Sony DVP-NC665P/B
Als arme scholier ben ik op zoek naar een goede dvd-speler, met een mooie prijs. Nu kwam ik op mijn zoektocht de Sony DVP-NC665P/B tegen op de site van SonyStyle USA *klik*
Deze dus: (hij is btw ook in zilver/grijs verkrijgbaar)
Afbeeldingslocatie: http://www.sonystyle.com/intershoproot/eCS/Store/en/imagesProducts/180x180/DVPNC655PB.jpg
hieronder nog ff een beschrijving van de speler in kwestie: (schaamteloos gejat van de SonyStyle USA site, dus volledig in Engels)
Overview
Sony’s DVP-NC665P/B DVD Player offers you the chance to relive the excitement of the movies in your very own living room. Enjoy the benefits this 5-Disc DVD/CD Changer brings home with features like a 480P Output Type: Precision Cinema Progressive™ Technology, a Precision Drive™ 2 System with Dynamic Tilt Compensation, DVD-RW/-R (VR and Video Mode) DVD+RW/+R, and MP3/CD-R/CD-RW Playback*, 12 Bit Video DAC with 108Mhz Processing with NSV, and Dolby® Digital and dts® Decoding Compatibility. Additional features include Virtual Surround - 4 Surround Modes, Block Noise Reduction, a Digital Video Enhancer, Digital Video EQ,, Custom Picture Mode, Advanced SmoothScan™ and SmoothSlow modes, and Instant Replay and Instant Search. Indulge in exceptional digital entertainment – the DVP-NC665P/B.
Features top of page
• 5-Disc DVD/CD Changer
• 480P Output Type: Precision Cinema Progressive™ Technology
• Precision Drive™ 2 System with Dynamic Tilt Compensation
• DVD-RW/-R (VR and Video Mode) DVD+RW/+R Playback
• MP3/CD-R/CD-RW Playback*
• 12 Bit Video DAC with 108Mhz Processing with NSV
• Dolby® Digital and dts® Decoding Compatible
• General Features
• Black Finish (Also Available in Silver)
• DVD/CD Text
• MP3 Playback - Playing MP3 Music on a Sony DVD player is easy. Just insert an MP3 encoded disc and press MENU. A blue screen pops up to display your folders. Scroll down the list using the remote or front panel cursor control to select the folder you want. The green files screen pops up to show the files in the selected folder. Select the file you want to hear and you're done. Finding music couldn't be easier.
• Precision Cinema Progressive™ Technology - Other DVD players detect image changes at the scan line level-Sony's Precision Cinema Progressive (PCP) system detects them at the pixel level. The picture is more faithful to the source-whether film or video-because separate, optimized algorithms are used to handle the differing pixel behavior. Separate algorithms are also used to process the moving and still parts of an image, resulting in sharp backgrounds with moving objects that are free from motion artifacts.
• Precision Drive™ 2 System - Past generations of Precision Drive were only able to compensate for warped discs by moving the entire optical block, which took more time and limited the amount of correction possible. Sony's new Precision Drive™ 2 system simplifies the process by moving the lens-instead of the entire optical block-for faster and more accurate error correction.
• 12 Bit Video DAC with 108Mhz processing w/NSV
• 192 kHz 24 Bit Digital to Analog Converter
• Dolby® Digital and dts® Optical/Coaxial Output
• Multi-Disc Resume- 6 Discs
• TV Virtual Surround - 4 Surround Modes
• Block Noise Reduction
• Digital Video Enhancer
• Digital Video EQ
• Custom Picture Mode
• Title and Chapter Viewer
• Advanced SmoothScan™ and SmoothSlow modes
• Instant Replay and Instant Search
• Full 3-2 Reverse Conversion
• A/V Bit Rate Indicator
• Layer Indicator
• Inputs and Outputs
• Component Video Output
• S-Video Output
• Composite Video Output
• Analog Audio Output
• Optical Digital and Coaxial Digital Output
• Convenience Features
• Quick Set-Up
• Custom Parental Control- 40 Discs
• RMT-D155A Remote Control w/Multi-Brand TV Control Compatible with Most Major Brands
• Supplied Accessories
• AA Battery x 2
• AV Cable
• Instruction Manual
de prijs: $179,95 (lijkt me toch redelijk voor een speler met deze capaciteiten)
Zoals hierboven te lezen speelt de speler ook DVD-r/rw en DVD+r/rw af, wat voor mij al een pro is. Graag zou ik horen of jullie dit een goede speler vinden, en zou niet waarom niet, en welke ik beter kan aan schaffen.
bvd Blown_Thunder
Lijkt me een goede speler, goede video DAC (12/108mhz), maar waarom deze in Amerika zoeken, ga je hem importeren of is hij in NL ook te koop?
  • -=bas=-
  • Laatst online: 17-07 05:15
Niet echt bijzondere specs voor een DVD-speler. :?
Een cheap-ass DVD-speler heeft ongeveer dezelfde specificaties en is ook regiovrij.
Dat is met veel Sony modellen echt een probleem (niet enkel ff een code invoeren).
Voor echte kwaliteit kom je in een heel andere prijsklasse.
Als geld een rol speelt, dan kan je net zo goed een goedkopere speler kopen want subliemen kwaliteit koop je met Sony voor dit bedrag niet. Wel is de afwerking uiteraard wat beter dan een speler van 50 euro. Ook is de geluidsproductie vaak een stuk minder.
Senile! Senile Oekaki
Waar bazeer je dat op? Een cheap-ass speler met een 12bit/108mhz dac? dacht het niet.
Daarnaast heeft hij ook gewoon 192/24 Dac's voor muziek en gewoon een coaxiale uitgang wat het DD/DTS signaal echt niet verprutst ofzo.
€179 voor een DVD-speler met die specs én een 5 cd wissellaar is een koopje, helaas dat je hem in Amerika moet halen. ;)
Dat is inderdaad een nadeel Play, ik heb ook nergens kunnen vinden wanneer deze naar Europa komt. Maar als ik een goede DVD speler wil waar ik over een tijdje een A/V-receiver bij kan kopen voor goed geluid (ik sluit hem nu nog gewoon aan op mijn stereo, maar wil er later nog wel een mooi audio setje bij kopen) dus daarom wil ik nu wel een goede kwaliteit dvd speler hebben.
Waar moet ik nu dus opletten bij de aanschaf van een speler? (uitgangen, dts/dd enz?)
