de nieuwe ati omega drivers v2.5.04 (3.10)
  • 126 views sinds 30-01-2008
  • staafonline
  • Laatst online: 25-09-2019
ze zijn eindelijk uit had gisteren al gedownload
en begin er steeds minder problemen met mijn vid kaart te krijgen
download ze hier http://www.omegacorner.com/index_ati.html
dit zal tevens ook de laatste driver zijn voor 9x en Me
zo effe een klein testje gedaan ben met 3dmark03 van 5439 naar 5438 punten gegaan
change log is als volgt
OMEGADRIVE here!
This are my "optimized" drivers for the ATI Radeon family of video cards.
What's New? (2.5.04 / 2.5.29)
* Based on the Official Catalyst 3.10 drivers. (2k/XP/9x/ME)
* Fixed the setup issues once and for all by re-writing the ATI setup INIs from
scratch. This was tested on a LOT of cards and they worked perfectly, if you
still have problems please E-Mail me.(2k/XP/9x/ME)
* Updated the profiler utility to the latest version with OC support
included. (2k/XP)
* Removed RadClocker from the package (petition by the author). (2k/XP/9x/ME)
* Added the STRETCH screen option for Digital Flat Panel monitors and
laptops. (2k/XP/9x/ME)
* Added support for HDTV resolutions. (2k/XP/9x/ME)
* Changed some of the default Omega settings. (2k/XP/9x/ME)
* Fixed the Dual Monitor/ATI Control Panel problems. (2k/XP/9x/ME)
* Added 1400x1050@60Hz for FPD monitors and laptops. (2k/XP/9x/ME)
Previous version(2.4.96c)
* Based on the Official Catalyst 3.9 drivers. (2k/XP)
* Included the OGL fix for AIW cards. (2k/XP)
* Added a very powerful full-blown profiler utility. (2k/XP)
* Removed the ATI profiles from the ATI CP, the OGL and D3D tabs
are now separated as pre Cat 3.8 drivers. (2k/XP)
* Added support for more cards, including Mobility and IGP. (2k/XP)
* Added a Desktop shortcut to go directly to the ATI Control Panel. (2k/XP)
* Added an exclusive version of Driver Cleaner for the Omega Drivers. (2k/XP)
-= Many thanks to Spike =-
Important Notes:
1. If you are experiencing crashes or black screens just a few seconds after
entering a game, DISABLE VPU RECOVER (IF available), that should help.
2. If you play Call of Duty (Full version, not demo) and experience lockups
in certain game areas, DISABLE Fastwrites.
3. To use the Profiler Software you may need to download and install a recent
version of .NET RUNTIME from Microsoft. If you get an error message, at program
start which sounds like "program cannot be intitialized", then you need to download
and install the latest .NET runtime from Microsoft, or you will not be able to
use the program. Link:
http://www.microsoft.com/...4D1E7CF3A3&displaylang=en
REMINDERS:
1- If you have the normal ATI drivers, uninstall the ATI Control Panel BEFORE
upgrading to these drivers, the drivers already have the CP integrated
and another CP may cause conflicts or other problems.
2- There is no need to uninstall ANY previous drivers (ATI or OMEGA) when
installing these, they will override any previous settings.
3- In Windows 2k/XP, ALWAYS disable DDC in the ATI "Displays/Monitor" CP after
installing drivers to be able to use ALL the refresh rates and resolutions
your monitor supports, also this is the best way to avoid the 60Hz RR bug.
4- The WDM drivers for VIVO and AIW cards are not included, but they can be
downloaded separately from a link in my drivers page.
5- I have received various E-Mails asking about FastWrites, there is only one
answer to that: TURN IT OFF
The Radeon cards do support FastWrites and they will work with it on
(on some machines), but it is not recommended, there is NO SPEED gain
when using FW, and this option will affect your PC's stability a LOT.
*** IMPORTANT FASTWRITES UPDATE ***
An important info has come to my attention, if you have a Radeon 9600 Pro card,
regardless of the manufacturer, you MUST enable Fastwrites to make it work
properly, if not, you may experience crashes and lockups! (This is only a temporary
fix until ATI resolves the problem)
I don't recomend the use of ANY external tweakers with my drivers (specially Rage3D
tweaker), as they override my special settings and will make my work useless. The only
time I recommend a tweaker is when you have a specific problem with a specific tweak
and need to change it in order to make the drivers work correctly. Also if you use
a tweaker for overclocking, FSAA, Gamma or Aniso settings, is just fine, but you'll
be better off using the integrated ATI CP for that (which is ok by me if you change
any setting in it).
If you have any problems with this drivers please go to my webpage
and look in the ATI help section for answers. If still have problems
look for the drivers thread in www.driverheaven.net forums and let me know
what is going on.
If you happen to find a new tweak or fix for a specific game or many games
and it proves that it works then drop me an E-Mail (don't post it in the
forums), I'll make sure credit will be granted to that person in this INFO file.
IMPORTANT: Don't bother ATI about this drivers as they are unsupported by them!
May GOD bless everybody!
O M E G A D R I V E
"Don't mess with the Best!"
verander zo nodig de titel
en nu jullie ervaringen
[ Voor 16% gewijzigd door staafonline op 23-12-2003 16:44 ]
