Call of duty Probleem(werkt neit)
  • 109 views sinds 30-01-2008
een collega van mij heeft een probleem met COD hij wilt voor geen meter opstarten deze error geeft hij:
COD 1.0 build win-x86 Oct 5 2003
----- FS_Startup -----
Current language: english
Current search path:
C:\PROGRA~1\CALLOF~1\main\pak6.pk3 (3 files)
C:\PROGRA~1\CALLOF~1\main\pak5.pk3 (4858 files)
C:\PROGRA~1\CALLOF~1\main\pak4.pk3 (1668 files)
C:\PROGRA~1\CALLOF~1\main\pak3.pk3 (1992 files)
C:\PROGRA~1\CALLOF~1\main\pak2.pk3 (694 files)
C:\PROGRA~1\CALLOF~1\main\pak1.pk3 (2642 files)
C:\PROGRA~1\CALLOF~1\main\pak0.pk3 (12828 files)
C:\PROGRA~1\CALLOF~1/main
C:\PROGRA~1\CALLOF~1\main\localized_english_pak1.pk3 (3736 files)
localized assets pak file for english
C:\PROGRA~1\CALLOF~1\main\localized_english_pak0.pk3 (1204 files)
File Handles:
29625 files in pk3 files
execing default.cfg
couldn't exec language.cfg
couldn't exec config.cfg
couldn't exec autoexec.cfg
execing safemode.cfg
fs_basepath is write protected.
fs_homepath is write protected.
========= autoconfigure
configure.csv: using configuration 2000 cpu MHz 512 sys MB 128 vid MB
execing configure.cfg
Hunk_Clear: reset the hunk ok
...detecting CPU, found AMD w/ 3DNow!
Measured CPU speed is 2.08 GHz
System memory is 512 MB (capped at 1 GB)
Video card memory is 128 MB
Streaming SIMD Extensions (SSE) supported
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
----- R_Init -----
Initializing OpenGL subsystem
...initializing QGL
...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded
...setting mode 6: 1024 768 FS
...using colorbits of 32
...calling CDS: ok
...registered window class
...created window@0,0 (1024x768)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...55 PFDs found
...hardware acceleration found
...PIXELFORMAT 9 selected
...creating GL context: failed
...failed hard
...restoring display settings
...WARNING: could not set the given mode (6)
...shutting down QGL
...unloading OpenGL DLL
Forcing 800x600 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 4: 800 600 FS
...calling CDS: ok
...created window@0,0 (800x600)
video card cannot set mode 800x600 because GL_MAX_TEXTURE_SIZE is only -831197568
...WARNING: could not set the given mode (4)
Forcing 640x480 resolution to allow OpenGL to run in fullscreen
...initializing QGL
...setting mode 3: 640 480 FS
...calling CDS: ok
...created window@0,0 (640x480)
...55 PFDs found
...failed hard
...WARNING: could not set the given mode (3)
----- CL_Shutdown -----
RE_Shutdown( 1 )
Could not load OpenGL. Make sure that you have the latest drivers for your video card from the manufacturer's web site.
systeem spec
AMD 2800+
512DDR
Asus Nvidia geforce 4 MX440 128mb
MB unknown met nvidia nforce chitset
deze driver is er op geinstaleerd 53.03_winxp2k_english_whql (nieuwste)
en directx 9.0b staat op de COD CD (origineel)
hoop dat iemand mij hiermee kan helpen, thx
  • Virgil
  • Laatst online: 16:25
Virgil
We're not alone
Hij moet zijn opengl drivers opnieuw installeren. Het ziet er naar uit dat OpenGL drivers niet geinitialised kunnen worden.
De engine kan namelijk wél een window maken (dus je hebt opengl) maar hij kan hem niet vasthouden.
Eerst even proberen driver opnieuw installeren of een oudere driver erop zetten (ergens in de 42.x serie)
[ Voor 51% gewijzigd door Virgil op 13-12-2003 20:23 ]
Ik was heel, heeeel vroeger SeRRveR
Je zou voor de gein eens met de Search moeten zoeken naar "Could not load OpenGL". Ik durf te wedden dat er dan een wereld voor je open gaat.
Dicht :)
