MX records for p5ycho.net violate section 3.3.9 of RFC 1035
  • 60 views sinds 30-01-2008
  • P5ycho
  • Laatst online: 09:28
Ik heb een beetje troubles met mn mailserver:
29
Mon 2004-01-26 11:23:51: [-1:4304:1] Parsing Message <D:\MDAEMON\Remoteq\pd50000000308.msg>
Mon 2004-01-26 11:23:51: [-1:4304:1] From: *@p5ycho.net
Mon 2004-01-26 11:23:51: [-1:4304:1] To: *@routerspeed.com
Mon 2004-01-26 11:23:51: [-1:4304:1] Subject: *
Mon 2004-01-26 11:23:51: [-1:4304:1] Message-ID: <4014EAB6.5080405@p5ycho.net>
Mon 2004-01-26 11:23:51: [-1:4304:1] MX-record resolution of [routerspeed.com] in progress (DNS Server: 127.0.0.1)...
Mon 2004-01-26 11:23:51: [-1:4304:1] P=000 D=routerspeed.com TTL=(1432) MX=[colo1.routerspeed.com] {217.21.144.1}
Mon 2004-01-26 11:23:51: [-1:4304:1] Attempting MX: P=000 D=routerspeed.com TTL=(1432) MX=[colo1.routerspeed.com] {217.21.144.1}
Mon 2004-01-26 11:23:51: [-1:4304:1] Attempting SMTP connection to [217.21.144.1 : 25]
Mon 2004-01-26 11:23:51: [472:4304:1] Waiting for socket connection...
Mon 2004-01-26 11:23:51: [472:4304:1] Socket connection established (217.19.24.56 : 3878 -> 217.21.144.1 : 25)
Mon 2004-01-26 11:23:51: [472:4304:1] Waiting for protocol initiation...
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 220 routerspeed.com ESMTP
Mon 2004-01-26 11:23:51: [472:4304:1] --> EHLO p5ycho.net
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-routerspeed.com Ok.
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-AUTH LOGIN
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-AUTH=LOGIN X-NETSCAPE-HAS-BUGS
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-XVERP=Courier
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-XEXDATA
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-XSECURITY=NONE,STARTTLS
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-PIPELINING
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-8BITMIME
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250-SIZE
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 250 DSN
Mon 2004-01-26 11:23:51: [472:4304:1] --> MAIL From:<p5ycho@p5ycho.net> SIZE=1885
Mon 2004-01-26 11:23:51: [472:4304:1] <-- 517-MX records for p5ycho.net violate section 3.3.9 of RFC 1035.
Mon 2004-01-26 11:23:52: [472:4304:1] <-- 517 Invalid domain, see <URL:ftp://ftp.isi.edu/in-notes/rfc1035.txt>
Mon 2004-01-26 11:23:52: [472:4304:1] --> QUIT
Mon 2004-01-26 11:23:52: [472:4304:1] SMTP session abnormally terminated, 350 bytes transferred.
c/p uit RFC 1035:
3.3.9. MX RDATA format
    |                  PREFERENCE                   |
    /                   EXCHANGE                    /
where:
PREFERENCE      A 16 bit integer which specifies the preference given to
                this RR among others at the same owner.  Lower values
                are preferred.
EXCHANGE        A <domain-name> which specifies a host willing to act as
                a mail exchange for the owner name.
MX records cause type A additional section processing for the host
specified by EXCHANGE.  The use of MX RRs is explained in detail in
[RFC-974].
Ik ben even helemaal de kluts kwijt, zou iemand me even op weg kunnen helpen?
12x 280Wp ZO, 9x 280Wp + 8x 465Wp ZW, Zubadan SHW80YAA 8kW, Zehnder Q450 ERV
  • Korakal
  • Laatst online: 08:20
Korakal
Up up up!
Algemene regels hoe je op het forum te gedragen (Netiquette)
Hier had je zo langzamerhand wel mee bekend moeten zijn...
• Leg je probleem goed uit. Hetgeen jij zegt is namelijk het enige dat anderen van jouw probleem weten. Hoe meer (relevante) informatie je geeft, hoe beter je geholpen kunt worden
• Noem eventueel terzake doende omstandigheden en feiten (gebruikt OS, hardware etc).
• Maak duidelijk wat je zelf hebt geprobeerd en vertel waarom dit je niet verder geholpen heeft. Wees hierbij specifiek, zodat de info relevant is. "Ik heb niets gevonden" zegt niets.
• Geef eventueel linkjes naar websites die je hebt bezocht (en geef aan waarom die informatie niet voldoende was).
• Probeer er een duidelijk! verhaal van te maken dat door andere mensen prettig te lezen en goed te begrijpen valt!
Ik kan echt geen van de bovenstaande dingen in jouw copy/paste ontdekken. Sorry, maar dit is GEEN fatsoenlijke topicstart. Dicht.
Je mag het opnieuw proberen als je je aan de Netiquette houdt.
