Linux TSC troubles
Ok, ik heb een probleem met het installeren met de tsc client met java. Ik krijg hierbij de volgende foutmelding:
# sh ./installDDOL.bin
./installDDOL.bin: ./installDDOL.bin: Onbekend bestand of map
[root@CP336226-A q]# cd Sources
[root@CP336226-A Sources]# sh ./installDDOL.bin
Preparing to install...
tail: `-1' option is obsolete; use `-n 1'
Try `tail --help' for more information.
./installDDOL.bin: line 329: [: `)' expected, found -z
WARNING! The amount of /tmp disk space required and/or available
could not be determined. The installation will be attempted anyway.
Extracting the JRE from the installer archive...
Unpacking the JRE...
Extracting the installation resources from the installer archive...
Configuring the installer for this system's environment...
Launching installer...
Invocation of this Java Application has caused an InvocationTargetException. This application will now exit. (LAX)
Stack Trace:
java.lang.NoClassDefFoundError
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:140)
at java.awt.GraphicsEnvironment.getLocalGraphicsEnvironment(GraphicsEnvironment.java:62)
at java.awt.Window.init(Window.java:224)
at java.awt.Window.(Window.java:268)
at java.awt.Frame.(Frame.java:398)
at java.awt.Frame.(Frame.java:363)
at com.zerog.ia.installer.Main.c(Unknown Source)
at com.zerog.ia.installer.Main.main(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:324)
at com.zerog.lax.LAX.launch(Unknown Source)
at com.zerog.lax.LAX.main(Unknown Source)
GUI-
Ik heb ook geprobeerd om hem zonder java vm te installeren, maar hierbij vind hij niet waar ik de java vm geinstalleerd heb :? Ik moet daarvoor waarchijnlijk wat regels veranderen, maar waar wat en hoe weet ik weer niet... :'(
Help! ;(
  • Mobster
  • Laatst online: 07-06-2016
Mobster
Los Alcoholicos
Ik heb ruk verstand van linux, maar ik zie in jouw eerste zin DDOL staan. Geen idee of dat klopt.
Notes:
After downloading open a shell and CD to the directory where you downloaded the installer.
At the prompt type: sh ./installCommunityTSC.bin
A Java virtual machine is included with this download. It will be run automatically when you run the shell script.
En misschien heb je nog wat aan deze link?
Succes en er komt vast zo wel een linux/TSC guru binnen. Anders kan je ook mailen naar TSC [at] dutchpowercows [dot] org
Deze wordt gelezen door ProjectVertegenwoordiger Glurp :)
Toch maar eens een andere sig bedenken :P
Dat is idd de foutmelding die ik bij DDOL had, goed opgelet :)
Helaas heb ik bij TSC hetzelfde probleem, dus het balletje blijft op ;)
* Q-collective wacht op Glurp
Hier! Nu! :D
Weetjewat, ik kom wel ff in #teb, is wat makkelijker lullen, dus als de wiederweerga daarheen Glurp! :P
Verwijderd schreef op 18 december 2003 @ 17:41:
Hier! Nu! :D
k ben er al :P
  • mcB
  • Laatst online: 21-08 10:41
mcB
Is er een duidelijke linux howto voor de TSC client?
Zelfs aan de hand van de installatiebeschrijving op de TSC site is het me niet gelukt.
Toch jammer dat ik mn servertje niet op TSC kan zetten...
Strix (Skullflame)
mcB schreef op 18 december 2003 @ 18:37:
Zelf weet ik niks van Linux af maar misschien dat de SID faq je op weg kan helpen. Is wel van voor versie 2.0, dus ik weet niet of het nog werkt, maar misschien geeft het de goede richting aan: http://145.94.192.103/sid/faq.cfm?project=9&tID=13
Anders kun je nog bij TRI terecht voor vragen: http://www.childhooddisea...imatebb.cgi?ubb=forum;f=8
Wat ik wel zag bij voorkomende problemen is dat je het beste java los kunt installeren en dan de client zonder java erbij installeren.
[ Voor 12% gewijzigd door Verwijderd op 18-12-2003 19:13 ]
  • ColdFusion
  • Laatst online: 23-07 22:05
Ik heb verder ook de ballen verstand van Linux, dus er is een kans dat ik iets roep in de trant van 'de klok horen luiden, maar niet weten waar de klepel hangt' :+
De TSC/D2OL client moet onder linux wel d.m.v. een GUI (X ofzo :?) geinstalleerd worden. Zodra de client geinstalleerd is kan deze in 'consolemode' verder draaien.
Misschien heb je er iets aan, misschien ook helemaal niet :D
_______________-=Team ColdFusion=-_______________
#2 DPAD - #2 OGR27 - #2 F@H - #3 R@H - #5 RC5 - #6 SoB - #10 WCG
||| #1 ECCp109 - #1 ECC2-109 - #1 OGR24 - #1 D2OL P1|||
  • geintje
  • Laatst online: 06-04 17:37
geintje
=| zeiken met een glimlach |=
* geintje denkt dat coldfusion de vinger op de zere plek legt : install (met of zonder java) kan NIET alleen in commando mode. er word nml een X-venster (GUI) ge-opened die voor verdere install zorgt ( mail adres invoer etc etc).
Dus distro's die geen X (GUI) hebben : jammer geen tsc/ D2OL ( of X ff apart installen :D)
________________________Team ColdFusion________________________
#1 DPAD, #1 OGR-27, #2 F@H, #4 RC5, #18 WCG
  • mcB
mcB
Hmm helaas,... geen TSC op mn server dan. Er komt geen X op mn server.
Dan maar verder met RC5 (dan draag ik op de site hosten na, toch nog iets bij aan Kudde Groningen)
@ Glurp.... de beschrijving op SID had ik ook al ontdekt.
Strix (Skullflame)
Het probleem is X niet hoor boys :)
Ik draai al weer een tijdje Fedora en het zou kunnen zijn dat deze toch net ff teveel afwijkt van RedHat 9 dan ik dacht. het java pakket vind zichzelf niet in de installatie (althans, dat kan ik opmaken uit de foutmelding :? ) en het pakket zonder java vind het java pakket niet wat ik apart geinstalleerd heb :P
Daar zit hem dus het probleem, optie 1 heb ik in principe opgegeven, optie 2 (installeren zonder java vm) moet in principe wel te doen zijn... als ik ff wist hoe alleen... :P
Btw:
Je MOET idd X draaien om tsc draaien te kunnen, er wordt hard gewerkt aan een versie die draait zonder X maar dit heeft nog niet veel concreets opgeleverd.
*Giving this topic a new swing...*
Nog Linux Guru's in de buurt hier? Joehoe! :)
  • Mobster
Mobster
Los Alcoholicos
Hoewel het ook op het TSC forum niet stikt van de linux gurus heb ik je probleem toch maar even gepost in dit draadje.
Aub ook zelf even in de gaten houden :)
  • Dutchman!
  • Laatst online: 05-09 15:47
Ik zal hem eens richting NOS gooien, eens zien of ze er daar wat op kunnen bedenken. En zo niet, voetbal de draag dan maar weer gewoon terug :)
We spend our years as a tale that is told
  • ajvdvegt
  • Laatst online: 15-08 12:40
TSC? :?
Ik denk dat er in dit forum iets meer info nodig is. (dat andere forum is weinig behulpzaam als het over dit soort elementaire vragen gaat.)
Welke java versie is nodig en welke heb je?
I don't kill flies, but I like to mess with their minds. I hold them above globes. They freak out and yell "Whooa, I'm *way* too high." -- Bruce Baum
  • Mobster
Mobster
Los Alcoholicos
Dat is ook het nadeel van draadjes verplaatsen. Geen idee of TS weet dat ie nu in NOS staat....
Maar met wat navraag op het TSC forum, kwam ik op het volgende draadje.
Misschien heeft TS er iets aan.
[ Voor 8% gewijzigd door Mobster op 24-12-2003 10:19 ]
