Postfix geeft opeens een error.
  • 175 views sinds 30-01-2008
  • RvdH
  • Laatst online: 28-07 15:42
RvdH
Uitvinder van RickRAID
Hoi,
Sinds drie dagen geeft Postfix opeens deze foutmelding:
Dec  8 11:46:36 web2 postfix/sendmail[3067]: fatal: -n option not supported
Dec  8 11:52:58 web2 postfix/sendmail[3094]: fatal: -n option not supported
Dec  8 11:57:24 web2 postfix/sendmail[3121]: fatal: -n option not supported
Dec  8 12:12:15 web2 postfix/sendmail[3238]: fatal: -n option not supported
Dec 11 09:46:38 web2 postfix/sendmail[27336]: fatal: -n option not supported
Dec 11 09:51:51 web2 postfix/sendmail[27384]: fatal: -n option not supported
Dec 11 10:01:54 web2 postfix/sendmail[27544]: fatal: -n option not supported
Dec 11 10:21:08 web2 postfix/sendmail[27808]: fatal: -n option not supported
Dec 11 10:23:36 web2 postfix/sendmail[27822]: fatal: -n option not supported
Dec 11 10:31:51 web2 postfix/sendmail[27925]: fatal: -n option not supported
Dec 11 10:39:38 web2 postfix/sendmail[28013]: fatal: -n option not supported
Dec 11 10:43:14 web2 postfix/sendmail[28055]: fatal: -n option not supported
Dec 11 10:46:22 web2 postfix/sendmail[28085]: fatal: -n option not supported
In de configuratie is niets verandert ofzo, en in master.cf staat ook geen -n optie ergens (behalve voor uucp).
Iemand enig idee wat dit kan zijn? Googlen naar de error levert geen hits..
Hier een gedeelte uit de logfile waartussen de error staat:
29
30
31
Dec 11 10:37:20 web2 postfix/smtpd[27992]: connect from
    pcp114320pcs.clmntn01.nj.comcast.net[68.45.66.120]
Dec 11 10:37:22 web2 postfix/smtpd[27992]: C9DF74E2D9: client=
Dec 11 10:37:24 web2 postfix/smtpd[27992]: C9DF74E2D9: reject:
    RCPT from pcp114320pcs.clmntn01.nj.comcast.net[68.45.66.120]:
    554 Service unavailable; Client host [68.45.66.120]
    blocked using bl.spamcop.net;
    Blocked - see http://www.spamcop.net/bl.shtml?68.45.66.120;
    from=<pz91buqfyn@mailnet.com> to=<aba@abaa.com> proto=SMTP
    helo=<pcp114320pcs.clmntn01.nj.comcast.net>
Dec 11 10:37:27 web2 postfix/smtpd[27992]: lost connection after RCPT from
Dec 11 10:37:27 web2 postfix/smtpd[27992]: disconnect from
Dec 11 10:48:42 web2 postfix/smtpd[28113]: connect from
    d134208.upc-d.chello.nl[213.46.134.208]
Dec 11 10:48:42 web2 postfix/smtpd[28113]: AF9AF4E2D9: client=
Dec 11 10:48:44 web2 postfix/smtpd[28113]: AF9AF4E2D9: reject:
    RCPT from d134208.upc-d.chello.nl[213.46.134.208]:
    Client host [213.46.134.208] blocked using bl.spamcop.net;
    Blocked - see http://www.spamcop.net/bl.shtml?213.46.134.208;
    from=<npak679@yahoo.com> to=<postmaster@theodeboer.com> proto=SMTP
    helo=<d134208.upc-d.chello.nl>
Dec 11 10:48:46 web2 postfix/smtpd[28113]: lost connection after RCPT from
Verder lijkt het er ook niet op dat er mails verloren gaan ofzo..
[ Voor 56% gewijzigd door RvdH op 11-12-2003 11:00 ]
  • Egbert
  • Laatst online: 07-09 21:20
Wat voor server is het? Zijn er users (of bijvoorbeeld php script) die mail verzenden? Misschien dat iemand in zn php scriptje dacht ns een keer -n bij de mailopties mee te geven.
  • RvdH
RvdH
't Is een webserver.. maar dat is inderdaad een goed idee om even te controleren. Hoe geef je mailopties mee in PHP?
't Is waarschijnlijk geen website, geen van de tijden die in de postfix logfile staan komen overeen met apache's logfiles.. maar ik ga even verder spitten.
[ Voor 42% gewijzigd door RvdH op 11-12-2003 11:08 ]
  • Egbert
Het kan met php-config instellingen (in php.ini, in httpd.conf, wellicht ook in .htaccess), maar meer gebruikelijk gewoon direct met het mail() commando in het php script zelf:
bool mail ( string to, string subject, string message [, string additional_headers [, string additional_parameters]])
en dan bij de 'additional_parameters'. Vooral handig om daar "-fafzender@domein.nl" neer te zetten, dat stelt de enveloppe-sender in, gebouncte mailtjes komen dan bij dat adres terecht ipv bij "nobody@server.tld" of "www-data@..." (wat je ook maar hebt als apache-user)
  • Egbert
linkje met info voor evt reden -n te willen gebruiken:
http://www.busan.edu/~nic/networking/sendmail/ch24_06.htm
  • RvdH
RvdH
Ik heb een cgi-scriptje gevonden wat sendmail aanroept met de -n optie, en die optie eruit gesloopt. Ik hoop dat dit 't was, maar het blijft vreemd dat er niks in apache's logfile staat over het script rond die tijd..
Aha! Wel in Apache's suexec log:
[2003-12-08 11:46:36]: uid: (501/interstad) gid: (501/501) cmd: framecal.pl
[2003-12-08 11:52:58]: uid: (501/interstad) gid: (501/501) cmd: framecal.pl
[2003-12-08 11:57:24]: uid: (501/interstad) gid: (501/501) cmd: framecal.pl
[2003-12-11 10:43:14]: uid: (501/interstad) gid: (501/501) cmd: framecal.pl
[2003-12-11 10:46:22]: uid: (501/interstad) gid: (501/501) cmd: framecal.pl
Dat komt wel errug netjes overeen. Bedankt voor je hulp!
[ Voor 55% gewijzigd door RvdH op 11-12-2003 11:20 ]
