windows2000 cpu 100%
Sinds een maand heb ik last van cpu die naar 100% stijgt, vnl. bij frontpage en bij photo shop.
- schijven gedefragmenteerd
- Spybot search en destroy uitgevoerd
- heb nu HijackThis uitgevoerd met onderstaande log als gevolg :
Logfile of HijackThis v1.97.7
Scan saved at 15:48:14, on 18-1-2004
Platform: Windows 2000 (WinNT 5.00.2195)
MSIE: Internet Explorer v5.00 (5.00.2920.0000)
Running processes:
C:\WINNT\System32\smss.exe
C:\WINNT\system32\winlogon.exe
C:\WINNT\system32\services.exe
C:\WINNT\system32\lsass.exe
C:\WINNT\system32\svchost.exe
C:\WINNT\system32\spoolsv.exe
C:\Program Files\Common Files\Symantec Shared\ccEvtMgr.exe
C:\Program Files\Norton Internet Security\NISUM.EXE
C:\Program Files\Norton Internet Security\ccPxySvc.exe
C:\WINNT\System32\svchost.exe
C:\Program Files\Norton AntiVirus\navapsvc.exe
C:\WINNT\system32\regsvc.exe
C:\WINNT\system32\MSTask.exe
C:\WINNT\Explorer.exe
C:\WINNT\System32\WBEM\WinMgmt.exe
C:\PROGRA~1\COMMON~1\SCM\ICONFIG.EXE
C:\WINNT\System32\taskmgr.exe
C:\Program Files\Internet Explorer\IEXPLORE.EXE
C:\WINNT\System32\spool\DRIVERS\W32X86\3\E_S00MT1.EXE
C:\Program Files\Common Files\EPSON\EBAPI\EBRR.EXE
C:\WINNT\System32\spool\DRIVERS\W32X86\3\E_S00RN1.EXE
C:\Documents and Settings\Administrator\Local Settings\Temporary Internet Files\Content.IE5\AFK74FO9\HijackThis[1].exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://www.msn.nl
R0 - HKCU\Software\Microsoft\Internet Explorer\Toolbar,LinksFolderName = Koppelingen
O1 - Hosts: 172.31.241.51 jaba1991
O1 - Hosts: 172.31.241.52 jaba2d71
O1 - Hosts: 172.31.241.54 pc
O2 - BHO: (no name) - {06849E9F-C8D7-4D59-B87D-784B7D6BE0B3} - C:\Program Files\Adobe\Acrobat 5.0\Acrobat\ActiveX\AcroIEHelper.ocx
O2 - BHO: NAV Helper - {BDF3E430-B101-42AD-A544-FADC6B084872} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O3 - Toolbar: @msdxmLC.dll,-1@1043,&Radio - {8E718888-423F-11D2-876E-00A0C9082467} - C:\WINNT\System32\msdxm.ocx
O3 - Toolbar: Norton AntiVirus - {42CDD1BF-3FFB-4238-8AD1-7859DF00B1D6} - C:\Program Files\Norton AntiVirus\NavShExt.dll
O4 - HKLM\..\Run: [Synchronization Manager] mobsync.exe /logon
O4 - HKLM\..\Run: [PE2CKFNT SE] C:\Program Files\Ulead Systems\Ulead Photo Express 2 SE\ChkFont.exe
O4 - HKLM\..\Run: [ICONFIG] C:\PROGRA~1\COMMON~1\SCM\ICONFIG.EXE
O4 - HKLM\..\Run: [ccApp] "C:\Program Files\Common Files\Symantec Shared\ccApp.exe"
O4 - HKLM\..\Run: [ccRegVfy] "C:\Program Files\Common Files\Symantec Shared\ccRegVfy.exe"
O9 - Extra button: Related (HKLM)
O9 - Extra 'Tools' menuitem: Show &Related Links (HKLM)
O12 - Plugin for .mid: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin.dll
O12 - Plugin for .mov: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin.dll
O12 - Plugin for .spop: C:\Program Files\Internet Explorer\Plugins\NPDocBox.dll
O12 - Plugin for .swf: C:\Program Files\Netscape\Communicator\Program\PLUGINS\NPSWF32.dll
O12 - Plugin for .wav: C:\Program Files\Internet Explorer\PLUGINS\npqtplugin.dll
O14 - IERESET.INF: START_PAGE_URL=http://www.msn.nl
O14 - IERESET.INF: MS_START_PAGE_URL=http://www.msn.nl
O16 - DPF: {33564D57-0000-0010-8000-00AA00389B71} - http://download.microsoft...-94901338C922/wmv9VCM.CAB
O16 - DPF: {C3DFA998-A486-11D4-AA25-00C04F72DAEB} (MSN Photo Upload Tool) - http://sc.communities.msn.com/controls/PhotoUC/MsnPUpld.cab
O16 - DPF: {D27CDB6E-AE6D-11CF-96B8-444553540000} (Shockwave Flash Object) - http://active.macromedia.com/flash2/cabs/swflash.cab
O17 - HKLM\System\CCS\Services\Tcpip\..\{BA306836-71BE-47B8-B916-B9BD822818DD}: NameServer = 213.151.60.2 212.35.2.2
Kan iemand mij hier wegwijs in maken ?
Zijn er nog dingen die ik kan checken ? om te weten te komen hoe ik dit probleem kan detecteren en oplossen ?
hartelijk dank,
Ingrid
  • Spider.007
Spider.007
* Tetragrammaton
Hmmm.. Je gooit een HiJackThis log neer en wij mogen het uitzoeken :? Bovenaan staat een knop; search... Kijk daar eens naar.
Is het trouwens niet meer dan logisch dat je CPU load stijgt naarmate je meer programma's opstart? Vanwaar dit plotselinge wantrouwen?
[ Voor 31% gewijzigd door Spider.007 op 18-01-2004 16:09 ]
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
  • Erazzzer
  • Laatst online: 15:33
Erazzzer
Fear me, I'm German!
als je in de taskmanager even kijkt wat precies het veroorzaakt?
  • G33rt
  • Laatst online: 22-06-2022
Heb je [rml][ Howto] Spyware scannen en opruimen[/rml] gezien? Daarmee kan je waarschijnlijk wel wegwijs worden met de output :)
Als ik de tekst ivm interpretatie log-file goed interpreteer dan denk ik niet dat ik hier een probleem heb. Schijven zijn gedefragmenteerd, heb tijdelijke internetbestanden ed. weggegooid, prog. spyware gedraaid, norton viruschecker. Toch heeft de pc problemen.
Symptomen zijn :
- soms tot 3keer opstarten alvorens ik echt opgestart geraak
- frontpage als ik pagina wil bekijken (voorbeeld) dan blijft de pc plots hangen idem bij photo shop
- bij andere programma's vb. schijf defragmentatie begon de pc te beepen (sirene) en had ik de kans om in de task manager te zien dat dat prog. ervoor zorgde dat hij aan 100 % zat.
De problemen zijn gestart na mijn abonementverlenging van Norton.
Ik heb 320 mb ram geheugen, ik dacht nu eerst dat uit te breiden en dan nog eens te evalueren of het beter gaat.
In elk geval dank je wel voor de reacties,
Ingrid
Gooi NAV er dan eens(tijdelijK)af om te zien of het dan verholpen is.
Welke NAV versie gebruik je?
  • Rodyman
  • Laatst online: 08-06-2024
Rodyman
chillend
is je NAV toevallig niet 'verlopen' .. heb ik ook wel eens gehad met een nav uit 2002 (geloof ik)
