See com.borland.dx.dataset.DataSetException error code:
  • 432 views sinds 30-01-2008
Dit is de volledige foutmelding die ik krijg al ik reslutaten wil toevoegen aan de database:
Kan iemand mij hiermee helpen?
See com.borland.dx.dataset.DataSetException error code: BASE+62
com.borland.dx.dataset.DataSetException: Execution of query failed.
at com.borland.dx.dataset.DataSetException.a(Unknown Source)
at com.borland.dx.dataset.DataSetException.queryFailed(Unknown Source)
at com.borland.dx.sql.dataset.QueryProvider.a(Unknown Source)
at com.borland.dx.sql.dataset.JdbcProvider.provideData(Unknown Source)
at com.borland.dx.dataset.StorageDataSet.refresh(Unknown Source)
at com.borland.dx.sql.dataset.QueryDataSet.refresh(Unknown Source)
at com.borland.dx.sql.dataset.QueryDataSet.executeQuery(Unknown Source)
at HerkansingsOpdracht.InvoerUitslagen.getId(InvoerUitslagen.java:124)
at HerkansingsOpdracht.InvoerUitslagen.jButton1_mouseReleased(InvoerUitslagen.java:103)
at HerkansingsOpdracht.InvoerUitslagen$1.mouseReleased(InvoerUitslagen.java:83)
at java.awt.AWTEventMulticaster.mouseReleased(AWTEventMulticaster.java:228)
at java.awt.Component.processMouseEvent(Component.java:5134)
at java.awt.Component.processEvent(Component.java:4931)
at java.awt.Container.processEvent(Container.java:1566)
at java.awt.Component.dispatchEventImpl(Component.java:3639)
at java.awt.Container.dispatchEventImpl(Container.java:1623)
at java.awt.Component.dispatchEvent(Component.java:3480)
at javax.swing.plaf.basic.BasicInternalFrameUI$GlassPaneDispatcher.retargetMouseEvent(BasicInternalFrameUI.java:1407)
at javax.swing.plaf.basic.BasicInternalFrameUI$GlassPaneDispatcher.forwardMouseEvent(BasicInternalFrameUI.java:1343)
at javax.swing.plaf.basic.BasicInternalFrameUI$GlassPaneDispatcher.mouseReleased(BasicInternalFrameUI.java:1273)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:3450)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:3165)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:3095)
at java.awt.Container.dispatchEventImpl(Container.java:1609)
at java.awt.Window.dispatchEventImpl(Window.java:1590)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:450)
at java.awt.EventDispatchThread.pumpOneEventForHierarchy(EventDispatchThread.java:197)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:150)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:144)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:136)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:99)
Chained exception:
java.sql.SQLException: [Microsoft][ODBC Microsoft Access-stuurprogramma] Er zijn te weinig parameters. Het verwachte aantal is: 1.
at sun.jdbc.odbc.JdbcOdbc.createSQLException(JdbcOdbc.java:6879)
at sun.jdbc.odbc.JdbcOdbc.standardError(JdbcOdbc.java:7036)
at sun.jdbc.odbc.JdbcOdbc.SQLExecute(JdbcOdbc.java:3104)
at sun.jdbc.odbc.JdbcOdbcPreparedStatement.execute(JdbcOdbcPreparedStatement.java:214)
at sun.jdbc.odbc.JdbcOdbcPreparedStatement.executeQuery(JdbcOdbcPreparedStatement.java:89)
at com.borland.dx.sql.dataset.o.f(Unknown Source)
at com.borland.dx.sql.dataset.QueryProvider.e(Unknown Source)
  • curry684
  • Laatst online: 04-09 14:38
curry684
left part of the evil twins
Ja doei, lees de sluitmessages bij Ik zit vast met JBuilder..Help!!! nog eens rustig door :O
Professionele website nodig?
  • Kees
  • Laatst online: 31-10 19:33
Kees
Serveradmin / BOFH / DoC
tss, tis al een herkansing? ;)
Maar wat staat er op die regels code, daar gaat het dus fout ergens, en het gaat fout in de dataset (dus zoek eens op waarom die gegooit wordt?)
