Voor Elements:
Solution 1
If you use Photoshop Elements 1.0, do one or more of the following:
-- Re-create the Photoshop Elements preferences file. To re-create the preferences file, restart Photoshop Elements and immediately press Ctrl+Alt+Shift until you receive the message "Create the Photoshop Elements Settings File?" Click Yes.
Note: To prevent the error from recurring, deselect Close Palette to Shortcuts Well on the Hints palette menu, or exit from Photoshop Elements and rename the ActiveShare.dll and PictureCD.dll files (for example, rename them to ActiveShare.old and PictureCD.old, respectively). When you rename the ActiveShare.dll and PictureCD.dll files, the ActiveShare and PictureCD options aren't available on the Import menu.
-- Upgrade to Photoshop Elements 2.0. You can purchase Photoshop Elements 2.0 from the Adobe Store at
www.adobe.com/products/photoshopel/main.html or from Customer Services at 800-492-3623.
Solution 2
If you use Windows XP and you installed Windows XP over a prior version of Windows, perform a clean reinstall of Windows XP, and then reinstall Photoshop Elements:
1. Back up the files you want to save, such as Photoshop Elements files you created.
2. Use the Add/Remove programs utility in Windows to remove Photoshop Elements, and then remove Windows XP.
3. Perform a clean install of Windows XP: That is, select New Installation for Windows XP, not Quick Upgrade.
4. Reinstall Photoshop Elements.
http://www.adobe.com/support/techdocs/2f096.htm
google, mooi man
