200GB HDD ondersteuning
Ik heb een MSI K7t266 pro-R moederbord en ik wil een schijf van
200Gb aanschaffen. De laatste BIOS update van MSI ondersteunt
schijven van 160Gb.
Ik draai Windows2K Pro (geen Service Pack; wel handmatige patches)
I have a drive that is larger than 137 GB but the operating system only recognizes
128 GB or 137 GB. How can I fix this?
Most system BIOSes are limited to 137 GB because it can only support 28 bit
Logical Block Addressing (LBA).
[1]
Upgrade the operating system to either Windows 2000 with Service Pack 3 (or newer)
or Windows XP with Service Pack 1 (or newer)
[2]
and download the Maxtor Big Drive Enabler software patch. The Maxtor Big Drive
Enabler, once executed, will update the Windows registry for large drive support.
Maxtor's Big Drive Enabler is a one step executable that enables support for
drives larger than 137 Gigabytes in Windows 2000 Service Pack 3 and XP Service
Pack 1. This utility takes the guess work out of editing the Windows registry. The
Big Drive Enabler fixes an operating system limitation. This utility is needed
anytime a Hard Disk Drive larger than 137 GB is connected to the motherboard's ATA
bus, regardless of any system BIOS that supports 48-bit LBA.
Dus ondanks het feit dat de BIOS update schijven ondersteunt van 160Gb, zal
windows nog geupdate moeten worden om ook 48-bit LBA te ondersteunen
STAP 1 en 2 zijn toch helemaal overbodig als je: je BIOS update en dan deze
regfix toe past:
MS knowledge base:
[qoute]
To enable 48-bit LBA large-disk support in the registry:
Start Registry Editor (Regedt32.exe).
Locate and then click the following key in the registry:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Atapi\Parameters
On the Edit menu, click Add Value, and then add the following registry value:
Value name: EnableBigLba
Data type: REG_DWORD
Value data: 0x1
Quit Registry Editor.
[/qoute]
MAW dit is gewoon wat dat Maxtor Big Drive Enabler software patch(stap 2)
onderwater voor je doet, maar waarom dan Service pack bla bla update?
-LBA 48 fix is voor W2K daarmee in orde.
Wat ik niet zwart op wit heb kunnen vinden of de BIOS update die MSI heeft
uitgebracht voor 160Gb schijven, daarmee ook 200Gb kan ondersteunen. Er staat
namelijk 'supports 160Gb disk'.
VRAAG:
Enig idee of de 200Gb van Maxtor het dan ook zal doen?
Ik denk het wel, omdat 48bits LBA adressering mogelijk wordt gemaakt door de
BIOS update, maar ik weet het niet zeker, vandaar de vraag........
  • BalusC
BalusC
Carpe diem
48bits LBA addressering gaat tot 128PB (144 miljoen GB). Zie ook de FAQ van dit subforum onder het kopje "Wat is de grootste HDD die ik in mijn PC kan doen?" en de daaropvolgende hoofdstuk :)
Ik heb overigens "Gb" in de titel veranderd naar "GB", staat wel netter zo namelijk. Anders komt jouw harddisk acht maal kleiner over dan bedoeld ;)
[ Voor 31% gewijzigd door BalusC op 11-12-2003 18:30 ]
BalusC schreef op 11 december 2003 @ 18:29:
<small>Ik heb overigens "Gb" in de titel veranderd naar "GB", staat wel netter zo namelijk. Anders komt jouw harddisk acht maal kleiner over dan bedoeld ;)</small>
Ah Merci !
ps: je het gelijk byte niet bit :o
Die service pack update voor W2K verwijst naar onderstaande bestanden:
Date Time Version Size File name
10/19/2001 01:42 PM 5.0.2195.4529 86,768 Atapi.sys
04/19/2002 05:43 PM 214,938 Update.inf
Is het dan naast die registry tweak, toch noodzakelijk om windows te updaten (SP3) voor 48bits LBA?
  • BalusC
BalusC
Carpe diem
Bij mijn weten hoeft dat niet :)
  • pisart
Normaal gaat het wel werken, maar ik had ook een msi (850 pro2) en een 200GB maxtor en het werkte niet. Ik had ook de bios geupdate zodat het de 160GB harde schijven ondersteunde, maar het had geen effect. De bios wou maar niet de volledige hd herkennen. Xp wel met die reghackje, maar als de bios het niet herkend dan ben je er niets mee. Je hoeft ook niets te updaten, gewoon die tweak doen en het moet wel werken.
Da's duidelijk, iig bedankt voor de reacties.
Hey gozers,
Heb een maxtor 260gig. Mijn bios herkent m ook als zodanig. Xp niet, ook niet na updaten sp1 en ook nog s die big drive enabler.
Heeft er iemand nog suggesties?
met partition magic ben ik er uitgekomen.
:Y)
[ Voor 15% gewijzigd door Verwijderd op 12-12-2003 20:25 ]
  • Yustme
  • Laatst online: 23-04-2023
Stel dat het in de BIOS op "Large" staat.
Zou het daarmee ook kunnen? Dan heb ik het over "patchen".
Of moet het op LBA staan?
Mijn pc in LBA laten starten gaat niet. Kom niet verder dan dat tabelletje mbt geïnstalleerde hardware.
En in "Large" zie ik geen veranderingen.
Iemand?
Niets is zo eerlijk verdeelt als het verstand, want iedereen denkt er namelijk genoeg van te hebben...
  • wasco
  • Laatst online: 09-09 13:37
wasco
brightest crayon in the box
ik heb net hetzelfde moederbord als de TS: MSI K7t266 pro-R (MS-6380)
ik heb er momenteel 2 * 250 GB aanhangen, maar niet aan de IDE's van het moederbord. Heb het allemaal aan een raid-controller gehangen. Moederbord had welliswaar
een RAID-controller aan boord maar das toch beperkt als er iets mis loopt met het moederbord. Heb nu Highpoint RocketRaid 404 en daar kunnen 8 harde schijven aanhangen voor een zacht prijsje. Ik heb dus niet geprobeerd of ze werken op het moederbord zelf omdat ik een ander bios draai. Had ooit is ergens een gehackt bios gevonden waarmee ik zelf IRQ's kon toewijzen en ik gebruik nu dat. Zonder dit bios is men computer gewoon een IRQ-soep. Nooit meer MSI voor mij net om die reden, das toch mijn gevoel.
Ik draai XP met SP1 en daarbij ook nog is een patch van MS die ervoor zorgt dat bij in standby gaan en er terug uitkomen geen corruptie van de data optreedt. (wat bij XP en SP1 wél gebeurt)
Als iemand mij een IRQ-instelbare versie van de laatste bios kan geven dan wil ik het wel proberen...
wasco [the brightest crayon in the box]
