ASUS S5200 Notebook
  • 230 views sinds 30-01-2008
Topic over de asus s5200 ;)
Dit notebook bezit de volgende specs:
Ff in het kort:
Intel centrino 1.40GHz - 1.70GHz
2.5-inch HDD, Capacity up to 80GB*
12.1-inch TFT LCD
Battery Life up to 7.6 hours
Weight 1.35 Kg (!!!)
Ff in het lang:
Processor & Cache Memory Intel® Pentium® M Processor with 1.40-1.70 GHz.
1MB On-Die L2 Cache
Operation System Microsoft® Windows® XP Home/ Professional Edition
Microsoft® Outlook Express
Chipset Intel 855GME and ICH4-M Chipset
Main Memory 256 MB, DDR 333 SDRAM
1x uSO-DIMM socket expandable to 256MB*
* subject to the availability of memory module
Display 12.1-inch XGA (1024x768) TFT Display
252K colors max
Video Graphics & Memory Embedded Intel 855GME internal graphics
64MB VRAM shared for display cache with Intel DVMT technology
Hard Drive 2.5-inch 9.5mm IDE HDD with ATA 100 S.M.A.R.T. supported, 40/60/80 GB
Card Reader MMC, SD, Memory Stick , MS PRO flash card slot
Optical Drive* - External Slim Combo: Support USB 2.0, 24X/12X/24X/8X
- 2MB data buffer
- Dimension: 129 x 142 x 16mm(max.), 250g
*Subject to different areas
Floppy Drive (optional) External 1.44 MB USB Floppy Drive
Fax/Modem/ LAN - Pass and support worldwide regulation
- Integrated MDC Fax/ Modem
- V.92 / K56 flex support
- On board 10/100 Mbps Fast Ethernet controller, support full and half duplex mode
- Boot from LAN support
PC Card Slot PCMCIA 2.1 compliant
One type II/ I
32-bit PC CardBus 1.0 architecture
LED Status Indicator Power-on/Suspend
Battery Charging/full/low
Storage device access
Wireless indicator
Interface - 1 x Audio-out jack
- 1 x Microphone-in jack
- 1 x VGA port/Mini D-sub 15-pin for external DDC monitor
- 1 x RJ11 Modem jack for phone line
- 1 x RJ45 LAN Jack for LAN insert
- 3x USB 2.0 ports, 1 x IEEE 1394 port
- 1x Card Reader
Audio AC 97 S/W audio
Built-in speaker and microphone
Keyboard Full size 83 keys with MS Windows function keys
Hot Keys Instant launch Key
Function Keys:
Fn+F1 suspend switch
Fn+F2 Wireless switch
Fn+F3 e-mail
Fn+F4 Internet Explore
Fn+F5 Brightness down
Fn+F6 Brightness up
Fn+F7 LCD on/off
Fn+F8 LCD/CRT/TV-out switch display
Fn+F9 Touch-pad On/Off
Fn+F10 Volume on/mute
Fn+F11 Volume down
Fn+F12 Volume up
Pointing Device Built-in Touch pad pointing device
Battery Pack & Life 24WHr battery pack, 2.8 Hrs run-down life*
48WHr battery pack, 5.5 Hrs run-down life*
72WHr battery pack, 8.5 Hrs run-down life*,**
*The figure is based on Mobile Mark 2002 after activating ASUS Power4 Gear power-saving technology.
**available in Nov.2003
AC Adapter - Output: 19 V DC, 2.64 A, 50W
- Input: 100—240V AC, 50/60Hz universal
Dimension & Weight - 275 x 223 x 17-25 mm (WxDxH,)
- 1.35Kg (with 30W battery pack )
Security - Pre-OS Authentication by programmable key code
- BIOS Booting / HDD User Password
- Protection and security lock
- I/O lock
- Kensington lock hole provided
Accessories RF Mouse
Protection and Carrying bag
Bundled / Optional Accessories:
Ai-Flash
ASUS 24X Slim Combo
Ai-Remote
Bluetooth Dongle
USB 2.0 Hub
Multimedia Software* ASUSDVD XP V4.0
Power Director V2.5 ME
Medi@Show V2.0 SE
ASUS Screen-saver
Virus & Tool Software Trend PC-cillin 2002 180 days trial version
Adobe Acrobat Reader 5.0
NERO Express V5.5 (Subject to different areas)
ASUS Utility ASUS Probe V2.10
ASUS Live Update
ASUS Power4 Gear
ASUS Winflash
Warranty & support - 2-year limited Global hardware warranty
- On-line problem resolution through web interface (BIOS, Driver update)
- OS (Microsoft Windows XP) install/uninstall consultation
- Bundled software install/uninstall consultation
Iemand de laptop al binnen??
De mijne komt binnen 2 weken :9
Grt. Mattee
  • Pollewob
Als je geen echt gerichte vragen/problemen hebt is een topic als dit niet echt nuttig. Dicht dus :)
