Native SATA?
  • Lev
  • Registratie: December 1999
  • Laatst online: 27-02-2018
Lev
Oldskool Tweaker
"Uit verschillende testen blijkt dat de performancekroon door Hitachi wordt gedragen, de stilteprijs altijd naar Seagate gaat en dat verder de 7200.7 van Seagate als enige native ondersteuning van Serial ATA biedt."
kan iemand me vertellen wat native s-ata inhoudt?
  • Mr.Nobody
Seagate Technology, a Native in Serial ATA The true Seagate "native" Serial
ATA solution offers customers the "real McCoy" in Serial ATA technology. By
implementing Serial ATA technology not only on the physical layer of the
drive but also in the controller, Seagate drives can communicate directly
from the drive to the host-up to the full 150-Mbytes/sec speed on the bus.
In addition, the native solution incorporates command queuing, which can be
a big performance boost in operating systems that can take advantage of that
type of function.
Some drive manufacturers may not immediately offer these "native" Serial ATA
features on their first-generation Serial ATA drives. Native Serial ATA =
150-Mbytes/sec bus speed, command queuing support, superset feature ready (for example, first party DMA) -A True Serial ATA Controller, Not Just a Translator Bridge Chip
An alternate way to quickly integrate Serial ATA onto
a drive is to use a "bridge" solution: the drive manufacturer inserts a
data serializer/de-serializer function before the data is sent or received
by the on-board ATA controller. Data on a bridged Serial ATA solution can
only be sent or received as fast as the ATA controller works. Since the
serial functionality is not natively tied to the drive controller link and
transport layers but is a separate function that translates data for a
parallel controller, it can only transfer at the parallel controller's
speed-100 or 133 Mbytes/sec.
linkje: http://groups.google.com/...corp.supernews.com&rnum=1
[ Voor 9% gewijzigd door Mr.Nobody op 13-01-2004 00:37 ]
Opensource delphi componenten (http://www.delphi-jedi.org)
  • BalusC
BalusC
Carpe diem
Grofweg gezegd betekent dat dus dat het een "pure" SATA harddisk is. Van grond af opgebouwd als een SATA HDD :) Veel vroege SATA harddisks zijn namelijk gewoon IDE schijven met een SATA convertertje ("bridge solution" in dat artikel).
De WD Raptor is overigens ook een "native SATA harddisk" ;)
  • Domino
  • Registratie: Juli 1999
  • Laatst online: 18:39
BalusC schreef op 13 januari 2004 @ 08:08:
Weet je dat zeker? Ik geloof dat er op mijn WD360GD ook zo een marvel converter op zit. Misschien alleen bij de nieuwe 74 GB?
  • Shuriken
  • Laatst online: 18:35
Shuriken
Life is all about priorities
Ja de eerste Raptor is zeker geen Native S-ATA.
Zie hier: http://www6.tomshardware.com/storage/20030501/wd360-05.html
I rather have a bottle in front of me, then a frontal lobotomie
