[Slackware]scsi cdtower, hoe cd's mounten?
Ik heb hier een scsi cdrom tower met 7 cdroms erin.
Die heb ik op mijn scsi kaart aangesloten.
De situatie is als volgt:
0 -> adaptec, met 1cdrom en een hd waarvan sackware boot
1 -> adaptec met de cdtower
2 -> megaraid controller
dmesg geeft:
scsi0 : Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 6.2.36
aic7880: Ultra Wide Channel A, SCSI Id=7, 16/253 SCBs
scsi1 : Adaptec AIC7XXX EISA/VLB/PCI SCSI HBA DRIVER, Rev 6.2.36
aic7860: Ultra Single Channel A, SCSI Id=7, 3/253 SCBs
(scsi0:A:0): 10.000MB/s transfers (10.000MHz, offset 8)
Vendor: PIONEER Model: CD-ROM DR-U03S Rev: 1.01
Type: CD-ROM ANSI SCSI revision: 02
(scsi0:A:1): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi0:A:2): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi0:A:3): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi0:A:4): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi0:A:5): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi0:A:6): 10.000MB/s transfers (10.000MHz, offset 8)
(scsi1:A:1): 20.000MB/s transfers (20.000MHz, offset 15)
Vendor: FUJITSU Model: MAJ3091MP Rev: 5508
Type: Direct-Access ANSI SCSI revision: 04
(scsi1:A:5): 10.000MB/s transfers (10.000MHz, offset 15)
Vendor: NEC Model: CD-ROM DRIVE:464 Rev: 1.05
scsi1:A:1:0: Tagged Queuing enabled. Depth 32
megaraid: v2.00.9 (Release Date: Thu Sep 4 17:49:42 EDT 2003)
megaraid: found 0x101e:0x9010:bus 1:slot 13:func 0
scsi2:Found MegaRAID controller at 0xe890, IRQ:9
megaraid: [U.77:1.47] detected 1 logical drives.
megaraid: channel[0] is raid.
megaraid: channel[1] is raid.
megaraid: no BIOS enabled.
scsi2 : LSI Logic MegaRAID U.77 254 commands 16 targs 5 chans 7 luns
scsi2: scanning scsi channel 0 for logical drives.
Vendor: MegaRAID Model: LD0 RAID5 21090R Rev: U.77
Type: Direct-Access ANSI SCSI revision: 02
scsi2: scanning scsi channel 4 [P0] for physical devices.
Vendor: DELL Model: 6UW BACKPLANE Rev: 9
Type: Processor ANSI SCSI revision: 02
scsi2: scanning scsi channel 5 [P1] for physical devices.
Attached scsi disk sda at scsi1, channel 0, id 1, lun 0
Attached scsi disk sdb at scsi2, channel 0, id 0, lun 0
SCSI device sda: 17783239 512-byte hdwr sectors (9105 MB)
Partition check:
sda: sda1 sda2
SCSI device sdb: 43192320 512-byte hdwr sectors (22114 MB)
sdb: sdb1
De cdroms worden wel gezien, maar hoe kan ik ze mounten?Welk device moet ik nemen?
[ Voor 1% gewijzigd door moto-moi op 06-01-2004 18:30 ]
  • Tomaat
  • Laatst online: 13-05 13:50
sdc, sdd, sde, enz ?
Nee, dat werkt dus niet.
Had ik al geprobeerd twns ;)
Is er geen progje/commando dat je je scsi bus kan scannen op devices?
  • igmar
  • Laatst online: 09-09 19:53
igmar
ISO20022
Verwijderd schreef op 06 januari 2004 @ 18:28:
/dev/scd0, scd1, etc, etc.
  • voodooless
  • Laatst online: 09:37
voodooless
Sound is no voodoo!
Verwijderd schreef op 06 januari 2004 @ 18:44:
probeer eens cdrecord --scanbus, daarmee zie je niet alleen je branders, maar ook de rest van de scsi devices.
of anders /dev/scsi/host[x]/bus[x]/target[x]....
Do diamonds shine on the dark side of the moon :?
  • imdos
  • Laatst online: 09:50
imdos
I use FreeNAS and Ubuntu
Het kan ook nog /dev/sr0 of /dev/sg0 zijn. Dit zijn alle bekende devices wel hoor, meer zijn er niet ;)
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
