RIS en installatie workstation
Ik heb dus hier van alles gelezen over remote installation services, heb wat documentatie gelezen hoe je zoiets kunt maken en ik vroeg me iets af..
Wanneer je een complete installatie van bijvoorbeeld windows 2000 proffesional als een ris bestand maakt, met de drivers van de netwerkkaart in die image dus, hoe zorg je ervoor dat een lege workstation die windows 2000 image kan gebruiken om te installeren..
daar ben ik niet helemaal over uit.
  • Zer0
  • Registratie: September 1999
Zer0
Destroy 2000 Years Of Culture
Installing Client Computers Using Remote Installation
This section describes the steps required to successfully install Windows 2000 Professional on a Net PC, a Managed PC (PC 98 compliant system), or a PC that contains a network card supported by the remote installation boot floppy. To ensure a successful client installation, complete all prerequisites listed at the beginning of this document.
Reboot your client machine from either the remote floppy or the PXE boot ROM. When prompted, press the F12 key to start the download of the client installation wizard.
Press Enter at the welcome screen.
For the user name, type Jon Grande (this user is created using the Common Infrastructure step-by-step guide discussed in the Prerequisites Section above.) Press the Tab key twice. For this instruction set, the password is left blank and the domain name should be entered as reskit.com. Press Enter to continue.
You will get a warning message that all data on the client machine hard drive will be deleted. To continue, press Enter.
A computer account and a global unique ID for this workstation are displayed. Press Enter to begin Setup. The Windows 2000 Setup program begins.
If prompted, type the Product Key (found on the back of the Windows 2000 Professional CD case) and click > Next. (Note This step can be avoided by specifying the product key in the .sif file; see Windows 2000 Online Help for assistance in making this change to the .sif file.)
After the installation is complete, the user is prompted to log on to the network with an existing user account, password, and logon domain.
At this point, you have successfully configured and installed a remote operating system using RIS. See below for additional information on configuration options.
Uit: Step-by-Step Guide to Remote OS Installation
maybe we sit down and talk about the revolution and stuff
but it doesn't work like that
you can't turn back now there's no way back
you feel the power to destroy your enemy..
En voor de duidelijkheid,
je moet in de server een netwerkkaart hebben met PXE
een cdimage met daarin de drivers van de netwerkkaart van de lege workstation
bootdisk die verbinding maakt met de netwerkkaart van de server en dan vanaf de cd in de server installeert?
Dit is toch dan een beetje het principe?
  • Zer0
Zer0
nope, als de netwerkkaart van de client PXE (Pre-Boot Execution Environment) ondersteunt kan deze zonder bootdisk, via PXE, een connectie maken naar de server.
De server dient wel de Remote Installation Service te draaien.
Short for Pre-Boot Execution Environment. Pronounced pixie, PXE is one of the components of Intel's WfM specification. It allows a workstation to boot from a server on a network prior to booting the operating system on the local hard drive. A PXE-enabled workstation connects its NIC to the LAN via a jumper, which keeps the workstation connected to the network even when the power is off. Because a network administrator does not have to physically visit the specific workstation and manually boot it, operating systems and other software, such as diagnostic programs, can be loaded onto the device from a server over the network
http://www.webopedia.com/TERM/P/PXE.html
[ Voor 5% gewijzigd door Zer0 op 29-01-2004 12:14 ]
  • Zuig
  • Laatst online: 31-08 20:48
Zuig
Fuck man dat Zuigt !
Verwijderd schreef op 29 januari 2004 @ 11:36:
het WERKSTATION moet een PXE boot kunnen uitvoeren, niet de server !!!
Hier hoort mij sig; dat doe ik alleen lekker niet...
