[gehacked?] hosts-file?
  • 59 views sinds 30-01-2008
Hey!
Sinds een paar dagen gaat m'n browser af en toe ineens naar een bepaalde pagina met het adres: http://69.31.85.201/c/
Er staat dat m'n hosts-file gehacked is. Nu heb ik even die file geopend en alleen m'n localhost laten staan en daarna de computer opnieuw opgestart, maar hij blijft zo nu en dan naar die pagina gaan. Ben ik echt gehacked of is er iets anders aan de hand? Ik heb echt geen flauw idee ;)
Alvast bedankt!
Rob
Dit stond er op die pagina:
If you see this page your hosts file has been hacked. Please use the instruction below to clean your machine.
You cannot reach the site you where trying to reach without following this procedure! - Please follow the steps provided in this document and make sure to download all patches for your computer from the Windows Update Site which can be found here:
http://windowsupdate.microsoft.com
1. Start regedit,
find HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Run ,
delete starting of svchost.exe file,
reboot your computer,
delete file svchost.exe in windows directory.
2. Reboot windows and start in
SAFE MODE (F8 key on keyboard before windows starting),
delete file winlogon.exe in directory: C:\Documents and Settings\All Users\Start Menu\Programs\Startup
3. Clear your 'hosts' file.
How to edit your hosts file: locate it first, either by browsing to the directory (as shown above) or by hitting "Start - Search - select all files and folders - type in 'hosts' (without the quotation marks) and hit search. When the file is found, click with your right mouse button on the file and select 'Open With...' This will bring up a list of programs to edit the file with. Select Notepad from that list and click OK. - Remove all lines from the file and type in: 127.0.0.1 localhost. Now close the file and save your changes.
For Windows 95/98/Millenium machines: Locate the file hosts in your C:\Windows directory. Just delete it or edit it with a text editor like notepad and make sure there is only one line there:
127.0.0.1 localhost
For Windows 2000 machines: Locate the file hosts in your C:\Winnt\System32\Drivers\Etc directory. Just delete it or edit it with a text editor like notepad and make sure there is only one line there:
127.0.0.1 localhost
For Windows XP machines: Locate the file hosts in your C:\Windows\System32\Drivers\Etc directory. Just delete it or edit it with a text editor like notepad and make sure there is only one line there:
127.0.0.1 localhost
  • RAJH
Het is niet nodig je bericht 2 maal te plaatsen hoor :)
Of was je je topic kwijt? ;)
[rml][ gehacked?] hosts-file?[/rml]
Oeps sorry :D
  • mimic
mimic
O ja joh?
Toen ik het 2e stukje was had ik zoiets dat dit best wel fake zou kunnen zijn
Want dit programmatje zit als ik het goed heb gewoon bij windows in en is nodig voor het systeem.
Misschien heb je een virus oid. :?
1. Start regedit,
  • intoxicated
intoxicated
Haaaai :w | ALT-S
Re-posten hoeft niet hoor ;)
"Anyone who does not agree with me is mentally sick, and should be shot I'm afraid to say."
- Pastor Richards @ VCPR
