van mijn vriend.
Maar ik krijg dit maar niet in orde, wil eens iemand kijken wat er fout is ??
Connecting to 24.215.67.62
Connected to 24.215.67.62 -> IP=24.215.67.62 PORT=21
220 Serv-U FTP Server v5.0 for WinSock ready...
USER leecher
331 User name okay, need password.
PASS (hidden)
230 User logged in, proceed.
SYST
215 UNIX Type: L8
PWD
257 "/g:" is current directory.
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (24,215,67,62,11,46)
LIST
150 Opening ASCII mode data connection for /bin/ls.
226 Transfer complete.
List Complete: 629 bytes in 1,57 (0,39 KBps)
Connecting to gens
Connected to gens -> IP=62.235.14.9 PORT=21
220 Tiscali.be Personal Web Page Server. Welcome...
USER gens@tiscali.be
331 Password required for gens@tiscali.be.
PASS (hidden)
230-User gens@tiscali.be logged in.
230 Quotas on: using 5680.87 of 51200.00 kb
SYST
215 UNIX Type: L8
REST 100
350 Restarting at 100. Send STORE or RETRIEVE to initiate transfer.
REST 0
350 Restarting at 0. Send STORE or RETRIEVE to initiate transfer.
CWD /operator/For Mister LAUWERS/
250 CWD command successful.
PWD
257 "/operator/For Mister LAUWERS" is current directory.
List (cached)
List Complete.
TYPE I
200 Type set to I.
TYPE I
200 Type set to I.
PASV
227 Entering Passive Mode (62,235,14,9,54,244)
PORT 62,235,14,9,54,244
530 Only client IP address allowed for PORT command.
Site to Site Transfer Failed! (Attempting alternative method)
PASV
227 Entering Passive Mode (24,215,67,62,11,47)
PORT 24,215,67,62,11,47
500 Illegal PORT command.
Transfer Failed!
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (62,235,14,9,54,245)
LIST
150 Opening ASCII mode data connection for file list
226-Transfer complete.
226 Quotas on: using 5680.87 of 51200.00 kb
List Complete: 86 bytes in 0,43 (0,08 KBps)
TYPE A
200 Type set to A.
PASV
227 Entering Passive Mode (24,215,67,62,11,48)
LIST
List Complete: 629 bytes in 1,15 (0,53 KBps)
Transfer queue completed
1 File failed to transfer
  • Arnold
  • Laatst online: 12:42
Wat wordt hier nu juist mee bedoeld dan, en wat kan ik eraan doen ?
  • Ceaser
  • Laatst online: 18-08 17:08
staan de permissies wel goed mbt fxp transfers?
  • Ook
  • Laatst online: 14-07 16:25
Ook
Yes I can!
Deze server ondersteunt volgens mij alleen active mode.
Ik zou dus even in het 'adresboek' van FlashFXP naar het 2e tabje (Options) gaan en daar "Use Passive mode" uitvinken.
Je kan het natuurlijk ook voor al je sites instellen (in de options), maar alleen voor deze ene adresboek-entry moet voldoende zijn..
Wees consequent, maar niet altijd
  • F_J_K
F_J_K
Moderator CSA/PB/AI
Front verplichte underscores
Verwijderd schreef op 31 januari 2004 @ 20:21:
Euhm benny1, het is hier op GoT toch wel de bedoeling om zelf uit te zoeken wat wat is. Daar ben je tweaker voor ;)
Loop de handleiding van FlashXP door, zoek op Google wat een 530 error doet, etc. Je handje vasthouden lijkt me niet nodig ;)
Dit staat verder gewoon letterlijk in de handleiding van FlashFXP:
Q: Why do I keep getting this message: "Only client IP address allowed for PORT command" when trying to FXP?
A: The FTP Server is set up to block FXP. In most cases using alternative fxp method doesn't solve this problem.
Etc.
Lees FAQ Forumgedrag even door voor meer uitleg over hoe en wat.
Omdat dit gewoon letterlijk in de FAQ staat van het programma en het gewoon dumpen van een error log zonder er zelf naar te kijken niet de bedoeling is op GoT, sluit ik dit topic.
Kijk eerst zelf even goed naar het log, zoek uit wat foutmeldingen betekenen (volg de tips hierboven) en je moet er uitkomen. Zo niet: open een nieuw topic maar geef dan wel even aan hoe en wat je zelf hebt gedaan behalve het log copy/pasten. Succes :)
