mohaa probleem
  • 64 views sinds 30-01-2008
Als ik mohaa geïnstalleerd heb en wil spelen zegt ie dit... :? wat moet ik doen?
--- Common Initialization ---
Medal of Honor Allied Assault 1.00 win-x86 Dec 6 2001
----- FS_Startup -----
Current search path:
D:\Program Files\EA GAMES\MOHAA\main\Pak5.pk3 (259 files)
D:\Program Files\EA GAMES\MOHAA\main\Pak4.pk3 (593 files)
D:\Program Files\EA GAMES\MOHAA\main\Pak3.pk3 (669 files)
D:\Program Files\EA GAMES\MOHAA\main\Pak2.pk3 (4722 files)
D:\Program Files\EA GAMES\MOHAA\main\Pak1.pk3 (772 files)
D:\Program Files\EA GAMES\MOHAA\main\Pak0.pk3 (11175 files)
D:\Program Files\EA GAMES\MOHAA/main
18190 files in pk3 files
execing default.cfg
execing menu.cfg
execing newconfig.cfg
Config: unnamedsoldier.cfg
couldn't exec configs/unnamedsoldier.cfg
execing safemode.cfg
couldn't exec localized.cfg
execing autoexec.cfg
Unknown command "fov"
couldn't exec custom.cfg
...detecting CPU, found Intel Pentium III
------- Input Initialization -------
Initializing DirectInput...
Couldn't set DI coop level
Falling back to Win32 mouse support...
------- Input Initialization Complete ------- 32
You are now setup for easy mode.
----- Client Initialization -----
Called FadeSound with: 0.000000
----- Initializing Renderer ----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\SYSTEM\opengl32.dll' ): succeeded
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...registered window class
...created window@0,0 (640x480)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 16, 16, 0 )
...23 PFDs found
...GLW_ChoosePFD failed
...23 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
...assuming '3dfxvgl' is a standalone driver
...initializing QGL
...WARNING: missing Glide installation, assuming no 3Dfx available
GLW_StartOpenGL() - could not load OpenGL subsystem
  • Hahn
  • Laatst online: 16-10 20:20
Meer informatie geven, nieuwste drivers installeren en vertellen wat je zelf al hebt geprobeerd, dat zou je kunnen doen :)
The devil is in the details.
  • Han
Han
Goeie versie downloaden? :?
  • shockme
  • Laatst online: 02-06-2022
Ik zou zeggen een probleem met je videokaart
Lijkt erop dat je videokaart geen 3Dfx ondersteund?
Of wellicht niet de juiste videokaart drivers geinstalleerd
Post ff je specs van je systeem wel zo handig!
Videokaart NVidia Riva Tnt 2
model 64
  • Fuelke
  • Laatst online: 22:18
Fuelke
Forza Ferrari
Graag wat meer uitgebreide specs, hier kunnen we amper iets mee.
La Ferrari più bella è quella che dobbiamo ancore fare: La Prossima
  • Switch
  • Laatst online: 30-08 17:36
Dat staat in je error message, misschien moet je eens Googlen?
[google=missing Glide installation, assuming no 3Dfx available]
[google=GLW_StartOpenGL() - could not load OpenGL subsystem]
Er zijn vast nog wel andere query's :z
2e link @ Google beschrijft ook jouw probleem
Ik stel voor dat je wat beter je specs post, en dat je de nieuwste patches van Mohaa installeerd.
[ Voor 24% gewijzigd door Switch op 08-01-2004 16:08 ]
  • M.I.G.
  • Laatst online: 06-01 13:48
M.I.G.
[like an alien]
Heb je al geprobeerd te patchen naar de 1.11 versie?
Fuelke schreef op 08 januari 2004 @ 16:04:
pentium 3
windows me
1 ghz
256 mb ram
zoiets? zeg anders ff waar ik die dingen kan vinden want dat weet ik niet eens :S
  • Switch
Ik zou zeggen lees even Lees dit voor je een topic opent/een reply post! door. Ik wed dat je vast wel een oplossing vindt van het probleem via Google (zie mijn vorige reply voor directe links, aangezien je het waarschijnlijk niet snapt).
En als je niet weet waar je je specs kan vinden, zou ik zeggen, ben je geen materiaal voor GoT. Maar dat is compleet mijn mening en mag je ook gewoon negeren.
Nu ik je onderstaande post lees, denk ik dat je toch maar beter naar BeginnersWeb kunt gaan :Z
[ Voor 16% gewijzigd door Switch op 08-01-2004 16:18 ]
ja ik heb via google gezocht en ik denk dat ik ff nieuwe drivers moet installeren, dat heb ik nog nooit gedaan geloof ik :S hoe doe je dat precies?
  • shockme
idd wel zelf enig initiatief tonen door wat verder te kijken dan je neus lang is
bv ff nieuw drivertje installeren
http://download.nvidia.co...4/53.04_win9x_english.exe
bestandje downloaden, en uitvoeren, de rest volgt vanzelf!
[ Voor 17% gewijzigd door shockme op 08-01-2004 16:16 ]
shockme schreef op 08 januari 2004 @ 16:15:
is dat de goeie?
  • CamU
  • Laatst online: 08-10 15:19
ja
* Workstation * / * Server * / * Laptop * / Monica: My motto is: "get out before they go down". Joey: "That is so not my mott
  • DjGeRo
  • Laatst online: 18-10 10:59
  • leuk_he
  • Laatst online: 14-10 16:13
leuk_he
1. Controleer de kabel!
Kortom de oplossing is je video kaart drivers updaten volgens de meeste van deze google posts.
Hij zegt ook juist dat er iets fout is gegaan met de OPENGL initilisatie. Als laatste probeert hij nog terug te valen naar 3dfx glide drivers, maar dat is redelijk uit de tijd.
volgende faq van: Videoplanken & Beeldkanonnen
kun je die
FAQ Videoplanken & Beeldkanonnen (18/11/02)
hier vinden
*telt hoevaak deze vraag al langs is gekomen*... 150... 151... tevaak.
Zou je de search kunnen gebruiken voordat je iets vraagt? Maar vergeet ook niet zelf het een en ander te proberen, of wat meer informatie te geven als je er echt niet uitkomt. In Lees dit voor je een topic opent/een reply post! kan je ook de nodige info vinden.
Dicht dus :)
[ Voor 37% gewijzigd door Verwijderd op 08-01-2004 17:06 ]
