[asp] Shopping cart met array in database krijgen
Hallo allemaal!
Ik ben bezig een e-commerce site te maken voor school, en ik heb een shopping cart met een array gemaakt. De code is als volgt:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
<!--#include file="beveilig.asp"-->
<HTML>
<HEAD>
<META NAME="GENERATOR" Content="Microsoft FrontPage 4.0">
<title></title>
</HEAD>
<BODY bgcolor="#0066CC">
Const Cartpid = 0
const Cartpname = 1
const cartpprice = 2
const cartpquantity = 3
if not isarray(session("cart")) then
    dim localCart(4,20)
else
    localCart = session("cart")
end if
productID = trim(request("pid"))
ProductName = trim(request("productName"))
ProductPrice = trim(request("productprice"))
if productID <> "" then
    foundIT = false
    for i = 0 to ubound(localcart)
        if localcart(cartpid, i) = productID then
            localcart(cartpquantity, i) = localcart(cartpquantity, i) + 1
            foundIT = true
            exit for
        end if
    next
    if not foundIT then
        for i = 0 to ubound(localcart, 2)
            if localcart(cartpid, i) = "" then
                localcart(cartpname, i) = productName
                localcart(cartpprice, i) = productprice
                localcart(cartpquantity, i) = 1
                exit for
            end if
        next
    end if
end if
if request("updateQ") <> "" then
        newQ = trim(request("pq" & localcart(cartpid, i)))
        deleteProduct = trim(request("pd" & localcart(cartpid, i)))
        if newQ = "" or newQ = "0" or deleteProduct <> "" then
        else
            if isnumeric(newQ) then
                localcart(cartpquantity, i) = newQ
            end if
        end if
    next
end if
Session("cart") = localcart
<font face="Comic Sans MS" size="4" color="#CCFFFF"><i><b>Winkelwagentje</b></i></font>
<hr>
<p>
<center>
<font face="arial" size=3 color="darkgreen"
<b>Uw winkelwagentje:
</font>
orderTotal = 0
</p>
<form method="post" action="Winkelwagentje.asp">
<input name="updateQ" type="hidden" value="1">
<table bgcolor="lightyellow" border=1
    cellpadding=4 cellspacing=0>
<tr bgcolor="lightgreen">
    <th>Product</th>
    <th>Prijs</th>
    <th>Hoeveelheid</th>
</tr>
for i = 0 to ubound(localcart,2)
if localcart(cartpid, i) <> "" then
    ordertotal = ordertotal + (localcart(cartpprice, i) * localcart(cartpquantity, i))
<tr>
    <td>
    <%=Server.HTMLEncode(localcart(cartpname, i))%>
    </td>
    <td>
    <%=formatCurrency(localcart(cartpprice, i))%>
    </td>
    <td>
    <input name="pq<%=localcart(cartpid, i)%>" type="text" size=4
        value="<%=localcart(cartpquantity, i)%>">
    <input name="pd<%=localcart(cartpid, i)%>" type="checkbox" value="1"> Verwijderen
    </td>
</tr>
end if
next
<tr bgcolor="yellow">
    <td colspan=2 align=right>
    <b>Totaal bedrag bestelling:</b>
    </td>
    <td>
    <%=formatCurrency(orderTotal)%>
    </td>
</tr>
<tr>
    <td colspan=3>
    <table border=0>
    <tr>
        <td align="right">
        <input type="submit" value="Winkelwagentje bijwerken">
        </td>
        </form>
        <form method="post" action="checkout.asp">
        <td>
        <input type="submit" value="Bestelling definitief maken">
        </td>
        </form>
        <form action="winkelen.asp">
        <td>
        <input type="submit" value="Doorgaan met winkelen">
        </td>
        </form>
    </tr>
    </table>
    </td>
</tr>
</table>
</center>
</BODY>
</HTML>
Deze shopping cart werkt perfect, alleen als de klant zijn bestelling definitief wil maken moet alle inhoud van de cart in een database komen(checkout.asp). En hier ligt mijn probleem. Ik weet niet hoe dit moet. (sorry, ik ben een asp virgin). Ik ben al 2 dagen aan het kloten met dit, en ik kom er gewoon niet uit! Ik hoop dat jullie me kunnen helpen, want ik wordt er helemaal gek van! Bij voorbaat dank!
[ Voor 20% gewijzigd door Verwijderd op 21-01-2004 15:12 ]
  • faabman
  • Laatst online: 08-08-2024
zou je eerst je html / script ff tussen [code] tags willen zetten??
daarnaast moet je in de pagina waarin je je winkelwagentje in de db gooit een aantal inserts doen aan de hand van de hoeveelheid producten in je wagentje
for I = 0 To Ubound(arr_winkelwagentje, 2)
  '// doe hier je insertquery
next
damn, zit weer te slapen achter me compie... er moet wel ff een 2 bij de ubound komen te staan
[ Voor 84% gewijzigd door faabman op 21-01-2004 15:20 ]
Op zoek naar een baan als Coldfusion webdeveloper? Mail me!
  • Jaspertje
  • Laatst online: 29-10 15:50
Jaspertje
Max & Milo.. lief
Misschien kan het met split, en dan elk item in de db wegschijven
Gebruik eens code tags om je code heen
ASP:
for each item in split(array, ",")
  Conn.execute(SQL)
next
en misschien kan je alleen relevante code laten zien
[ Voor 16% gewijzigd door Jaspertje op 21-01-2004 15:11 ]
  • supakeen
  • Laatst online: 09-09-2025
Kent ASP geen serialize functie :?
  • BasSpruit
  • Laatst online: 09-04-2022
Je hebt method="post" gebruikt, dus vraag je de variabelen in de volgende pagina op met:
 variabele = request.form("variabele_naam")
Ik raad je aan eerst een asp - faqje als www.w3schools.com of www.asp101.com
  • Jaspertje
Jaspertje
Max & Milo.. lief
ChaosDream schreef op 21 januari 2004 @ 15:12:
Inderdaad, wat heb je nu op Winkelwagentje.asp staan?
[ Voor 16% gewijzigd door Jaspertje op 21-01-2004 15:14 ]
FvKnijff schreef op 21 januari 2004 @ 15:10:
for I = 0 To Ubound(arr_winkelwagentje)
next
Dit heb ik al geprobeerd, maar ik kreeg steeds de foutmelding
typen komen niet overeen: ubound
Jaspertje schreef op 21 januari 2004 @ 15:13:
Kan dit request.form ook met een array? Want ook request.form had ik al geprobeerd, maar ook zo kreeg ik mijn informatie niet uit mijn array
  • gorgi_19
  • Laatst online: 30-10 13:06
gorgi_19
Kruimeltjes zijn weer op :9
zmn schreef op 21 januari 2004 @ 15:11:
Nope
Digitaal onderwijsmateriaal, leermateriaal voor hbo
  • Jaspertje
Jaspertje
Max & Milo.. lief
Verwijderd schreef op 21 januari 2004 @ 15:19:
Ik weet niet waar je die array hebt staan, hoe je die vasthoudt.. als dat in een hidden field is.. doe dan gewoon request.form("hierdenaam")
Anders moet je ook eens response.write Session("cart") doen (volgens mij houdt die de array vast of niet?)
Jaspertje schreef op 21 januari 2004 @ 15:33:
Ja, de array localcart worden vastgehouden door session("cart")
en ik heb nu op de pagina checkout.asp response.write session("cart") gezet en dan krijg ik de foutmelding een incorrect datatype is aangetroffen...
  • Jaspertje
Jaspertje
Max & Milo.. lief
Gebruik je quotes in je array (weet niet of het uitmaakt hoor!)
