[linux do_mremap kernel bug] patch al gezien?
  • usr-local-dick
http://cve.mitre.org/cgi-bin/cvename.cgi?name=CAN-2003-0985
En:
http://isec.pl/vulnerabilities/isec-0013-mremap.txt
Volgens de laatste URI zouden alle 2.x.x kernels vulnerable zijn.
Alleen ik kan (nog) nergens een patch vinden :(
Iemand al iets zien langs vliegen?
  • imdos
  • Laatst online: 09:50
imdos
I use FreeNAS and Ubuntu
2.4.24 is schijnbaar niet meer vulnerable daarom is deze kernel ook zo snel uitgebracht!
Verder weet ik niet meer dan jij....
pvoutput. Waarom makkelijk doen, als het ook moeilijk kan! Every solution has a new problem
  • Infern0
  • Laatst online: 20-08 13:36
Infern0
Hou die ontzettende rust!!
Even een copy van het Bugtraq bericht
Redhat, Engarde, Connectiva, Trustix en Suse hebben al nieuwe kernel (deze heb ik tenminste gezien op bugtraq)
Hash: SHA1
Synopsis: Linux kernel do_mremap local privilege escalation vulnerability
Product: Linux kernel
Version: 2.2, 2.4 and 2.6 series
Vendor: http://www.kernel.org/
URL: http://isec.pl/vulnerabilities/isec-0012-mremap.txt
CVE: http://cve.mitre.org/cgi-bin/cvename.cgi?name=CAN-2003-0985
Author: Paul Starzetz <ihaquer@isec.pl>, Wojciech Purczynski
<cliph@isec.pl>
Date: January 5, 2004
Issue:
A critical security vulnerability has been found in the Linux kernel
memory management code in mremap(2) system call due to incorrect bound
checks.
Details:
The mremap system call provides functionality of resizing (shrinking or
growing) as well as moving across process's addressable space of exist %/1€Œiso8859-15 ­
ing virtual memory areas (VMAs) or any of its parts.
A typical VMA covers at least one memory page (which is exactly 4kB on
the i386 architecture). An incorrect bound check discovered inside the
do_mremap() kernel code performing remapping of a virtual memory area
may lead to creation of a virtual memory area of 0 bytes length.
The problem bases on the general mremap flaw that remapping of 2 pages
from inside a VMA creates a memory hole of only one page in length but
an additional VMA of two pages. In the case of a zero sized remapping
request no VMA hole is created but an additional VMA descriptor of 0
bytes in length is created.
Such a malicious virtual memory area may disrupt the operation of other
parts of the kernel memory management subroutines finally leading to un %/1€Œiso8859-15 ­
expected behavior.
A typical process's memory layout showing invalid VMA created with
mremap system call:
08048000-0804c000 r-xp 00000000 03:05 959142 /tmp/test
0804c000-0804d000 rw-p 00003000 03:05 959142 /tmp/test
0804d000-0804e000 rwxp 00000000 00:00 0
40000000-40014000 r-xp 00000000 03:05 1544523 /lib/ld-2.3.2.so
40014000-40015000 rw-p 00013000 03:05 1544523 /lib/ld-2.3.2.so
40015000-40016000 rw-p 00000000 00:00 0
4002c000-40158000 r-xp 00000000 03:05 1544529 /lib/libc.so.6
40158000-4015d000 rw-p 0012b000 03:05 1544529 /lib/libc.so.6
4015d000-4015f000 rw-p 00000000 00:00 0
• 60000000-60000000 rwxp 00000000 00:00 0
bfffe000-c0000000 rwxp fffff000 00:00 0
The broken VMA in the above example has been marked with a • .
Impact:
Since no special privileges are required to use the mremap(2) system
call any process may misuse its unexpected behavior to disrupt the ker %/1€Œiso8859-15 ­
nel memory management subsystem. Proper exploitation of this vulnerabil %/1€Œiso8859-15 ­
ity may lead to local privilege escalation including execution of arbi %/1€Œiso8859-15 ­
trary code with kernel level access. Proof-of-concept exploit code has
been created and successfully tested giving UID 0 shell on vulnerable
systems.
The exploitability of the discovered vulnerability is possible, although
not a trivial one. We have identified at least two different attack vec %/1€Œiso8859-15 ­
tors for the 2.4 kernel series. All users are encouraged to patch all
vulnerable systems as soon as appropriate vendor patches are released.
Credits:
Paul Starzetz <ihaquer@isec.pl> has identified the vulnerability and
performed further research. COPYING, DISTRIBUTION, AND MODIFICATION OF
INFORMATION PRESENTED HERE IS ALLOWED ONLY WITH EXPRESS PERMISSION OF
ONE OF THE AUTHORS.
Disclaimer:
This document and all the information it contains are provided "as is",
for educational purposes only, without warranty of any kind, whether ex %/1€Œiso8859-15 ­
press or implied.
The authors reserve the right not to be responsible for the topicality,
correctness, completeness or quality of the information provided in
this document. Liability claims regarding damage caused by the use of
any information provided, including any kind of information which is in %/1€Œiso8859-15 ­
complete or incorrect, will therefore be rejected.
Paul Starzetz
iSEC Security Research
http://isec.pl/
http://www.bsdfreaks.nl Home site: http://rob.lensen.nu /me was RobL
  • Creepy
  • Laatst online: 09-09 21:25
Creepy
Tactical Espionage Splatterer
usr-local-dick schreef op 06 januari 2004 @ 12:12:
En:
Creepy in "Linux kernel 2.4.24 (ook -pre en -rc) dr..."
Volgende keer beter kijken? :)
"I had a problem, I solved it with regular expressions. Now I have two problems". That's shows a lack of appreciation for regular expressions: "I know have _star_ problems" --Kevlin Henney
Hier wordt gediscuseerd over of Linux 2.2 vunerable is.
Er wordt een voorzichtige voorlopige conclusie getrokken.
Actually, after looking at the code again, I'm now quite convinced 2.2 has not this particular vulnerability
