Linux OSPF probleem
In de volgende simpele setup, heb ik het volgende probleem. Router 1 kan alles en iedereen pingen, router 2 daarentegen kan alle interfaces op router 1 pingen maar niet door router 1 naar de default gateway (of het gehele 10.33.18.x netwerk)
Afbeeldingslocatie: http://www.wlanstore.nl/zebraospf.gif
ip_forward staat aan.
zebra.conf Node 1
hostname Node1
password xxx
enable password xxx
! Interfaces
interface lo
description loopback
ip address 127.0.0.1/8
interface ath0
description backbone
ip address 10.0.0.2/24
no shutdown
multicast
interface wlan0
description sector noord
ip address 10.33.28.1/25
no shutdown
no multicast
interface wlan1
description sector zuid
ip address 10.33.28.129/25
no shutdown
no multicast
log file /var/log/zebra/zebra.log
ospfd.conf Node 1
hostname Node1
password xxx
enable password xxx
interface lo
! Intefaces
interface ath0
ip ospf message-digest-key 1 md5 blabla
ip ospf authentication message-digest
ip ospf network broadcast
interface eth0
interface wlan0
ip ospf network non-broadcast
interface wlan1
! ospf router
router ospf
ospf router-id 10.33.28.1
passive-interface lo
passive-interface eth0
! networks
!ath0
network 10.0.0.0/24 area 0
!wlan0
network 10.33.28.0/25 area 1
!wlan1
network 10.33.28.128/25 area 1
log file /var/log/zebra/ospfd.log
zebra.conf Node 2
hostname Node2
password xxx
enable password xxx
! Interfaces
interface lo
interface ath0
ip address 10.0.0.3/24
multicast
no shutdown
interface wlan0
description wlan0
ip address 10.33.15.1/24
no multicast
no shutdown
ospfd.conf Node 2
hostname Node2
password xxx
enable password xxx
interface lo
! Interfaces
interface ath0
interface eth0
interface wlan0
! ospf router
router ospf
ospf router-id 10.33.15.1
! networks
!ath0
!wlan0
network 10.33.15.0/24 area 2
routing table router 1
Destination     Gateway         Genmask         Flags Metric Ref    Use Iface
10.33.28.0      *               255.255.255.128 U     0      0        0 wlan0
10.33.28.128    *               255.255.255.128 U     0      0        0 wlan1
10.0.0.0        *               255.255.255.0   U     0      0        0 ath0
10.33.18.0      *               255.255.255.0   U     0      0        0 eth0
10.33.15.0      10.0.0.3        255.255.255.0   UG    20     0        0 ath0
default         10.33.18.1      0.0.0.0         UG    0      0        0 eth0
routing table router 2
10.33.28.0      10.0.0.2        255.255.255.128 UG    20     0        0 ath0
10.33.28.128    10.0.0.2        255.255.255.128 UG    20     0        0 ath0
10.33.18.0      10.0.0.2        255.255.255.0   UG    20     0        0 ath0
10.33.15.0      *               255.255.255.0   U     0      0        0 wlan0
default         10.0.0.2        0.0.0.0         UG    20     0        0 ath0
het opvragen van de routing table van router 2 geeft enkele seconden vertraging (even als arp -a) bij router 1 wordt de routing table echter wel gelijk geprint.
ospf md5 verificatie lukt en komt tot stand, dr and backup election werkt eveneens...pingen 10.33.18.1 vanaf router 2 onmogelijk.
Iemand enig idee ?
waarom perse met ospf, het lijkt mij een nodeloos ingewikkelde oplossing voor een simpel probleem. Probeer het eerst eens gewoon met statische routes zonder routing protocol. den heb je i.i.g. bevestigd of het probleem wel in ospf zit.
p.s. moet je ospf area niet identiek zijn om ze elkaars routes te laten leren ?
[ Voor 17% gewijzigd door Verwijderd op 12-12-2003 16:15 ]
  • FatalError
  • Laatst online: 22:15
nee, hoeft niet
If it ain't broken, tweak it! | gasloos sinds oktober 2025, hoekwoning 1978 | 10kWp PV, Panasonic K serie 7kW, Atlantic Explorer V5 270L | Tesla Model Y | 3x Victron MP2 6k5, 48kWh
Mmm... de route komt wel in de routing table van node 2 terecht, maar mogelijk met het verkeerde next-hop adres: je netwerktekening is anders dan je configuratie; op de tekening heeft node 2 ip adres 10.0.0.2, en node 1 10.0.0.3, terwijl het in je config precies andersom is... hoe zijn de interfaces geconfigureerd?
Dat hoeft wel, maar dat zijn ze ook. Zowel node 1 als node 2 hebben een interface in Area 0.
  • FatalError
Je hebt gelijk, stom van me:)
Ben 'n beetje vermoeid;)
jeroenr> configs van pcmcia kaarten gaat via pcmcia-cs dmv het editen etc/pcmcia/network.opts & wireless.opts en voor pci kaart /etc/network/interfaces
overigens klopt het plaatje niet met de situatie, met router 1 wordt router 2 bedoeld en andersom :/
config files
network.opts router 1
case "$ADDRESS" in
*,*,*,00:02:6F:01:xx:xx)
INFO="Sector Zuid"
IF_PORT=""
BOOTP="n"
DHCP="n"
DHCP_HOSTNAME=""
PPPOE="n"
WHEREAMI="n"
IPADDR="10.33.28.1"
NETMASK="255.255.255.128"
NETWORK="10.33.28.0"
BROADCAST="10.33.28.127"
# GATEWAY="10.0.1.1"
DOMAIN=""
SEARCH=""
DNS_1=""
DNS_2=""
DNS_3=""
MOUNTS=""
MTU=""
IPX_FRAME=""
IPX_NETNUM=""
IPMASQ="n"
NO_CHECK=n
NO_FUSER=n
INFO="Sector Noord"
IF_PORT=""
BOOTP="n"
DHCP="n"
DHCP_HOSTNAME=""
PPPOE="n"
WHEREAMI="n"
IPADDR="10.33.28.129"
NETWORK="10.33.28.128"
BROADCAST="10.33.28.255"
DOMAIN=""
SEARCH=""
DNS_1=""
DNS_2=""
DNS_3=""
MOUNTS=""
MTU=""
IPX_FRAME=""
IPX_NETNUM=""
IPMASQ="n"
NO_CHECK=n
NO_FUSER=n
esac
wireless.opts router 1
case "$ADDRESS" in
INFO="Sector Zuid"
ESSID="test"
NWID=""
RATE="äuto"
MODE="master"
FREQ=""
CHANNEL="11"
SENS=""
KEY=""
RTS=""
FRAG=""
IWCONFIG=""
IWSPY=""
IWPRIV=""
INFO="Sector Noord"
ESSID="test"
NWID=""
RATE="auto"
MODE="master"
FREQ=""
CHANNEL="6"
SENS=""
KEY=""
RTS=""
FRAG=""
IWCONFIG=""
IWSPY=""
IWPRIV=""
esac
network.opts router 2
case "$ADDRESS" in
INFO="Sector Zuid"
IF_PORT=""
BOOTP="n"
DHCP="n"
DHCP_HOSTNAME=""
PPPOE="n"
WHEREAMI="n"
IPADDR="10.33.15.1"
NETMASK="255.255.255.0"
NETWORK="10.33.15.0"
BROADCAST="10.33.15.255"
# GATEWAY="10.0.0.1"
DOMAIN=""
SEARCH=""
DNS_1=""
DNS_2=""
DNS_3=""
MOUNTS=""
MTU=""
IPX_FRAME=""
IPX_NETNUM=""
IPMASQ="n"
NO_CHECK=n
NO_FUSER=n
esac
wireless.opts router 2
case "$ADDRESS" in
INFO="Sector Oost"
ESSID="test"
NWID=""
RATE="äuto"
MODE="master"
FREQ=""
CHANNEL="1"
SENS=""
KEY=""
RTS=""
FRAG=""
IWCONFIG=""
IWSPY=""
IWPRIV=""
esac
Is het wellicht nodig hosts toe te voegen in de routing table, dit doet ospf overigens niet maw ik weet niet of het persee nodig is. Bedoel zoiets als;
route add -host 10.0.0.3/32 ath0
met dit als resultaat
10.0.0.3        *               255.255.255.255 UH    0      0        0 ath0
voor de personen die zich afvroegen waarom ospf te gebruiken in deze ongelofelijk simpele opzet... het betreft een testopstelling waar uiteindelijk tientallen routers in opgenomen worden.
alleen mislukt het nu al jammerlijk
[ Voor 21% gewijzigd door Verwijderd op 12-12-2003 19:13 ]
Als in het plaatje router1 en 2 omgewisseld zijn, lijkt het mij dat het probleem niet in OSPF zit, dan klopt namelijk je routing table gewoon...
Router 2:
Is dus correct: forward traffic naar router 1
Weet je wat het source adres van de ping is?
Kan je wel vanaf router 1 pingen naar dat adres?
Wat is de output van een traceroute?
Probeer eens met "tcpdump ip proto icmp" te achterhalen of de ping wel aankomt op router 1.
Maar voor zover ik kan zien werkt OSPF goed: je routing tables worden immers gevuld met de juiste gegevens...
En? Hoe staat het ermee?
Ik vind het toch eigenlijk wel heel erg jammer dat je ons laat nadenken over een probleem, maar vervolgens nooit meer met de oplossing komt...
