Netwerk fouten in eventvwr van Win2k
  • 113 views sinds 30-01-2008
  • Jake
  • Registratie: September 1999
Als ik in de eventvwr kijk van mijn beide PC's dan staan daar (soms, hangt denk ik van opstart volgorde af) nogal wat netwerk fouten.
Ik zal eerst ff me configuratie geven, dat tikt straks een stuk makkelijker:
- BP550 met 2 NIC's 192.168.0.1 als localnetwork en 10.0.0.150 voor ADSL-modem (dat tevens 10.161.72.73 als PPP-adapter IP-address gebruikt)
- VIA800 met 1 NIC 192.168.0.2
(het adsl modem hing eerst aan de VIA800, maar dual-bp6 is daar beter voor geschikt, om meerdere redenen)
Error op VIA800:
Event Type: Error
Event Source: MRxSmb
Event Category: None
Event ID: 8003
Date: 12-12-2000
Time: 14:21:20
User: N/A
Computer: VIA800
Description:
The master browser has received a server announcement from the computer BP550 that believes that it is the master browser for the domain on transport NetBT_Tcpip_{2AC8B531-8FA3-45FF-8AF. The master browser is stopping or an election is being forced.
Data: * Jake : maar ff weggelaten,anders zo lang
Warnings en Errors op BP550:
Event Type: Error
Event Source: NetBT
Event ID: 4319
Date: 12-12-2000
Time: 13:41:03
User: N/A
Computer: BP550
Description:
A duplicate name has been detected on the TCP network. The IP address of the machine that sent the message is in the data. Use nbtstat -n in a command window to see which name is in the Conflict state.
Data:* Jake : zie boven
Event Type: Error
Event Source: BROWSER
Event ID: 8019
Date: 12-12-2000
Time: 13:46:13
User: N/A
Computer: BP550
Description:
The browser was unable to promote itself to master browser. The browser will continue to attempt to promote itself to the master browser, but will no longer log any events in the event log in Event Viewer.
Data:
0000: 34 00 00 00 4...
Event Type: Warning
Event ID: 8021
Date: 12-12-2000
Time: 14:03:24
User: N/A
Computer: BP550
Description:
The browser was unable to retrieve a list of servers from the browser master \\VIA800 on the network \Device\NwlnkNb. The data is the error code.
Data:
0000: 35 00 00 00 5...
Event Type: Warning
Event ID: 8005
Date: 12-12-2000
Time: 13:51:23
User: N/A
Computer: BP550
Description:
The browser has received a server announcement indicating that the computer BP550 is a master browser, but this computer is not a master browser.
nbtstat -n ook ff gedaan op command prompt
MxStream NIC:
Node IpAddress: [10.0.0.150] Scope Id: []
No names in cache
Local NIC:
Node IpAddress: [192.168.0.1] Scope Id: []
NetBIOS Local Name Table
Name Type Status
BP550 <00> UNIQUE Registered
BP550 <20> UNIQUE Registered
WORKGROUP <00> GROUP Registered
BP550 <03> UNIQUE Registered
WORKGROUP <1E> GROUP Registered
WORKGROUP <1D> UNIQUE Registered
..__MSBROWSE__.<01> GROUP Registered
JAKE <03> UNIQUE Registered
\Device\NetBT_Tcpip_{3EC9172E-599D-414A-8578-24AD1746A842}:
Node IpAddress: [10.161.72.73] Scope Id: []
No names in cache
Snapt iemand er iets van?
wat ik denk ik moet doen is de BP550 de master browser maken, en de VIA800 de slave, maar ik weet niet hoe dat moet.
Ik denk niet dat al deze fouten bevordelijk zijn voor de netwerk-snelheid, vooral aan het begin duurt het heel lang voordat de 2 PC's elkaar zien.
BVD
Jake
  • wildhagen
wildhagen
Blablabla
Dat hele browser-meuk kun je negeren, ze zijn onderling aan het uitvechten wie nu eigenlijk de lijst van netwerk-PC's mag beheren, dat is normaal en word allemaal correct en automatisch afgehandeld. Iedere NT-pc die online komt zal namelijk proberen de master-browser te worden (dmv een "election", en ze doen niet aan recounts ;)). Als die er al is, krijgt hij te horen dat hij geen master mag worden en dan word het een Backup Browser.
Als het goed is is het ook een Informatie-melding (blauwe I) en geen Warning (gele I) of Error (rood kruis).
Virussen? Scan ze hier!
  • Jake
is het niet zo dat ze sneller opstarten als ik ze vertel wie de master-browser moet worden?
want "The browser will continue to attempt to promote itself to the master browser" lijkt me niet echt bevorderlijk voor de snelheid...
maar deze moet ik toch eigenlijk wel oplossen:
"A duplicate name has been detected on the TCP network"
  • wildhagen
wildhagen
Blablabla
Kun je idd beter aanpassen, is allemaal toch wel netwerkverkeer ja, hoewel niet veel, maar toch... moet je ff op de MS-site kijken, want ik meen dat je de registry in moet duiken om dat aan te passen...
Dat andere probleem moet je idd nog eventjes achteraan gaan, dat is namelijk écht niet goed. Heb je toevallig geen 2 PC's met dezelfde hostname ?
  • Twarp
  • Laatst online: 23-04 22:35
Twarp
just grin...
Je kan dit instellen bij NT machines in de registry. Ik ga wel ff zoeken waar.
B-)
Meh ...
  • Jake
Op dinsdag 12 december 2000 16:14 schreef wildhagen het volgende:
ik heb maar 2 pc's
maar zoals ik al zei: dat adsl modem hing eerst aan die VIA800 misschien zit dat IP-address nog ergens verborgen, ik zal ff zoeken
edit1: name-conflict heb ik misschien opgelost door bij BP550 zichzelf als DNS-server op te geven (192.168.0.1 dus) dat stond nog leeg (ff een paar maal rebooten, om te kijken of het werkt)
edit2: nope, geen succes, nog steeds dat name-conflict (ik weet ook nog steeds niet welke precies)
  • Jake
als ik het op DHPC zet, dan krijg ik geen meldingen in eventvwr, maar dat kan niet want ik 'moet' IP 192.168.0.1 gebruiken ivm internet-sharing
die "duplicate name" is er ook nog steeds, daardoor is het traag na klikken op "Computers Near Me" (daarna geeft ie die meldingen dus ook steeds)
Ik heb de namen van de twee gewijzigd, en WINS aangezet, maar het mocht niet baten...
