[debian] boot naar runlevel 0
  • klokop
  • Laatst online: 17-06 14:59
klokop
swiekie swoeng
Als ik de pc boot, kom ik uiteindelijk in runlevel 0 terecht en wordt de pc gereboot. Geen idee wat de oorzaak is. Geschiedenis:
- libranet 2.7 schoon geinstalleerd, zonder X.
- apt-get dist-upgrade naar 'sid' (testing)
- apt-get install kde
Tot dan werkte alles prima, zelfs KDE.
Tot ik vanochtend de pc aanzette en ik dus niet meer kan inloggen, want debian floept naar runlevel 0, en stopt ermee.
-in /var/log/messages staat geen relevante info.
-in /var/log/syslog staat geen relevante info.
- /var/log/boot~:
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
bootlogd.
Activating swap.
Checking root file system...
fsck 1.35-WIP (21-Aug-2003)
* Warning: The dma on your hard drive is turned off. *
* This may really slow down the fsck process.        *
Reiserfs super block in block 16 on 0x302 of format 3.6 with standard journal
Blocks (total/free): 1024143/600944 by 4096 bytes
Filesystem is cleanly umounted
Filesystem seems mounted read-only. Skipping journal replay.
Checking internal tree../  1 (of   2)/  1 (of  86) [knip]
System time was Wed Dec 10 09:17:55 UTC 2003.
Setting the System Clock using the Hardware Clock as reference...
System Clock set. System local time is now Wed Dec 10 10:17:57 CET 2003.
Calculating module dependencies... modprobe: modprobe: Can't locate module mousedev
done.
Loading modules: sr_mod ide-floppy ide-cd ide-scsi parport lp libranet-sound-0 libranet-ethernet-0
Checking all file systems...
Setting kernel variables..
Mounting local filesystems...
nothing was mounted
Running 0dns-down to make sure resolv.conf is ok...done.
Cleaning: /etc/network/ifstate.
Setting up IP spoofing protection: rp_filter.
Configuring network interfaces...done.
Starting portmap daemon: portmap.
Loading the saved-state of the serial devices...
/dev/ttyS0 at 0x03f8 (irq = 4) is a 16550A
unicode_stop: Already in byte-mode
^[[9;30]^[[14;30]
System Clock set. Local time: Wed Dec 10 10:18:17 CET 2003
Cleaning: /tmp /var/lock /var/run.
Initializing random number generator... done.
Recovering nvi editor sessions... done.
Setting up X server socket directory /tmp/.X11-unix...done.
INIT: Entering runlevel: 0
Stopping portmap daemon: portmap.
Sending all processes the TERM signal...
Inloggen in 'single user mode' lukt overigens wel.
Ik heb 'voor de grap' (je moet toch iets proberen) kernel 2.6.0 geinstalleerd. Daarmee kom ik wel zover dat ik kan inloggen, maar dan doen een heleboel andere dingen het weer niet (wat natuulijk goed mogelijk is: ik heb alleen maar de nieuwe kernel geinstalleerd, verder niks aangepast).
"Passing silhouettes of strange illuminated mannequins"
  • moto-moi
  • Laatst online: 09-06-2011
moto-moi
Ja, ik haat jou ook :w
Wat staat er als default runlevel in /etc/inittab ?
[ Voor 9% gewijzigd door moto-moi op 10-12-2003 11:19 ]
God, root, what is difference? | Talga Vassternich | IBM zuigt
  • Warbringer
  • Laatst online: 16:10
regel 26 - Nothing was mounted.
wordt er wel een FS gemount door linux?
I want to live forever, so far.. so good.
Wat is je default runlevel? (cat /etc/inittab | grep default)
En heb je mischien (al is het onwaarschijnlijk) een script wat init 0 aanroept?
overigens, voor de duidelijkheid, runlevel 0 staat voor shutdown, en niet reboot (runlevel 6). Waarom jouw bak in dit geval reboot is mij een raadsel.
  • klokop
klokop
swiekie swoeng
Post ik zometeen.
Tsja.... geen idee. Blijkbaar niet nee.
Post ik zometeen.
Trouwens: het systeem reboot idd niet, maar stopt met de woorden: 'poweroff'.
kan ik een reiserfs partitie bekijken met win2k?? vast niet he? dan moe'k ff rebooten.
[ Voor 20% gewijzigd door klokop op 10-12-2003 15:21 . Reden: kan ik een reiserfs partitie bekijken met win2k?? vast niet he? ]
  • klokop
klokop
swiekie swoeng
inittab - behoorlijk standaard zo lijkt me...
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
# /etc/inittab: init(8) configuration.
# $Id: inittab,v 1.91 2002/01/25 13:35:21 miquels Exp $
# The default runlevel.
# Boot-time system configuration/initialization script.
# This is run first except when booting in emergency (-b) mode.
si::sysinit:/etc/init.d/rcS
# What to do in single-user mode.
~~:S:wait:/sbin/sulogin
# /etc/init.d executes the S and K scripts upon change
# of runlevel.
# Runlevel 0 is halt.
# Runlevel 1 is single-user.
# Runlevels 2-5 are multi-user.
# Runlevel 6 is reboot.
l0:0:wait:/etc/init.d/rc 0
l1:1:wait:/etc/init.d/rc 1
l2:2:wait:/etc/init.d/rc 2
l3:3:wait:/etc/init.d/rc 3
l4:4:wait:/etc/init.d/rc 4
l5:5:wait:/etc/init.d/rc 5
l6:6:wait:/etc/init.d/rc 6
# Normally not reached, but fallthrough in case of emergency.
z6:6:respawn:/sbin/sulogin
# What to do when CTRL-ALT-DEL is pressed.
ca:12345:ctrlaltdel:/sbin/shutdown -t1 -a -r now
# Action on special keypress (ALT-UpArrow).
#kb::kbrequest:/bin/echo "Keyboard Request--edit /etc/inittab to let this work."
# What to do when the power fails/returns.
pf::powerwait:/etc/init.d/powerfail start
pn::powerfailnow:/etc/init.d/powerfail now
po::powerokwait:/etc/init.d/powerfail stop
# /sbin/getty invocations for the runlevels.
# The "id" field MUST be the same as the last
# characters of the device (after "tty").
# Format:
#  <id>:<runlevels>:<action>:<process>
# Note that on most Debian systems tty7 is used by the X Window System,
# so if you want to add more getty's go ahead but skip tty7 if you run X.
1:2345:respawn:/sbin/getty 38400 tty1
2:23:respawn:/sbin/getty 38400 tty2
3:23:respawn:/sbin/getty 38400 tty3
4:23:respawn:/sbin/getty 38400 tty4
5:23:respawn:/sbin/getty 38400 tty5
6:23:respawn:/sbin/getty 38400 tty6
# Example how to put a getty on a serial line (for a terminal)
#T0:23:respawn:/sbin/getty -L ttyS0 9600 vt100
#T1:23:respawn:/sbin/getty -L ttyS1 9600 vt100
# Example how to put a getty on a modem line.
#T3:23:respawn:/sbin/mgetty -x0 -s 57600 ttyS3
  • mindcrash
  • Laatst online: 22-11-2019
mindcrash
Rebellious Monkey
Hm... en wat staat er in je fstab ?
Wat jij nu meemaakt is namelijk vrij normaal gedrag in elke linux distro als er geen root file system kan worden gevonden ;)
"The people who are crazy enough to think they could change the world, are the ones who do." -- Steve Jobs (1955-2011) , Aaron Swartz (1986-2013)
  • Spider.007
Spider.007
* Tetragrammaton
Bij mij staat er in de documentatie dat runlevel 2 unused is; vandaar dat mijn default runlevel dan ook
is. Zou je dat eens kunnen proberen?
# These are the default runlevels in Slackware:
# 0 = halt
# 1 = single user mode
# 2 = unused (but configured the same as runlevel 3)
# 3 = multiuser mode (default Slackware runlevel)
# 4 = X11 with KDM/GDM/XDM (session managers)
# 5 = unused (but configured the same as runlevel 3)
# 6 = reboot
Prozium - The great nepenthe. Opiate of our masses. Glue of our great society. Salve and salvation, it has delivered us from pathos, from sorrow, the deepest chasms of melancholy and hate
  • klokop
klokop
swiekie swoeng
/etc/fstab
# /etc/fstab: static file system information.
#<device>     <mount point> <type>    <options>             <dump>  <pass>
/dev/hda2     /             reiserfs    defaults                 0       1
proc          /proc            proc        defaults                 0       0
/dev/hda8     none             swap        sw                       0       0
/dev/fd0      /floppy          auto        defaults,user,noauto     0       0
/dev/hdc      /cdrom           iso9660     defaults,user,noauto,ro  0       0
  • klokop
klokop
swiekie swoeng
Spider.007 schreef op 10 december 2003 @ 16:04:
Maar da's Slackware, ik doe aan Debian. Da's anders... :|
  • Spider.007
Spider.007
* Tetragrammaton
klokop schreef op 10 december 2003 @ 16:40:
/etc/fstab
Moet je swap niet als swap worden geladen ipv none?
/dev/sda2        swap             swap        defaults         0   0
  • klokop
klokop
swiekie swoeng
Spider.007 schreef op 10 december 2003 @ 16:44:
Hmmm. Volgens mij niet... Ik d'r niks aan veranderd, is standaard, en lijkt ook wel te kloppen.
  • smoking2000
  • Laatst online: 15:44
smoking2000
DPC-Crew
dpkg-reconfigure reality
Heb je ReiserFS wel in je kernel meegebakken?
Doe je machine dit ook als je een andere kernel image boot (een die voorheen wel altijd werkte) ?
| [Folding@Home] Announce: Client monitor voor Linux (fci) | fci-1.8.4 | Fatal Error Group |
  • DeMoN
  • Laatst online: 12-03 14:25
DeMoN
Pastafari
Neuh, hier @ een standaard Debian installatie op mijn werk (werkt zonder problemen):
bruyn:~# cat /etc/fstab
# <file system> <mount point>   <type>  <options>               <dump>  <pass>
/dev/hda1       /               ext2    errors=remount-ro       0       1
/dev/hda5       none            swap    sw                      0       0
/dev/fd0        /floppy         auto    user,noauto             0       0
/dev/cdrom      /cdrom          iso9660 ro,user,noauto          0       0
bruyn:~# cat /etc/debian_version && uname -a
3.0
Linux bruyn 2.2.20-idepci #1 Sat Apr 20 12:45:19 EST 2002 i686 unknown
Dus lijkt me goed zitten. :)
hmmm 9 minuten te laat maar :Z
[ Voor 6% gewijzigd door DeMoN op 10-12-2003 17:00 ]
Gamertag: Cosmicv0id
"Het woord Gods is voor mij niets meer dan een expressie en het product van menselijke zwakheid. De Bijbel is een verzamelwerk van legendes die achtenswaardig zijn maar ook primitief en kinderachtig.'' - Albert Einstein
  • klokop
klokop
swiekie swoeng
Ik heb wat gerommeld in lilo.conf... stond *iets* niet helemaal goed denk ik. Ik typ dit nu weer vanuit KDE, dus alles doet het weer.
  • Spider.007
Spider.007
* Tetragrammaton
klokop schreef op 10 december 2003 @ 17:38:
Je hebt zelf ook niet duidelijk wat er fout stond? Dit zou andere gebruikers wellicht kunnen helpen die tegen hetzelfde probleem aanlopen :)
  • klokop
klokop
swiekie swoeng
eh, nee, ik weet het niet exact.
Maar iets in de trant van:
image=/boot/vmlinuz-2.4.22
initrd=/boot/initrd.img-2.4.19
read-only.
dus niet de juiste vmlinuz bij de initrd.img.
