Verdwijnende blocks?? Of gewoon veel dupes?
  • Burat
Burat
bos wortels
Een stuk uit m'n pper log:
<FONT FACE="Courier" SIZE=2>
2000-12-10 14:56:00,rc564 r=20820/22663, d=351771/500000, 44.2 Mkeys/sec, tot=76725
2000-12-10 14:56:00,ogr r=20/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
2000-12-10 14:56:00,Status: Uptime: 16.08:35:58, 2 listeners, 0 uplinks
2000-12-10 14:56:00,Status: 0 active clients (peak: 4, mean: 0.00)
2000-12-10 14:56:31,rc564 r=20820/22663, d=351771/500000, 44.2 Mkeys/sec, tot=76725
2000-12-10 14:56:31,ogr r=20/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
2000-12-10 14:56:31,Status: Uptime: 16.08:36:29, 2 listeners, 0 uplinks
2000-12-10 14:56:31,Status: 0 active clients (peak: 4, mean: 0.00)
2000-12-10 14:56:44,Status: Shutting down listeners...
2000-12-10 14:56:44,Status: Closing client connections...
2000-12-10 14:56:44,Status: Closing uplink connections...
2000-12-10 14:56:44,*Break* Initiating shutdown.
2000-12-10 14:56:44,Shutting down contests.
2000-12-10 14:56:46,Proxy shutdown complete.
2000-12-10 15:12:14,distributed.net Personal Proxy (build 318)
2000-12-10 15:12:14,Visit http://www.distributed.net/ for details.
2000-12-10 15:12:14,Proxy starting up.
2000-12-10 15:12:14,Verbosity set to: general stats keyblock server client buffers timestamp attention errlow errsevere (3519)
2000-12-10 15:12:14,rc564-in: limits adjusted to min 30, max 1000
2000-12-10 15:12:16,desII-in: limits adjusted to min 1, max 20
2000-12-10 15:12:16,csc-in: limits adjusted to min 1, max 20
2000-12-10 15:12:16,Notice: connectivity mode is normal
2000-12-10 15:12:16,Notice: Loaded 0 ignoredip addresses from ini file
2000-12-10 15:12:16,Notice: Loaded 0 allowedip addresses from ini file
2000-12-10 15:12:16,Notice: Primary listener bound to (all devices):2064
2000-12-10 15:12:16,Notice: Test listener bound to (all devices):3064
2000-12-10 15:12:17,Status: Uplink needed... (thresholds exceeded)
2000-12-10 15:12:17,Status: Creating uplink (outgoing server) connection.
2000-12-10 15:12:17,rc564 r=20820/1000, d=220665/20, 0.0 Mkeys/sec, tot=0
2000-12-10 15:12:17,ogr r=20/20, d=0/3, 0.0 Mnodes/sec, tot=0 stubs
2000-12-10 15:12:17,Status: Uptime: 0.00:00:00, 2 listeners, 0 uplinks
2000-12-10 15:12:17,Status: 0 active clients (peak: 0, mean: 0.00)
2000-12-10 15:12:18,Uplink: [1] connection to 130.161.38.10 changed state
2000-12-10 15:12:18, from 0 (ESTNONE) to 1 (ESTCONNWAIT)
2000-12-10 15:12:18, from 1 (ESTCONNWAIT) to 50 (ESTREADY)
2000-12-10 15:12:19,Uplink: [1] Establishing handshake with 130.161.38.10...
2000-12-10 15:12:19,Uplink: [1] Server is running version 321.
2000-12-10 15:12:19,Uplink: [1] Got permission acknowledgement.
2000-12-10 15:12:19,Uplink: [1] The fullserver says: "This field should contain the proxymessage (ivo/1)"
2000-12-10 15:15:26,server: --> uplink rc564 x 1 651ea20a:10000000
2000-12-10 15:15:26,server: --> uplink rc564 x 1 654695b8:d0000000
2000-12-10 15:15:26,server: --> uplink rc564 x 1 65b5e5a7:10000000
2000-12-10 15:15:26,server: --> uplink rc564 x 1 6518c463:70000000
</FONT>
Waarom had ik eerst 351771 workunits en dan ineens zonder waarschuwing of melding maar 220665??? Veel te wazig. Van de 220665 zijn er ongeveer 203000 aangekomen bij Dnet, das logisch, er zaten wat randoms enzo bij..
Maar waar zijn in vredesnaam die 130.000 workunits heen gegaan?? Ik snap er nix van.
Homepage | Me @ T.net | Having fun @ Procurios | Collega's gezocht: Webontwikkelaar PHP
  • crisp
  • Laatst online: 12:06
crisp
Devver
Pixelated
Is gebeurd tijdens de shut-down blijkbaar. Heb je toen iets gedaan met de buffs?
Intentionally left blank
  • Burat
Burat
bos wortels
Nope. Een shutdown via PC AnyWhere (zoals normaal). Daarna even naar beneden gelopen en een toetsenbord, muis en monitor aan de server gehangen en geflushed. Moest eerst shutdownen om in de ini de min/max op 10/20 te zetten zodat ie werd geleegd..
NIETS raars gedaan dus.
  • Burat
Burat
bos wortels
Weet niemand hier iets over?? Onbekend probleem?
was hij niet met een uplink bezig toen jij hem afsloot? in het log staat namelijk
Misschien moet je verder terugkijken. en zie je daar een uplink naar de server, maar is die om een of andere hik niet afgesloten of wacht op een time-out.
