Heeft iemand ervaring met deze combo?De WAG54G is pas dit jaar uit en er zijn nog geen reviews op het web te vinden. Deze combo kost ongeveer 191 euro.
WAG54G specs:1
-High-speed ADSL Modem gives you a fast, "Always On" connection to the Internet
-Connect your PCs via the built-in Router and 4-port Switch to jump start your Ethernet network and share the Internet throughout your household
-Built-in Wireless-G (802.11g) Access Point also lets you connect without running wires
-Advanced firewall and security features protect your PCs, your data, and your family
WMP54G specs:
-Wireless-G (802.11g) connectivity for your desktop PC
-Incredible data rates up to 54Mbps in the 2.4GHz radio band
-Also interoperates with Wireless-B (802.11b) networks at 11Mbps
-Put your PC wherever you want, with no cabling hassle
WAG54G specs:1
WMP54G specs:
