utopia problemen met browser
  • 103 views sinds 30-01-2008
  • Lord_T
  • Laatst online: 16-10 18:59
Hi heb wat problemen met Utopia...
Hij komt heel erg vervelend vaak met een melding dat ik cookies moet toestaan en dat er een bekend probleem is met IE6.0 enzo...
Nou heb ik cookies toegestaan... heb zelfs u1.swirve.com / a.swirve.com / b.swirve.com in de vertrouwde websites staan, maar werkelijk mag niets baten.
Iemand met een oplossing voor IE6.0 gebruikers?
Sorry, but you've reached this page in the wrong way.
This page is a part of the Utopia interactive multiplayer web game. If you are seeing this message and were playing the game normally, try clicking your selected link again - this error may come up occassionally due to server congestion. Otherwise, please let us know in our Bug Reports section. Additionally, check the following:
1. Be sure you have cookies activated on your web browser
2. If you have a Firewall, try deactivating it or allowing access to Swirve.com, as it may otherwise block cookies and/or referer information.
3. Please try the Browser Compatibility option to see if it can provide any useful information.
NOTE: This problem appears to occur with Internet Explorer 6.0 for as-of-yet unknown reasons. You may have to lower the Security Policy on Cookies to allow IE6.0 to send us the cookies used to run Utopia. We are still looking into both the cause and solution for this problem. For a temporary solution, please try the following in Internet Explorer:
1. Go to Tools / Options / Privacy. Make sure your Security Settings are set no higher than "Medium". Alternatively, under the Web Sites option, you can specify to allow your browser to accept all cookies from "swirve.com".
2. Go to Tools / Options / General. Under Temporary Files, select Delete Cookies to delete all temporary cookies.
3. Close all open instances of your browser.
4. Come back to Utopia and try logging in from there.
ja ja... niet iedereen heeft dezelfde kennis... wees daarom ook eens gewillig en geef een antwoord op een vraag ;)
  • Jaymz
  • Laatst online: 18:29
Jaymz
Keep on moving !
SGD -> SPV :)
  • Lord_T
*bump*
alleen in vertrouwde pagina`s zetten is niet genoeg, er kunnen koekjes van sites binnen willen komen waar je zo gauw nix van af weet, dus zet even je beveiliging op laag (bij extra>internetopties>beveiliging) en probeer ut nog eens.
DA King, Mark
  • Lord_T
helaas geprobeerd maar mocht niet baten...
nog een andere oplossing?
Ik heb er even de boeken voor je open geslagen.... Ja, bedankt me later maar :P
En ik ben achter het volgende gekomen:
Het is dus weer zo`n leuk microsoft zeik-gedoe. Ze zeggen dat ze bepaalde dingen niet toelaten op je browser om de gebruikers te "beschermen". Een of andere nieuwe "beveiliging" die bij IE6 zit. Zo dus dat jij je utopia niet kunt spelen. Dit is dus duidelijk weer zo`n microsoft-monopoly situatie, waar zij dus de lakens uitdelen.
MAARRRRR, je hebt geluk, hoop ik... Nadat microsoft enorm veel klachten had binnen gekregen van zowel developers als gebruikers, hebben ze deze gigantische blunder aangepast in de nieuwste servicepacks/updates. Welke is mij ook een raadsel, maar zorg dus dat je ff alle service packs installeerd en kijk of alle XP files up to date zijn. Dan moet volgens microsoft het probleem verholpen zijn.... Ben er bang voor eigenlijk, maarja tis het proberen waard he
DA King, Mark
