[delphi] Keys doorsturen naar andere app werkt maar half
  • 246 views sinds 30-01-2008
  • Rambo
  • Laatst online: 19-12-2024
Ik ben bezig met een programmaatje dat edit.text doorstuurt naar een opgegeven venster. Ik heb hiervoor een component gevonden:
SendKeys.pas
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
{              SendKeys Unit for Delphi 32           }
{    Copyright (c) 1999 by Borut Batagelj (Slovenia) }
{                       Aleksey Kuznetsov (Ukraine)  }
{            Home Page: www.utilmind.com             }
{            E-Mail: info@utilmind.com               }
unit SendKeys;
interface
uses
  Windows, SysUtils;
const
  SK_BKSP = #8;
  SK_TAB = #9;
  SK_ENTER = #13;
  SK_ESC = #27;
  SK_ADD = #107;
  SK_SUB = #109;
  SK_F1 = #228;
  SK_F2 = #229;
  SK_F3 = #230;
  SK_F4 = #231;
  SK_F5 = #232;
  SK_F6 = #233;
  SK_F7 = #234;
  SK_F8 = #235;
  SK_F9 = #236;
  SK_F10 = #237;
  SK_F11 = #238;
  SK_F12 = #239;
  SK_HOME = #240;
  SK_END = #241;
  SK_UP = #242;
  SK_DOWN = #243;
  SK_LEFT = #244;
  SK_RIGHT = #245;
  SK_PGUP = #246;
  SK_PGDN = #247;
  SK_INS = #248;
  SK_DEL = #249;
  SK_SHIFT_DN = #250;
  SK_SHIFT_UP = #251;
  SK_CTRL_DN = #252;
  SK_CTRL_UP = #253;
  SK_ALT_DN = #254;
  SK_ALT_UP = #255;
procedure SendKeyString(Text: String);
procedure SendKeysToTitle(WindowTitle: String; Text: String);
procedure SendKeysToHandle(WindowHandle: hWnd; Text: String);
procedure MakeWindowActive(wHandle: hWnd);
function GetHandleFromWindowTitle(TitleText: String): hWnd;
implementation
var
   i: Integer;
   Shift: Boolean;
   vk, ScanCode: Word;
   ch: Char;
   c, s: Byte;
const
   vk_keys: Array[0..9] of Byte =
      (VK_HOME, VK_END, VK_UP, VK_DOWN, VK_LEFT,
       VK_RIGHT, VK_PRIOR, VK_NEXT, VK_INSERT, VK_DELETE);
   vk_shft: Array[0..2] of Byte = (VK_SHIFT, VK_CONTROL, VK_MENU);
   flags: Array[False..True] of Integer = (KEYEVENTF_KEYUP, 0);
begin
   Shift := False;
   for i := 1 to Length(Text) do
    begin
     ch := Text[i];
     if ch >= #250 then
      begin
       s := Ord(ch) - 250;
       Shift := not Odd(s);
       c := vk_shft[s shr 1];
       ScanCode := MapVirtualKey(c,0);
       Keybd_Event(c, Scancode, Flags[shift], 0);
      end
     else
      begin
       vk := 0;
       if ch >= #240 then
        c := vk_keys[Ord(ch) - 240]
       else
        if ch >= #228 then {228 (F1) => $70 (vk_F1)}
         c := Ord(ch) - 116
        else
         if ch < #110 then
          c := Ord(ch)
         else
          begin
           vk := VkKeyScan(ch);
           c := LoByte(vk);
          end;
       if not Shift and (Hi(vk) > 0) then { $2A = scancode of VK_SHIFT }
        Keybd_Event(VK_SHIFT, $2A, 0, 0);
       Keybd_Event(c,scancode, 0, 0);
       Keybd_Event(c,scancode, KEYEVENTF_KEYUP, 0);
        Keybd_Event(VK_SHIFT, $2A, KEYEVENTF_KEYUP, 0);
      end;
    end;
end;
begin
  if IsIconic(wHandle) then
   ShowWindow(wHandle, SW_RESTORE)
  else
   BringWindowToTop(wHandle);
end;
var
  StrBuf: Array[0..$FF] of Char;
begin
  Result := FindWindow(PChar(0), StrPCopy(StrBuf, TitleText));
end;
var
  Window: hWnd;
begin
  Window := GetHandleFromWindowTitle(WindowTitle);
  MakeWindowActive(Window);
  SendKeyString(Text);
end;
begin
  MakeWindowActive(WindowHandle);
end;
end.
Het doorsturen lukt maar half.
Alleen letters in uppercase worden goed weergegeven. Als je ze in lowercase invoert dat worden er rare tekens naar het doelprogramma gestuurt.
Ik wilde de string www.adres.nl doorsturen naar het doelprogramma.
Dit lukt voor geen meter :/
Wat ik tot nu toe heb:
bericht := UpperCase(Edit1.Text);
programma := Edit2.Text;
//alleen a tm z en 0 t/m 9 lukt op deze manier, SK_ENTER=enter :)
SendKeysToTitle(programma, bericht+SK_ENTER);
Wat voorbeelden:
//zonder de input naar uppercase te zetten dus
bericht :=Edit1.Text; //invoer is: 'teststring'
output:
t5ststr9n7
//wel eerst naar uppercase
bericht :=UpperCase(Edit1.Text); //invoer is: 'teststring'
output:
teststring
bericht :=UpperCase(Edit1.Text); //invoer is: 'www.google.nl'
output:
wwwgooglenl
Maar hoe krijg ik daar nu een .(punt) tussen?
Heb echt al alles geprobeerd. Ben er al 2 dagen mee bezig en met google/delphi sites kom ik ook niet veel verder.
Wat ik uitgevogeld heb is dat ik waarschijnlijk iets met #46 moet doen :?
Dat is de punt. Maar ergens anders kom ik weer het getal 110 tegen.
Ik heb ook al zitten spelen met Ord en Chr, maar het lukt maar niet.
Iemand een idee hoe ik dit kan oplossen? 8)7
  • Woohooo
  • Laatst online: 20:04
Woohooo
Smilie, James Smilie
Heb je al geprobeert om die tekst uit Edit1.Text in een aparte String te zetten?
en daarna in die UpperCase te plaatsen?
IK zou zeggen ga eens op zoek naar de unit sndkey32.pas die doet het wel goed opzich.
staat btw op de Delphi CD.
[ Voor 15% gewijzigd door Verwijderd op 09-12-2003 11:25 ]
  • Rambo
Verwijderd schreef op 09 december 2003 @ 11:22:
Ben nu op stage ;)
Dus ik zoek hem even op internet.
Dit wordt niks meer zo, met het huidige component.
ik gebruik nu bovenstaand component, werkt prima.
Voor meer info:
Topic op nldelphi forum
[ Voor 24% gewijzigd door Rambo op 09-12-2003 15:28 ]
