Irc via website, code werkt niet
  • 72 views sinds 30-01-2008
Hoi,
Ik krijg deze code niet aan de praat:
Hij staat online op www.mediaplace.nl/fp/irc.php
heeft iemand hier verstand van? Het irc kanaal draait gewoon op Efnet #mediaplace
Gr. Paul :)
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
[BLOCK="_irc"]
<applet name="jchat" archive="http://www.phpfreakz.nl/chatfiles/jirc_nss.zip" code="Chat.class" width=580 height=400 align=middle>
<param name="CABBASE" value="http://www.phpfreakz.nl/chatfiles/jirc_mss.cab">
<param name="ServerPort" value="6667">
<param name="ServerName1" value="irc.efnet.nl">
<param name="Channel1" value="#mediaplace">
<param name="AllowIdentd" value="true">
<param name="IgnoeMOTD" value="true">
<param name="WelcomeMessage" value="Welcome to Mediaplace IRC">
<param name="RealName" value="Chatting from mediaplace.nl/">
<param name="NickName" value="Guest">
<param name="UserName" value="phpjunk">
<param name="isLimitedServers" value="true">
<param name="isLimitedChannels" value="true">
<param name="MessageCol" value="80">
<param name="BackgroundColor" value="239,239,239">
<param name="TextColor" value="black">
<param name="TextScreenColor" value="white">
<param name="ListTextColor" value="black">
<param name="TextFontName" value="Arial">
<param name="TextFontSize" value="12">
<param name="ConfigNickOnly" value="true">
<param name="NickNChannelOnly" value="true">
<param name="LogoBgColor" value="white">
<param name="BorderVsp" value="2">
<param name="DirectStart" value="false">
<param name="FGColor" value="black">
<param name="TitleBackgroundColor" value="black">
<param name="TitleForegroundColor" value="white">
<param name="InputTextColor" value="black">
<param name="InputScreenColor" value="white">
<param name="IgnoreLevel" value="3">
<param name="DisplayConfigRealName" value="false">
<param name="DisplayConfigServer" value="false">
<param name="DisplayConfigPort" value="false">
<param name="DisplayConfigMisc" value="false">
<param name="IgnoreServerMsg" value="true">
<param name="AliasList" value="/m=/msg,/t=/topic,/j=/join">
<param name="FieldNamePrivateChatTitle" value="Prive Chat: ">
<param name="FieldNameConnected" value="Connecting to server, please wait!" >
<param name="LicenseKey" value="2705057969-336533786034827600938166828877-6688888655090917171714866686316034827600140428098566828814866686-336533786034827600938166828877">
</applet>
[/BLOCK]
Heb je zelf een fatsoenlijke Java VM geinstalleerd?
En wat zou er niet moeten werken dan?
Verwijderd schreef op 25 januari 2004 @ 20:41:
Als het goed is gebruikt het script de JAVA van phpfreakz, zie de code
Je ziet wel staan:
Load class: Chat not found
Maar die moet er wel zijn, zitten 300 man in, dus klopt er iets niet!
de code is gejat van phpfreakz idd die het applet netjes hebben gekocht op
http://www.jpilot.com/ en daarom werkt het bij hun wel en bij jou niet.
  • whoami
  • Laatst online: 30-10 12:27
Hoi, dit is niet iets wat we in P&W willen.
Je hebt een script gedownload, je krijgt het niet aan de praat, en dan mogen wij het hier in P&W proberen op te lossen? Sorry, maar zo werkt het hier niet.
Ondersteuning voor scripts van derden leveren we hier niet, en aan topics waarin gewoon code gedumpt wordt, met de vermelding, misschien krijgt hier iemand het aan de praat, doen we ook niet mee.
Je kan misschien even de P&W Quickstart lezen.
[ Voor 9% gewijzigd door whoami op 25-01-2004 20:59 ]
https://fgheysels.github.io/
