401s/411s --> 811s werkt!!!
  • 62 views sinds 30-01-2008
  • savale
  • Laatst online: 04-09 08:20
Er is een methode ontwikkeld waarmee lite on dvd writers van lite on van het type 401s ook dvd-r dvdtjes kan branden (kan normaal al1 dvd+r). dit is de zogenaamde 401s naar 411s modificatie:
http://liteon401s.front.ru/ 401S -> 411S
deze nieuwe patch zorgt voor een 411s naar 811s voor dvd writers van lite on (8x write speed) :) wel eerst even modden van 401s naar 411s indien je geen 411s hebt
http://www.speedlabs.tk/ 411S -> 811S
laat even weten hoe het gegaan is. en misschien kprobe resultaten?
dit berichtje komt vanaf een ander forum: www.atomicmpc.com.au
Latest Offical Announcememt 10:08PM
Annoucement Regarding the 411S->811S Program
Well it looks like somehow I have got the 411S->811S mod
Anyway email me at: BurnItHard@ssl-mail.com
Please do not email me Qs regarding anything. Also don't send a reply back (unless you actually didn't get what you were ment to be getting, (and if you don't know what your ment to be getting - don't ask.))
If you didn't get it - email me again. And I'll try a 2x time.
There are many replies and I will reply to ALL of them , but you have to realise two things; 1- There are a huge amount of people on the list and it will take time; 2- I have a life and I need sleep as well, so if I don't respond wait at least 24hrs & for the love of god DO NOT send me anymore emails telling me to hurry up - or you will not get the patch .
Please note the two email accounts which I set up have both gone over the limit so the email has been changed to the above (which is by the way: BurnItHard@ssl-mail.com) This email WILL WORK.
If you have sent me an email asking for the patcher and you have already D/L it from below, please do not email me again - all I'll do is keep sending you the app. per email (so if you send me 35 email asking for it - expext to get the app 35 times).
FAQ:
Q-can i use the polish hacked firmware? Or must I use another one? And where can I find it??
A-ok if i understand ya question the answer is yes ya do use the firmware on the polish site
Q-Where is this hacked firmware??
A- GO HERE: http://www.speedlabs.tk/
The contents of the patcher.nfo guide (for those that don't have it yet, parts have been removed for safety sake)
??????????????? 411s@811s EEPROM modification to improve upgrade: ????????????????&
i) Things to be aware of:
? This modification technique fixes the MAJOR problems with the other methods. DVD-R
(minus or negative) writing @ 2X and 4X is now possible with 411S@811S. It fixes the
freeze on lead out issues that were synonumous with the previous modification technique.
It goes without saying, it also fixes 8x writing with correct 8x write strategy.
? An EEPROM is like a drives unique fingerprint ? it is fine tuned for any given drive.
Putting a real 811S EEPROM right onto your 411S is just plain silly.
? This patcher corrects missing 8x calibration data, missing from the 411S drives.
? This EEPROM patcher is NOT a checksum correction method. Hence, it
will NOT allow you to use the REAL Liteon windows flashers, only the hacked ones.
This will be addressed in another release in the future
? If you patch your EEPROM with this patch, you can go back to a 411S drive at any time
via the use of ******* and a .bin of the latest 411S firmware, or even a flashfixed
official 411S Windows flasher.
? Lots of talk about the ?Safe? tool has materialised. While this method if MUCH safer
than the previous method of modification that originated from the Polish,
nothing is totally safe. It is naïve to think that ANY over clock is safe.
? As every laser diode is unique, every calibration is so. But it will work for 99% of people.
The other 1% - this issue is being worked on
? At this time we do not know if ALL DRIVES laser diodes are rated for the needed power
at 8x (ca. 30mW). It could potentialy be overpowered as it's only 4x rated (ca. 18mW).
We will know one day if the first drives fail permanently. Its unlikely however.
ii) Instructions
? Backup current EEPROM using *******. Put it somewhere SAFE.
To do this, run *******, select the 411S, go to the EEPROM tab then hit READ, then SAVE.
? Open patch tool executable
? Browse to where a backup of current EEPROM is located or drag and
drop EEPROM file to patch tool window. It will make a safe backup copy of the original
? Once finished, run ******* and using the EEPROM tab, LOAD the newly modified EEPROM into ********
then WRITE the new newly modified EEPROM onto your drive.
? Reboot computer
Your EEPROM is now corrected for 8x +R writing.
NB: Remember - you need a HACKED firmware to successfully implement this modification. These are easily
found! At the time of writing HS0K (hacked) is easily attainable!
Finally - if you break/hurt/mame/destroy/melt your drive in the process of your tweaking/OCing adventures,
DONT be a selfish little twerp! BUY A NEW ONE - DONT WHINGE TO LITEON FOR A REPLACEMENT! YES, BUY A NEW ONE.
The company gives the enthusiast community a great deal of pleasure! The least you can do is be honest and
buy a new one if your adventures result in a nuked drive.
******** = L-T-N-F-L-A-S-H
Thanks Zebra, Amphetamine, SSseth .
ps. misschien wil een modje ff de topic titel aanpassen (ff lite-on ervoor zetten)
[ Voor 15% gewijzigd door savale op 13-01-2004 08:35 ]
  • Notna
  • Laatst online: 21:43
Notna
Where are you?®
Door het te lezen kwam ik er pas achter waar het over ging :/
Maar is dit om op de FP te zetten :?
Xbox Live ID:Notna8310
  • savale
Notna schreef op 13 januari 2004 @ 08:23:
ja is misschien btje onduidelijk maar het gaat om een firmware/eeprom hack waarmee lite on 401s drives kunnen worden gemod naar 411s en 811s (deze laatste is dus net uit en zorgt voor een schrijfsnelheid van 8x ipv 4x) :)
  • Flappie
  • Laatst online: 11-09 12:03
Okee... en waar gaat dit over? :)
  • savale
Flappie schreef op 13 januari 2004 @ 08:27:
ben al bezig mijn beginpost wat aan te passen, was iets te enthousiast met posten denk hahaha
  • BalusC
BalusC
Carpe diem
» LDW-401S flashen naar LDW-411S/811S
[ Voor 25% gewijzigd door BalusC op 13-01-2004 08:46 ]
