[WIN XP] Post sp1 hotfixes
  • 29 views sinds 30-01-2008
Hi,
Ik update mijn systeem regelmatig met hotfixes van microsoft, maar heel vaak kom ik ook KB artikelen tegen, die je niet zomaar kan downloaden.. Heeft iemand enig idee hoe deze te bemachtigen zijn ?
Ik zit al enige tijd achter onderstaande hotfixes aan, sommige bugs in XP erger ik me echt mateloos aan, vooral ''InstallShield 5.5 Setup May Run Slowly with the Bluetooth Supplement Installed'' en ''CD-RW Drive Does Not Eject Blank Media''
Heeft iemand enig idee hoe ik onderstaande hotfixes kan verkrijgen?
Q327897 - Sony DVMC-DA2 Converter Is Not Compatible with Video for Windows on Windows XP
Q319233 - Keypad "=" Key May Not Work on NEC PC98 USB Keyboard
Q326119 - Event Viewer May Show IrEvents Error 8205 If the Irmon Service Is Stopped
Q324230 - A Domain Driver-Signing Policy Is Not Applied
Q328070 - Netmeeting Does Not Disconnect When You Use It Through a Windows XP Firewall
Q328237 - Some Programs Do Not Work As Expected When Large Files Are Opened
Q328293 - "Close Open Files" Message Appears During Initial Folder Synchronization When You Do Not Have Files Open
Q329059 - Themed Programs May Stop Working During Long Operations
Q327575 - Cannot Log On One Time After an Administrator Uses Remote Desktop
Q330836 - Shortcuts to Mapped Drives on Windows 95 or Windows 98 May Not Work in Windows XP
Q810019 - InstallShield 5.5 Setup May Run Slowly with the Bluetooth Supplement Installed
Q812110 - Outlook Express May Hang When You Send Mail with a Long Line
Q816736 - CD-RW Drive Does Not Eject Blank Media
Q829637 - Programs That Run Correctly with Windows 2000 Do Not Run Correctly with Window XP
Q823291 - File List in the Windows Explorer Folder Is Not Refreshed After You Create, Move, or Delete Files
Q828929 - Ctfmon.exe Uses 100 Percent of the CPU When You Try to Change the Font Properties in Visual Basic for Windows
Q828940 - Wireless Client Cannot Reconnect to a Wireless Access Point
Q830987 - Some Devices Are Not Recognized When You Use Multiple IEEE 1394 (FireWire) Devices
Q831559 - The shortcut (.lnk file) is returned instead of the file or the folder that is referenced by the path in the shortcut in the Open or in the Save dialog box in Windows XP or in Windows Server 2003
Q830363 - Your video appears in the preview window for only a few seconds in your video capture program
Q833512 - Message Queuing cannot send messages to a target queue after the IP address changes
  • Zwelgje
  • Laatst online: 17-08 09:02
gewoon contact opnemen met support (telefonisch)
Ik heb dit ook netjes gedaan zoals op de pagina staat aangegeven, maar wat ik van hun te horen kreeg is dat deze hotfixes in SP2 uitkomen, en die zal voor het publiek te downloaden zijn :S
  • elevator
elevator
Officieel moto fan :)
Die hotfixes zijn private - zoals ook in die support articles te lezen is - het is dan ook niet toegestaan om ze onderling uit te wisselen, en aangezien het niet over echt hele belangrijke hotfixes gaat is dit een gebied wat we lieve niet betreden (zou het nu een security patch zijn oid zou het eerder toegestaan worden) :)
