Pioneer DVR-106 + nero 6.3.0.0
  • anglico
  • Laatst online: 07-02 00:11
Na het doorzoeken van de faq toch maar effe vragen hier.
Af en toe mislukken mijn dvd+r's, dit direct na het schrijven van de leadin.
Nu wil ik weten waarom maar hoe moet ik de log van nero analyseren?
Ik gebruik XP pro SP1, Nero 6.3.0.0, Aspi 4.72, Pioneer DVR106D via USB 2.0.
PS en wat doet dit juist => DVD high compatibility mode: Yes
Dit is de log van nero:
====== *** Nero-Burning Rom, History File *** ======
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=4.71 (0002), size=45056 bytes, created 17/07/2002 10:03:20
ahead WinASPI: File 'C:\Program Files\Applications\Dvdr\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 11/11/2003 14:49:52
Nero version: 6.3.0.0
Recorder: <PIONEER DVD-RW DVR-106D>Version: 1.07 - HA 4 TA 0 - 6.3.0.0
Adapter driver: <> HA 4
Drive buffer : 2000kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <Generic DVD-ROM >Version: 3.41 - HA 3 TA 0 - 6.3.0.0
Adapter driver: <st3shark> HA 3
=== Scsi-Device-Map ===
DiskPeripheral : WDC WD1200JB-00CRA1 atapi Port 0 ID 0 DMA: On
DiskPeripheral : WDC WD1200JB-00CRA1 atapi Port 0 ID 1 DMA: On
CdRomPeripheral : HL-DT-ST RW/DVD GCC-4480B atapi Port 1 ID 0 DMA: On
CdRomPeripheral : LITE-ON LTR-40125S atapi Port 1 ID 1 DMA: On
DiskPeripheral : Promise 1+0 Stripe/RAID01.10 fasttx2k Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 3.41 st3shark Port 3 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 3.41 st3shark Port 3 ID 1 DMA: Off
=== CDRom-Device-Map ===
HL-DT-ST RW/DVD GCC-4480 M: CDRom0
LITE-ON LTR-40125S N: CDRom1
Generic DVD-ROM P: CDRom2
Generic DVD-ROM O: CDRom3
PIONEER DVD-RW DVR-106D R: CDRom4
AutoRun : 0
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 1023MB (1048084kB)
Free physical memory: 562MB (576220kB)
Memory in use : 45 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
21.12.2003
Burn DVD Image
19:25:02 #1 Text 0 File Reader.cpp, Line 118
Reader running
19:25:02 #2 Text 0 File Writer.cpp, Line 124
Writer PIONEER DVD-RW DVR-106D running
19:25:02 #3 Text 0 File Burncd.cpp, Line 3094
Turn on Disc-at-once, using DVD media
19:25:03 #4 Text 0 File DlgWaitCD.cpp, Line 239
Last possible write address on media: 2295103 (510:01.28)
Last address to be written: 2286261 (508:03.36)
19:25:03 #5 Text 0 File DlgWaitCD.cpp, Line 244
Write in overburning mode: FALSE
19:25:03 #6 Text 0 File DlgWaitCD.cpp, Line 2068
Recorder: PIONEER DVD-RW DVR-106D, Media type: DVD+R
Disc Manufacturer ID: OPTODISC, Media Type ID: OP1, Product revision number: 1
Disc Application Code: 0, Extended Information Indicators: 0
19:25:03 #7 Text 0 File DlgWaitCD.cpp, Line 405
>>> Protocol of DlgWaitCD activities: <<<
19:25:03 #8 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (2 - CD-ROM Mode 1, Joliet)
2 indices, index0 (150) not provided
original disc pos #0 + 2286262 (2286262) = #2286262/508:3.37
not relocatable, disc pos for caching/writing not required/not required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286262 blocks [PIONEER DVD-RW DVR-106D]
19:25:03 #9 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [PIONEER DVD-RW DVR-106D] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4682264576, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286262 | lead-out | 1 | 0x00 | 0x41
19:25:03 #10 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
19:25:03 #11 Text 0 File Burncd.cpp, Line 4061
Cache writing successful.
19:25:03 #12 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
19:25:03 #13 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 2.4x (3.312 KB/s)
19:25:03 #14 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (not relocatable, no disc pos, no patch infos, orig at #0): write at #0
19:25:03 #15 Text 0 File Cdrdrv.cpp, Line 7912
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD+R (10), Part Version: 1
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 26053F h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 4F 50 54 4F 44 49 - 53 43 4F 50 31 01 38 23 ..OPTODISCOP1.8#
54 37 09 02 64 6A 02 C8 - 63 18 18 0A 0A 0E 0E 01 T7..dj..c.......
1B 1D 0B 0B 11 13 01 00 - 00 00 00 00 00 00 00 00 ................
19:25:03 #16 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 23:46,202 (1426202ms) -> OK
19:25:03 #17 Text 0 File DVDPlusRW.cpp, Line 603
Start write address at LBA 0
19:25:08 #18 Text 0 File Cdrdrv.cpp, Line 1276
19:25:08.046 - PIONEER DVD-RW DVR-106D\H4 T0 : Queue again later
19:25:22 #19 SCSI -500 File Cdrdrv.cpp, Line 1430
SCSI Exec, HA 4, TA 0, LUN 0, buffer 0x03960000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x2A 0x00 0x00 0x00 0x03 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
19:25:22 #20 CDR -500 File Writer.cpp, Line 301
SCSI command aborted
19:25:22 #21 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
19:25:22 #22 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
19:25:29 #23 Phase 127 File dlgbrnst.cpp, Line 1800
Generating DVD high compatibility borders
19:25:29 #24 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
19:25:29 #25 Phase 129 File dlgbrnst.cpp, Line 1800
Generating DVD borders completed successfully
19:25:29 #26 Text 0 File dlgbrnst.cpp, Line 1658
19:25:29 #27 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 2.4x (3.312 KB/s)
Existing drivers:
File 'Drivers\ASPI32.SYS': Ver=4.71 (0002) built by: WinDDK, size=16512 bytes, created 17/07/2002 9:05:10
File 'Drivers\st3shark.sys': Ver=3.41.0.0 built by: WinDDK, size=5504 bytes, created 27/09/2003 14:37:16 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
"I've always found a fully Deployed Battle Group to be the most Effective Negotiator." Admiral Stark, High Guard, CY 9758
  • -=bas=-
  • Laatst online: 17-07 05:15
Ik weet niet wat voor schijfjes je gebruikt maar het lijkt erop dat Nero iets niet kan lezen aan het begin van het brandproces.
Probeer anders eens een paar A-merk schijfjes te gebruiken, mogelijk ligt het gewoon aan het type/merk schijfjes die je gebruikt. Goedkope merken kunnen soms dit soort rare fouten geven.
Senile! Senile Oekaki
  • anglico
ik gebruik nu philips 4x (cmc id code), heb er 15 achter elkaar gebrand en geen probleem
met die andere (medianca) 4 achter elkaar branden en problemen, raar.
nu maar hopen dat die cmc dvd+r wat waard is
