[VPN] Symantec Client Security
Er is iets fout met de settings van het programma waarmee je inlogd op het netwerk
ik krijg de volgende error log..
Dec 15 11:57:14.782 lt009 isakmpd[3356]: 301 Internal warning: Failed to find ike enabled security gateway = LSg_xxx.xxx.xxx.xxx
Dec 15 11:57:14.782 lt009 emapi[3340]: 400 Symantec Enterprise VPN Client Error: Communications with the ISAKMP daemon failed.
Dec 15 11:57:14.792 lt009 emapi[3340]: 301 Internal warning: accept fails (Socket operation on non-socket.)
Dec 15 11:57:31.065 lt009 emapi[3568]: 100 Symantec Enterprise VPN Client Info: Entering EMAPI initial wait state.
Dec 15 11:57:31.195 lt009 vpnd[3596]: 117 Daemon starting
Dec 15 11:57:31.165 lt009 isakmpd[3588]: 117 isakmpd Info: Daemon starting
Dec 15 11:57:31.266 lt009 isakmpd[3588]: 120 isakmpd Info: Not waiting for Mobile
Dec 15 11:57:32.277 lt009 isakmpd[3588]: 120 isakmpd Info: Reloading tunnels to vpnd with 3 sec wait.
Dec 15 11:57:32.277 lt009 isakmpd[3588]: 120 isakmpd Info: Reloading tunnels to RaptorMobile with 3 sec wait.
Dec 15 11:57:33.248 lt009 isakmpd[3588]: 120 isakmpd Info: Cannot find entrust config file C:\Program Files\Symantec\VPNClient\entrust.cf. Will use default configuration.
Dec 15 11:57:33.599 lt009 isakmpd[3588]: 120 isakmpd Info: IKMPLogin: Switched to lite mode, cannot access CA directory
Dec 15 11:57:33.609 lt009 isakmpd[3588]: 120 isakmpd Info: Try to turn off crl validation...
Dec 15 11:57:33.609 lt009 isakmpd[3588]: 120 isakmpd Info: Successfully logged into the ISAKMP engine with a default profile which has no Certificate support
Dec 15 11:57:33.619 lt009 isakmpd[3588]: 120 isakmpd Info: Reconfiguring Isakmp tunnels
Dec 15 11:57:33.619 lt009 emapi[3568]: 100 Symantec Enterprise VPN Client Info: Continue operation.
Dec 15 11:57:33.629 lt009 isakmpd[3588]: 120 isakmpd Info: Reloading tunnels to RaptorMobile with 15 sec wait.
Dec 15 11:58:22.339 lt009 vpnd[3596]: 120 vpnd Info: Some adapter ip address has changed. Will reconfigure vpn services
Dec 15 11:58:25.744 lt009 emapi[3568]: 100 nsetup Trace: Session Notification enabled.
Dec 15 11:58:28.010 lt009 isakmpd[3588]: 120 isakmpd Info: Reconfiguring Isakmp tunnels
Dec 15 11:58:28.128 lt009 isakmpd[3588]: 120 Isakmpd Info: Detected adapter ip addr changes. Rebinding to new sockets.
Dec 15 11:58:28.558 lt009 vpn: 401 Internal error: can't set interface parameters for IP address xxx.xxx.xxx.xxx
Dec 15 11:58:30.657 lt009 isakmpd[3588]: 120 isakmpd Info: Waiting 2 seconds for Adapter Changes
Dec 15 11:58:32.033 lt009 isakmpd[3588]: 120 isakmpd Info: No adapter changes found.
Dec 15 11:58:32.353 lt009 emapi[3568]: 100 nsetup Trace: Connecting security gateway xxx.xxx.xxx.xxx
Dec 15 11:58:32.443 lt009 emapi[3568]: 100 nsetup Trace: Connecting tunnel xxx.xxx.xxx.xxx
Dec 15 11:58:38.252 lt009 isakmpd[3588]: 120 isakmpd Info: Error while processing data rcvd from peer xxx.xxx.xxx.xxx: (-3382) Invalid ID information.
Dec 15 11:58:38.262 lt009 isakmpd[3588]: 120 isakmpd Info: Error during isakmp sa negotiation with peer xxx.xxx.xxx.xxx, status=IKMP_ERROR err=(-3382) Invalid ID information.
Dec 15 11:58:38.262 lt009 isakmpd[3588]: 120 isakmpd Info: Initiator, Failed to establish ISAKMP SA with peer xxx.xxx.xxx.xxx[tunTemplate=SP1]
Dec 15 11:58:38.502 lt009 isakmpd[3588]: 120 isakmpd Info: Error while processing data rcvd from peer xxx.xxx.xxx.xxx: (-3382) Invalid ID information.
Dec 15 11:58:38.512 lt009 isakmpd[3588]: 120 isakmpd Info: Error during isakmp sa negotiation with peer xxx.xxx.xxx.xxx, status=IKMP_ERROR err=(-3382) Invalid ID information.
Dec 15 11:58:38.512 lt009 isakmpd[3588]: 120 isakmpd Info: Initiator, Failed to establish ISAKMP SA with peer xxx.xxx.xxx.xxx[tunTemplate=SP1]
Dec 15 11:58:38.783 lt009 isakmpd[3588]: 120 isakmpd Info: Error while processing data rcvd from peer xxx.xxx.xxx.xxx: (-3382) Invalid ID information.
Dec 15 11:58:38.824 lt009 isakmpd[3588]: 120 isakmpd Info: Error during isakmp sa negotiation with peer xxx.xxx.xxx.xxx, status=IKMP_ERROR err=(-3382) Invalid ID information.
Dec 15 11:58:38.855 lt009 isakmpd[3588]: 120 isakmpd Info: Initiator, Failed to establish ISAKMP SA with peer xxx.xxx.xxx.xxx[tunTemplate=SP1]
Dec 15 11:58:39.295 lt009 isakmpd[3588]: 120 isakmpd Info: Error while processing data rcvd from peer xxx.xxx.xxx.xxx: (-3382) Invalid ID information.
Dec 15 11:58:39.330 lt009 isakmpd[3588]: 120 isakmpd Info: Error during isakmp sa negotiation with peer xxx.xxx.xxx.xxx, status=IKMP_ERROR err=(-3382) Invalid ID information.
Dec 15 11:58:39.361 lt009 isakmpd[3588]: 120 isakmpd Info: Initiator, Failed to establish ISAKMP SA with peer xxx.xxx.xxx.xxx[tunTemplate=SP1]
Dec 15 11:58:39.123 lt009 emapi[3568]: 400 Symantec Enterprise VPN Client Error: Communications with the ISAKMP daemon failed.
Dec 15 11:58:42.899 lt009 emapi[3568]: 100 nsetup Trace: Error connecting tunnel to xxx.xxx.xxx.xxx RC=1. Terminating connect operation.
Iemand een tip om mij de juiste richting op te helpen of Iemand enig idee wat voor instellingen ik moet wijzigen hiervoor ben al sinds vorige week ermee bezig en heb dat hele boek door geneusd maar wordt er niet echt wijzer van :'(
bij voorbaat dank...
